Flash LG PK5 DEMO - CH431A ERROR - verification error on address 00000000
  • kyrios
    • Nov 2023
    • Spain
    Hello!
    I apoligize for my English. I need some help.
    I have an LG PK5 in demo version and trying to repair it, I found the original firmware in this forum to flash speaker to the original version.
    Without having any idea about these things, I give thanks this forum and other tutorials, I bought a CH431A programmer and I have tried to do all the steps but after reading the new firmware, in the "verification" step I get this error: verification error on address 00000000
    Could someone help me to solve it, please?
    Thank you so much
  • 0888572025
    • Dec 2023
    • Viet nam
    I also have a pl5 demo. please guide me how to flash rom
      • 31103
      what is the exact part number of the flash chip?
      and are you removing it or trying to program it on the board?
      • jingleslacks
        • 26
        Originally posted by kyrios
        Hello!
        Thank you so much
        I'm having the same problem with my PL5 and PL7 (newer version.) I'm also still learning and could use assistance.
        • Superbee_dad
          Sharp 80” long short flash backlight error - Help
          by Superbee_dad
          Hello Sharp TV experts
          Our Sharp LC-80LE642U displays one short one long flash error code which is a backlight error. I went into service mode and there were 8 lamp error counts recorded. I reset the count to 0 and did a reset. The last monitor error cause was 16 B00014639:12. 16 is the code for backlight error. I tried to power the tv up but went back into error mode.
          > I checked voltages on the power supply board and they all check out .. including 3.28 volts at the error pin.
          > There is power to the cpu and T-CONN and no faults found there. The cpu has a flashing...
          01-24-2025, 11:51 PM
        • Sus256
          HISENSE 65E7KQ PRO - no boot
          by Sus256
          Hi all!
          HISENSE 65E7KQ PRO
          RSAG7.820.13512 - chassis
          MT9618BAATAB - cpu
          RSAG7.820.12059 - power
          HD650Y3U77 - panel
          KLM8G1GETF - emmc
          Replaced emmc.
          Terminal log
          UART
          AC_ON
          E-B
          FDE enabled
          06-01-2025, 02:11 AM
        • ekozeko333
          by ekozeko333
          🧠 What I’ve Done So Far
          Flashed...
          06-21-2025, 02:48 AM
        • andre4744
          Dell G15 5515 - Error 43 After Incorrect VBIOS Flash on RTX 3050
          by andre4744
          The dell g15 5515 service tag 64TXVM3 turned on and no image appeared. I reprogrammed the wrong BIOS chip, I ended up doing it on the 25Q16JWSIQ VBIOS chip. After realizing the error, I reprogrammed the correct chip and burned the ROM of the GPU taken from TECHUP (https://www.techpowerup.com/vgabios/...le-4096-210618) on 25Q16JWSIQ. When starting, the notebook turned on normally and showed an image, but the GPU shows error 43 in Windows. I uninstalled the drivers via DDU and installed them again, without success. I used NVFlash, the GPU is recognized, but the EEPROM is not...
          02-10-2025, 08:44 AM
        • Woodsworth
          PS3 CECHC03 60GB YLOD Troubleshooting
          by Woodsworth
          I have a post on psx-place for this but thought I'd try here as well in case anyone has experience or the schematics or any kind of help. Here's the original post from psx-place:
          START
          Hi, so I bought a YLOD Fat PS3 as I wanted a repair project and thought it would be a good way to get experience. I was able to solder to the RX, TX and Diag pads on the COK-002 motherboard and was able to get external access and retrieved the codes. I haven't powered it on beforehand so these should be the last ones. I did try to get internal access immediately after but kept getting scopen response...
          03-19-2024, 07:58 AM
