PS5 Digital component ID!
  • Dobbin123
    • Jan 2024
    • 11
    Hope you can help me identify some components and their values on the PS5 Digital.
    They were based around the HDMI port and seem to have been blown away during a port replacement.
    I have a picture from another source and I have circled and numbered the parts in blue.
    I think they are 2 caps 1 resister and 1 diode.
    any help would be appreciated!
  • LaPCon_IT
    • Sep 2022
    • 82
    • Malta
    1. capacitor 100pF/50V
    2. diode 1SS352
    3. resistor 27k 1/16W
    4. capacitor 100nF/16V
    • Dobbin123
      • Jan 2024
      • 11
      Thank you for the prompt reply! Much appreciated!
      • PantherDave
        by PantherDave
        Hi all!
        05-29-2024, 02:01 PM
      • asr
        Finding replacement diode iPad Pro 3rd gen A1701
        by asr
        Hello, I am looking for help to replace a damaged diode. The tristar was replaced and a diode was damaged in the process. I have a picture of the diode but dont have an exact donor. I mostly have macbooks for donors and only a few ipad and iphone boards. Diode part number: DSF01S30SCAP
        Im not sure where to find the ipad board number. Anybody have an idea where else this diode is used on other boards? Thanks....
        07-09-2024, 06:24 PM
      • unimatrix93
        TV backlight zener diode
        by unimatrix93
        Hello everyone, I'm repairing an LG TV backlight and I noticed some strange behavior when I touching the backlight strip with a missing Zener diode.
        So I replaced the leds on the strips and they seemingly working fine, but soon as I touch the strip which has a missing Zener diode the whole backlight turns off for a few seconds and then turns back on.
        Is this caused by the missing diode? If so what kind of zener diode should I use to replace it?.
        The led strips has 9 6V leds.
        02-10-2025, 12:13 PM
      • Gentian
        Please help me find 7 pin smd ic 901 part number in Delta DPS-300AB-76 LED Display Power Supply
        by Gentian
        I have a 5V 55A led Delta power supply with no output. I found this 7 pin IC 901 damaged as in the photo. All other elements look ok. I checked and every other surrounding componets diodes, resistors and capacitors look ok. I have 2 identical power supplies removed from a led wall which have the same defect with this ic burned but not a working one for reference. I founded by measurements that pin 7 goes to positive hot 450V 220uF electrolytic capacitor primary side. Pin 1, 2, 3, 4 connected together to pcb cooper trace. These four pins goes to negative side of 10uF 50V electrolytic capacitor...
        09-27-2025, 11:03 PM
      • Baste
        MBR3045CT and SR3045LCT Schottky diode testing help.
        by Baste
        Hello experts,
        Can anyone educate me on how to test MBR3045CT and SR3045LCT Schottky diodes? I'm totally a newbie in electronics, so forgive me if I have cheap tools. In my effort to repair a Gigabyte PSU, I stumbled upon the two diodes, which I suspect are leaky. I tested this with my two cheap multimeters and the newly bought LCR-T4 MC328, and I got confusing results. Below are my test results.
        Aneng ST182 Meter.
        Diode mode.
        MBR3045CT:
        Diode mode
        Pin 2-1 - 0.150v
        Pin 2-3 - 0.150v ...
        10-21-2025, 06:14 AM
