Ancel BA-101 automotive battery tester reads low on flooded batteries
  • petehall347
    • Jan 2015
    • 4451
    and that bad soldering
    • CapLeaker
      Leaking Member
      • Dec 2014
      • 8352
      only looks like so for some reason. Cleaned it up and shot a photo from my microscope.
      • petehall347
        • Jan 2015
        • 4451
        looks better .
        • CapLeaker
          Leaking Member
          • Dec 2014
          • 8352
          Yes, it does… and the 7805 doesn’t have a hole in it. Not sure why it looked like that on the pictures that I took the first round. I did find a couple of shoddy solder joints and fixed those, but I still don’t think that’s the problem.
          • CapLeaker
            Leaking Member
            • Dec 2014
            • 8352
            Put it back together and no dice. Same thing. I think there is a firmware bug.
            • redwire
              • Dec 2010
              • 3912
              The whole board looks like an early prototype. The current-sense resistor is jumpered out 0R, so many MCU pins wasted not used, and then the tiny film caps seem to be charged and discharged into the battery or something to measure ESR.
              It looks hokey and I wouldn't trust its numbers. Most testers are using one power mosfet and resistor to pulse load the battery at say 6A, measure the ramp down and calculate ESR.
              • CapLeaker
                Leaking Member
                • Dec 2014
                • 8352
                Funny thing. If I use the AGM option and test an AGM battery it’s like within 3% or so. It just the flooded selection is screwed up.
                • redwire
                  • Dec 2010
                  • 3912
                  Did you try use it flipped - set for AGM but on a flooded battery, set to FLOODED and use on AGM?
                  The voltage verses state-of-charge chart in has small differences, if it's correct in the firmware. I might have a messed up flooded battery table.
                  • CapLeaker
                    Leaking Member
                    • Dec 2014
                    • 8352
                    Yes, I did that. That’s why I think it was something wrong with the sensing or the firmware, The firmware version is 1.0 after all.
                      • 31303
                      maybe there is new firmware
                      https://www.anceltech.com
                      • CapLeaker
                        Leaking Member
                        • Dec 2014
                        • 8352
                        There is no firmware for that thing that I can find.
                        • carrzkiss
                          Cyberpower cps1500avr not charging batteries
                          by carrzkiss
                          Hello, all.
                          Cyberpower Battery Backup Unit.
                          I bought two new ML18-12 batteries through Amazon (They have already refunded my money for the two batteries as we thought the batteries might have been bad.)
                          When I got them in, they were not fully charged. I connected them to the UPS and waited 24 hours before connecting any networking equipment.
                          In parallel, they read 24v, but within 24 hours, the meter on the front of the unit dropped from 4 to 3 bars on the battery charge indicator.
                          Checking the voltage, it was down to 22v.
                          I quickly removed everything...
                          06-15-2024, 02:10 PM
                        • howardc64
                          Where do repair shops buy MB replacement batteries?
                          by howardc64
                          Order my parts from mobilesentrix.com and iPhone batteries have been excellent. Recently got 3x bad A1534 (2015) batteries. All would work until ~30-40+% and drop to < 10% instantly. Typical sign of cheap batteries.
                          Perhaps the less popular A1534 model's aftermarket batteries are more source limited. Just find it surprising quality from mobilesentrix (usually fairly high quality aftermarket parts) have been so poor.
                          BTW, this isn't the only defective parts I've had from mobilesentrix. Amongst others including iPad Air touch screen and A1989 touch bar (display was...
                          07-25-2024, 10:42 AM
                        • Astonished
                          Fixing the Charge Circuit of the Batteries of the DC Motor
                          by Astonished
                          Hi friends of electronics
                          What you see in the video and pictures attached is the circuit for charging the batteries of a DC motor.
                          The problem is that this circuit cannot charge the batteries (3 1800mAH NiMH batteries) any more. When the circuit was OK, its green LEDs lit up one at a time to show that the batteries have charged more. But now that the circuit is flawed, LEDs light up as you see in the video and at the same time successive beeps are heard.
                          Please help me fix this circuit.
                          (the datasheet of the IC: https://pdf.datasheet.live/28...
                          01-28-2025, 06:24 AM
                        • davidebaldini
                          UPS ruins batteries every three months
                          by davidebaldini
                          Problem description:
                          My UPS requires new batteries every ~3 months; in this time frame, an average of about 5 to 10 power flickers or short power interruptions (< 2 minutes) occur. After an average of 3 months, a new pair of batteries begins to fail to keep the UPS up during any flicker or power interruption. The load it powers is a single computer/workstation running 24/7 with a continuous consumption between 200W to 300W.
                          UPS model:
                          The Atlantis 1001 is a non-inexpensive (~120€ back then) home/office offline UPS, rated 1000VA, 600W, designed for two 7Ah...
                          10-02-2019, 06:19 AM
                          Here is a good used source for 18650 batteries
                          Here is a website I have ordered from before and the results that they claim are correct from what I have seen from the batteries I have bought from them
                          BatteryHookUp.com
                          https://batteryhookup.com/collection...odem-batteries
                          I have test about 5 battery packs ( out of 15 battery packs I bought) and have had very good results and so far have not found any bad cells
                          I have also bought these battery packs before on EBay and they are a good source for a battery case that holds 18650 batteries however...
                          06-25-2021, 05:05 AM
