Pc PIC16F877A-I/P DIP-40
  • olymbou
    • Mar 2014
    • 30
    • lar
    hi to everyone . i have a board from a viessmann gas heater and it has a Microcontroller - Microchip Pc PIC16F877A-I/P DIP-40 and i whant to buy anather one , do i have to programe it or is it programed. thanks john.
    • 31117
    Re: Pc PIC16F877A-I/P DIP-40
    you have to program it,
    and obviously you need the hex file first.
    the original is probably protected btw, so dont expect to read the code from it.
    • ben7
      Capaholic
      • Jan 2011
      • 4059
      Yes you will very likely have to program it again.
      You MIGHT be able to get one pre-programmed, but I don't think you will, unless you take it out of another similar unit that had a different failure.
      Muh-soggy-knee
      • olymbou
        • Mar 2014
        • 30
        • lar
        do they get dameged or unprogramed when they are on in use .i checket everything on the board and did not find nothing (open or closd or burnd )
        • mariushm
          • May 2011
          • 3799
          They don't usually get unprogrammed, flash memory inside has very long retention (decades).
          It's possible the chip could be damaged if something connected to it failed, but otherwise they shouldn't just fail all of the sudden.
          It's most likely the internal memory is protected (you can't read the hex data from it) so even if you buy a spare mcu or request one as a sample (it's old, almost obsolete so made in small quantity, therefore expensive) you'd still need the code to upload in it and a programmer.
          I have a programmer and I could flash one for you but again.. you need the code in the first place.
            • 31117
            it's not rare or expensive - it's worth a few Euro and easy to get in any quantity.
            but the code is the prooblem.
            • mariushm
              • May 2011
              • 3799
              I don't want to check again, but it was about 5-6 dollars on microchip's own site. It's 6$ on Digikey: http://www.digikey.com/product-detai...%2FP-ND/446143
              They don't even recommend this one for new designs, the 887 is recommended.. which has very minor differences and costs only 2.65$ on Digikey.
              You can get more powerful PIC chips for that money, for example you can get pic18f4321 at 3.2$ when getting 10, or 3$ when getting 25.
              With 3.4$ (10 quantity) you get get pic18f4550 with usb support, 48mhz, the works... much more powerful and more user friendly (better architecture for C)
              • Agent24
                I see dead caps
                • Oct 2007
                • 4992
                • New Zealand
                Check the obvious - does the PIC have all the power supplies present and correct? If it has a crystal or other clock source check that its functioning.
                -David VanHorn
                • conghuyms
                  EC Microchip MEC1416-NU pls help me
                  by conghuyms
                  I have a Dell G7 motherboard, model LA-E993P DDK51, which has lost the +3VALW power rail. Upon inspection, I found that the EC, model MEC1416-NU, is shorted. I need to replace it with a new chip, but I am not sure whether the new EC needs to be reprogrammed. Please help me. Thank you very much...
                  08-14-2025, 08:51 PM
                • Donny2derby
                  PIC 16F1937 microchip
                  by Donny2derby
                  Hi all. Hoping someone can help. There is an oil filled heater at work that is not running. The pump that fires the oil is not kicking in.
                  I've taken the PCB out the panel and found a board that is marked IPD-0018-E
                  It's receiving 230v ac and the output relay has 5v DC present. The various diodes and resistors etc all check out ok. The only thing seemingly left is the IC labelled as PIC 16F1937.
                  My question would be. How would I know this is the component causing the issue/how do I test? And should I simply order one and replace it? Or does it need programming...
                  01-29-2025, 08:41 AM
                • pcservised
                  EC Microchip ME17xx - what programmer could be used
                  by pcservised
                  Hello guys,
                  Wondering if someone know - EC MEC1723 (on new Lenovo series) - is it programmable? Which programmer could be used? RT809F can handle it? If not, any other can?
                  I did not find any useful information on the internet. I will appericiate any help.
                  thanks a lot...
                  11-29-2023, 12:02 PM
                • makar303
                  Aorus 15p xc
                  by makar303
                  Hello. I'm experiencing an issue with my Aorus 15p xc laptop.
                  The motherboard is GA-RX5LXC.
                  The problem I'm encountering is that the laptop sometimes fails to power on, and it appears that a protective mechanism is being triggered.
                  I've observed that while the laptop is in operation, the EDP_U8 microchip (I've included a photo) heats up significantly, reaching temperatures of 75-80 degrees Celsius.
                  However, when I disconnect the LCD from the motherboard, the EDP_U8 microchip doesn't heat up. I've conducted power supply measurements with the screen disconnected....
                  08-19-2023, 03:14 PM
                • Fernon@Repair
                  Gigabyte h310m s2h rev 1.1 Keep Restart solution pls
                  by Fernon@Repair
                  Gigabyte h310m s2h rev 1.1 motherboard come bios screen and keep restarting .sometime 2 3 times fan spring and off after come bios screen . some time working 15 to 30 minutes .
                  I allready checked
                  VCCPLL voltage ok
                  VCCIO Voltage ok
                  VCCIO Enable ok
                  VCCSA Voltage Ok
                  VCCSA Enable Ok
                  VRM IC voltages ok
                  Replaced VRM IC
                  Replaced LM358 ic
                  Re programed Bios
                  But sometime motherboard working 20 30 minutes and restarting ......sometime have fan spring and off error ..........anyone have solution...
                  07-08-2025, 10:16 AM
