PIC 16F1937 microchip
  • Donny2derby
    • Apr 2023
    • 228
    • Uk
    Hi all. Hoping someone can help. There is an oil filled heater at work that is not running. The pump that fires the oil is not kicking in.
    I've taken the PCB out the panel and found a board that is marked IPD-0018-E
    It's receiving 230v ac and the output relay has 5v DC present. The various diodes and resistors etc all check out ok. The only thing seemingly left is the IC labelled as PIC 16F1937.
    My question would be. How would I know this is the component causing the issue/how do I test? And should I simply order one and replace it? Or does it need programming out the box or ready to run? My limited knowledge of IC's leads me to think this would have to be flashed with the old one?
    Any help appreciated.
    Gareth.
    • 31294
    so is the heater and pump in parallel if it only has one relay?
    does this thing have a display or any lights on it?
    it could be the relay or relay driver - hopefully.
    because the PIC has software in it.
    • Donny2derby
      • Apr 2023
      • 228
      • Uk
      Apologies for the delay in getting back to you stj. I was working nights last weekend. On second inspection it does appear to be the relay as there’s no 5v DC output from it. A new one has been ordered and is on a slow boat from china as we speak! I’ll let you know the outcome.
      • CoinCoin88
        Garage door RX unit (Cardin S38C) does not short relay to send opening signal
        by CoinCoin88
        I'm turning to the Badcaps community to help me troubleshoot the radio Rx card from my (old) garage door opener. While I could just ditch that card and replace the whole system, I first would like to understand "why" it suddenly stopped working, because that's just how I am wired...!
        Some basics: the receiver works on a 30.875 Mhz frequency. Yes, I'm aware this is not in use anymore in a looot of places. It does not use any rolling code, it's just a regular dip-switch code that you have to set up on both the receiver and transmitter. The receiver...
        09-15-2025, 03:36 AM
      • edugimeno
        Vaillant 242 Gas Water heater. Shortcut in board anc compatibility with model 282
        by edugimeno
        Hi!!
        Yesterday I was installing a new Wifi thermostat for my domestic gas water heater model Vaillant 242/2-3, and accidentlly one wire from mains touched one wire from the thermostat output contacts. This shut off the heater so I finished installing the thermostat and then went out to check the heater
        I found one fuse blown (T2 250V). Replaced it with another equivalent fuse and it blew right away. I measured L-N in mains input and I sometimes got 4K but sometimes, not sure why, I got 100 Ohm...
        At a certain point, moving stuff around, I put all wires back in place and...
        03-24-2024, 02:31 PM
      • JuniperSprouts
        Deep Well Pump Control Box - Start & Run Capacitors & Relay - CB20412CR
        by JuniperSprouts
        Trying to help a small hospital in Haiti...
        Is it possible to test the relay without it being hooked up to the pump motor? It is the normal 5-1-2 configuration, as far as I understand it.
        Any tips for testing large start/run capacitors of this size and nature?...
        02-22-2023, 08:48 AM
      • madan1
        Diesel heater emergency power supply / poor man's UPS
        by madan1
        Hello everyone.
        Some background - I have one of those chinese diesel heaters, which I'm using to heat a garage. Probably most of you are familiar with that units, but here is some basic info - the main heater body is enclosed with the motherboard+sensors unit inside a plastic case. The heater has a glow plug, that works only when the unit is starting (start the fire in the burner) and stopping (make sure to completely burn the fuel inside the burner) and two fans on a single motor. One fan is used to push fresh air in the burner, the other is used to push cold air in the case and...
        12-18-2022, 08:05 PM
      • edugimeno
        Repairing a ENERTRES Biomass BI-650 heater
        by edugimeno
        Hi all!
        A friend asked me to repair his biomass (pellet) heater. This heater has a pellet feeder powered by a relay that's not switching anymore
        I measured the voltage at the relay coil socket while entering the individual tests procedures and it has 6-7v while the relay is NOT on the socket, and drops to 0v when the relay is plugged in the socket, like the source is providing nearly 0 mA. I measured the relay coil and it is correct and not shorted so the issue is in the board, fed no amps to this output
        I checked the board at home and this output is driven by an...
        07-28-2025, 04:32 AM
