PS5 disk drive not working
+ More Options
Posts
  • bogosort
    • May 2022
    • 78
    I am trying to diagnose a PS5’s disk drive that is not working. At first, I found a shorted capacitor. However, after removing it, I cannot find any other short but it still is non working. I measured the voltage at this place (see photo) but there’s only 12.11v at one pin. Other pins all show varying voltage between 0 and 50mV. (Constantly changing)
    Any idea?
  • bogosort
    • May 2022
    • 78
    Is it possible that the component (the one with 5 pins) is bad? If so, anyone can identify it? It says A8-P1P on top of it.
    • bogosort
      • May 2022
      • 78
      Anyone?
      • lotas
        • Jan 2016
        • 4539
        • Russia
        Richtek RT8008-18P
        • lotas
          • Jan 2016
          • 4539
          • Russia
          RT8008
          • bogosort
            • May 2022
            • 78
            Thank you. Based on the data sheet you provided, it implies that there's 12v on the EN pin only. This seems strange. Also, the ground doesn't seem to be at the same place on the board vs the data sheet. I'll have to investigate further
            edit: ground is at the right place
            • lotas
              • Jan 2016
              • 4539
              • Russia
              Remove the chip and look where the 4 pin (VIN) goes.
              Yes, and the input voltage exceeds (your input is 12V), but it looks like it’s not.
              • lotas
                • Jan 2016
                • 4539
                • Russia
                Rather, your pinout, look here, maybe you will find yours, look for the markings (A8-xxx) and the body.
                Or do you have (A8=xxx)?​
                  • 30977
                  are you actually getting 5v and 12v going in?
                  • Mommotexx
                    • Mar 2018
                    • 10
                    • Norway
                    Check diode readings on this component, and come back to us. I will check a working one
                    • bogosort
                      • May 2022
                      • 78
                      It does look like A8=XXX, hard to tell
                      I am only getting the 12V
                      Here are the diode readings.
                      • lotas
                        • Jan 2016
                        • 4539
                        • Russia
                        So where are these 12v?, which are supplied if there is no power supplied to the input, and accordingly there will be nothing at the output.
                        ​​​​​​Is there some tension here?
                        • bogosort
                          • May 2022
                          • 78
                          The tension at the point you mention is 12.09v
                          • bogosort
                            • May 2022
                            • 78
                            Sorry for the double post, but I’d like to add that the shorted component that I removed was there (see photo). Could it be the reason it is not working? I thought it was only a capacitor and that it could work without replacing it. Can anyone confirm the component that was in this location?
                            • lotas
                              • Jan 2016
                              • 4539
                              • Russia
                              It’s not clear, if at this point you have 12.09v, then why on 1 pin. you have 0.668v when it should be 12v?
                              • Mommotexx
                                • Mar 2018
                                • 10
                                • Norway
                                Diode reading looks good compared to mine. The component you're missing is indeed a capacitor, and shouldn't be necessary for testing
                                • Mommotexx
                                  • Mar 2018
                                  • 10
                                  • Norway
                                  Because this is a diode mode measurement, and not voltage measurement
                                  • bogosort
                                    • May 2022
                                    • 78
                                    Thank you for confirming. Could it be that the MAIN motherboard should be supplying another voltage, other than the 12v? I checked everywhere else on the disk drive board and all I can find is the same 12v at its source
                                    • lotas
                                      • Jan 2016
                                      • 4539
                                      • Russia
                                      In order for voltage to appear at the output (pin 6) of this LDO, the controller must send a command (voltage) to turn it on, this is to the 3-pin EN (turn on).
                                      • Croupier
                                        • Mar 2021
                                        Pretty sure there should be 5v and 12v supplied to the disc drive daughter board.
                                        • reformatt
                                          Intel iMacs, 3rd party SSD failures and Fusion setups
                                          by reformatt
                                          I thought I'd throw out some of my personal experiences in the last 12 months with Intel iMacs, 2.5" SATA SSD drives and Fusion drive data recoveries.
                                          As a backgrounder, Apple never fitted a 2.5" SSD's to these iMacs. Apple's SSD option was a system of 32GB NVMe blade drive (NGFF connector) and Seagate 1TB 2.5" HDD, married together in software to become a Fusion drive. Non Fusion systems have just the 1TB Seagate HDD.
                                          So, the most common reason an iMac comes across my bench is because it's either ridiculously slow, or it fails to boot at all. The most...
                                          12-18-2024, 10:34 PM
                                        • eccerr0r
                                          It's 2025: do you know where your 5¼" floppy drives are?
                                          by eccerr0r
                                          Oh wow.
                                          As in the other thread I was trying to revive/re-bootstrap an old Apple IIe and wasn't successful reading or writing any disk. Both drives behave similarly.
                                          Then I was wondering, what about my PC floppy drives? I have a HH 5¼" HD drive and a combo 5¼+3½ drive. I tried formatting the disk that wouldn't work in the Apple and it didn't work in the PC either!
                                          Then I tried a HD 5.25 disk ... it won't even touch the disk either! Just like the Apple DD disk, "Not Ready!"
                                          Weird. Seems the PC drive is having trouble clamping...
                                          07-07-2025, 12:49 AM
                                        • DynaxSC
                                          ASUS ROG STRIX B550-I GAMING - M.2_2 port not working correctly with SAMSUNG SSD980 1TB NVME SSD
                                          by DynaxSC
                                          I have an really very weired issue with ASUS ROG STRIX B550-I GAMING.
                                          Some NVME (PCIe) SSD's are not working correctly in the second M.2 socket. An example of it is the SAMSUNG SSD980 1TB NVME SSD.
                                          Some other NVME (I have only smaller ones) disk do work without any problem, also SAMSUNG disks, eg an MZVPV128HDGM-0000.
                                          The behaviour is also really very strange, i.e.:
                                          • The disk shows always up in BIOS - so it is recognized, so far so good
                                          • POST-ing with this disk with fresh Windows 24H2 installation (done in the M.2_1 socket) in the M.2_2 socket
                                          02-23-2025, 01:33 PM
                                        • erbuzzicker
                                          DVD drive not working
                                          by erbuzzicker
                                          Hello, I have an HP 15-P013NL with motherboard DAY11AMB6E0. Problem is that DVD drive has not been detected in device manager and so not working. Pin 8 (ZERO_ODD_DP#) in the image below is 0v both optical drive connected and not. R553 (image 2) is 0v on optical drive side and 3.3v on the PCH side, both with optical drive connected and not. I tried to replace DVD drive and DVD drive connector with no results, so i suppose it's a problem on the motherboard. Can you please help me to understand more?...
                                          05-27-2021, 11:42 AM
                                          HP xw4550 Workstation Specification for Upgrade or Repair
                                          This specification for the HP xw4550 Workstation can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the xw4550 Workstation boardview and xw4550 Workstation schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                                          09-12-2024, 03:36 PM
