Xbox 360 slim(corona V2):A cap by the psu is dented,I need help identifying it
  • tronik25
    • Dec 2013
    • 15
    I took a chance & bought a slim listed as parts/repair off ebay for $37 shipped.
    The seal didn't appear to be broken or tampered with.I noticed the exaust vent had a couple small cracks in it.The console powered up with no video & audio,showed green then after 3-5 sec went red.
    When I was thinking about reflowing the southbridge & xcgpu,I thought I should do the obvious & look really hard for any physical damage.This cap is all I found that had any damage.
    I turned the console on probably 26 times total,3 times it came on & froze on the logo screen with a graphics glitch & once it got to the dashboard before doing the same.
    From top to bottom the cap reads:
    FP
    14Pe
    471
    16
    In the last pic,its the one closest to the power cord/psu adapter.Says 12po main right above the bent cap.I googled but couldn't find this cap.Althought its not bent very bad,imo it could still be enough to mess things up.Everything else looks fine on the board.
  • mariushm
    • May 2011
    • 3799
    Re: Xbox 360 slim(corona V2):A cap by the psu is dented,I need help identifying it
    Nichicon FP (Functional Polymer)
    470 uF (471 = 47 x 10 to the power of 1) , 16v
    The exact series can be determined by the 14Pe code but it doesn't matter. Just measure the diameter and pick one of the FPCAP series or Nichicon polymer series and they'll be suitable.
    For example any one of these will work fine, provided they'll fit in the area you have (the diameter):
    http://www.digikey.com/product-detai...4-1-ND/3768618
    http://www.digikey.com/product-detai...019-ND/1136109
    http://www.digikey.com/product-detai...114-ND/1662500
    http://www.digikey.com/product-detai...4-1-ND/2239227
    • tronik25
      • Dec 2013
      • 15
      Thanks mariushm!I tried to find the exact model & measurements but couldn't find them.It sucks because I don't have a mm to spare in height in this area.A hdd port casing rests right over these.I will try & look more.I seen a fujistu cap on ebay that looked pretty close but it wasent the same code.
      • gabri2211
        Xbox Series X Console Won't Turn On - Broken Nexus Connector on Mainboard
        by gabri2211
        Inside the console there is a small circuit board (see photo) that contains the main power switch, the one on the front.
        This circuit board connects to a 10-pin flat cable called NEXUS that terminates on the motherboard.
        This NEXUS connector broke.
        Can anyone tell me, while waiting for a replacement, if it's possible to turn on the Xbox by disconnecting this circuit board and making some modifications (like adding a small power button) on the motherboard?
        The Xbox has a power supply that provides 12 volts on all outputs, so the power...
        07-28-2025, 07:13 PM
      • TMTGTR
        An Xbox One PSU Odyssey
        by TMTGTR
        Firstly I am not a tech. You guys may see mistakes or oversights in my methods so don't be bashful and feel free to post corrections/opinions.
        =>Background:
        I bought my son a used Xbox One original model: A12-220N1A Rev: 02 with original PSU & 2 controllers 7 years ago. I “modded” the unit placing a 4.5” 12V exhaust fan with a 9v wall wart adapter on top of the vent/fan of the unit. And plugged the Xbox PSU into a Tripplite LTR-600 voltage regulator. Also connected to the Tripplite are a 275w computer tower, an Xbox 360 PSU and a Westinghouse 52” LED TV. ...
        06-17-2022, 05:40 PM
        HP EliteDesk 800 G3 + ProDisplay P240va + Seagate Game Drive for Xbox 2TB Green EliteDesk 800 i5-7500 Specification for Upgrade or Repair
        This specification for the HP EliteDesk 800 G3 + ProDisplay P240va + Seagate Game Drive for Xbox 2TB Green can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the EliteDesk 800 G3 + ProDisplay P240va + Seagate Game Drive for Xbox 2TB Green boardview and EliteDesk 800 G3 + ProDisplay P240va + Seagate Game Drive for Xbox 2TB Green schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively...
        09-12-2024, 02:00 PM
      • grimacelord
        Xbox One S - 12V Rail Short - Q9F1 Keeps Blowing
        by grimacelord
        Have an Xbox One S here that has a short on the 12V power rail. There is no power, beep, or partial fan spin when connecting power cable.
        After diagnosing with thermal camera, Q9F1 MOSFET (NTTFS4C50N) is getting hot. When I remove this MOSFET, the short on the 12V rail disappears.
        I first replaced Q9F1 with one from a donor board and then partially reassembled the Xbox to test. When I plugged the power cord in, I got a partial fan spin and I thought I had fixed it, but unfortunately, the Xbox still did not power on. So I then disassembled the Xbox...
        10-24-2024, 12:31 PM
      • Stevedb
        Boardview xbox 360 , xbox fat , xbox one x and xbox one s
        by Stevedb
        Hi all
        I will share the boardviews i found internet from the xbox 360 , xbox fat and xbox one x and xbox one s
        Pasw netcomchetumal.
        Enjoy it.
        Greetings Steve
        From Belgium...
        04-04-2023, 12:42 AM
