Sony PS3
  • dj_ricoh
    • 2073
    Sony PS3
    hy guys
    i was running away from those consoles but fate just bit my ass and give me one to fix.
    so my first one but i don`t have the luxury of reballing and i saw many ppl haveing problems with those tokin capacitor(is there a topic how to measure them?)
    i don`t even know witch one its the gpu
    Those tokin fail like in the notebooks?
    any advice where to start its welcome TY
  • Mad_Professor
    A Mech Warrior
    • Feb 2011
    • 1587
    Re: Sony PS3
    Originally posted by dj_ricoh
    hy guys
    Yellow light of death? or any light of death?
    • dj_ricoh
      • 2073
      Re: Sony PS3
      ty for reply no no no. its green and it stay like that but nothing on screen.
      those two cpu or gpu get hot
      when i press the sensor from red it goes green but 0
      • Mad_Professor
        A Mech Warrior
        • Feb 2011
        • 1587
        Re: Sony PS3
        did you try other video inputs? I know on my (now dead) PS3 to switch from HDMI to component it will do just that, leaving the hdmi dark and component live and there is no way to switch it back because you can't see what you are doing on the screen unless you connect the component and tell it to switch back.
        • dj_ricoh
          • 2073
          Re: Sony PS3
          ty for reply ,i got only a tv with hdmi where the tech guys that repairs cellphones is.
          today i ordered a bios programmer ; can i rewrite the bios on it?
          i`ll go in the storege room they say they got a lot of ps3 dead i wanna see some values of those nec-tokin capacitor maybe its replated to those
          • Yatti420
            • Mar 2008
            • 130
            Re: Sony PS3
            Hold the power button.. I believe that also resets video mode to whatever you are using.. I don't think you will be able to re-write the bios..
            All polies in a PS3? No need for recap? These PS3s are a thousand times better then a 360 build wise..
            • dj_ricoh
              • 2073
              Re: Sony PS3
              i did ask if someone knows how to mesasure those nec-tokin; they have the same value like the ones from the notebook... i have a toshiba with a tokin i`ll open it so i can see the value on it.
              "polies" sry i don`t understand
              yes i did try that reset by holding nothing
              • trebo
                • 514
                • Wales, UK
                Re: Sony PS3
                check this out, seems to be 1200uf
                  master hoarder
                  • May 2008
                  • 12170
                  • Bulgaria
                  Re: Sony PS3
                  Since you have nothing else but HDMI to test with, check the HDMI connector on the PS3 to make sure it isn't damaged. Also try a different HDMI cable if you haven't done so.
                  I know these seem like simple stuff, but I've tried to repair "complicated" problems that didn't even exist in the first place.
                  I strongly disagree with this statement.
                  The 360s are built wonderfully. Microsoft just f**ked up the cooling part and that's why so many of them die/died.
                  PS3's on the other hand are horrible. Not only are the boards really hard to work on (due to super-thick ground planes and tiny SMD pads), but the dammned things never really give you anything more than a YLOD if something is wrong. On one occasion, my friend (who has a repair shop) tried removing all (or nearly all) of the BGA chips, and the stupid thing still gave him a YLOD. The Xbox 360 at least gives you a secondary code that is actually useful more than half of the time.
                  • dj_ricoh
                    • 2073
                    Re: Sony PS3
                    ty for the reply he gave me the key so i can take as many ps3 and i will dig to find some ports and change them .
                    i`ll still measure some nec-tokin caps jsut in case i see some other values maybe i get lucky with one
                    ty
                    • DJduck
                      • Dec 2012
                      • 229
                      • Estonia
                      Re: Sony PS3
                      I agree, 360s are actually well built, they use good quality parts, all top tier capacitors and stuff. And they are much easier to work on. Cooling is crap, yes, but its still somewhat better than PS3 because the PS3 is so packed inside that you have no room to work on the heat management but the x360 has some room inside so you can add bigger heatsinks or more fans. The x360 is also cheaper, at least here in Estonia.
                      I can put text here?!
                      • DJduck
                        • Dec 2012
                        • 229
                        • Estonia
                        Re: Sony PS3
                        ty
                        Wait, you can get free PS3s? lel, take a lot of them. Keep some boards and reflow them with flux and keep em'. If on dies just put another one in. Also look for boards that have visually damaged components, that way you know for sure what is wrong with them and they are an easier fix. And power all of them up, maybe one of them have some simple issue like a broken optical drive, an even easier fix.
                        • dj_ricoh
                          • 2073
                          Re: Sony PS3
                          no no no they all got problems similar like this.
                          its like a faulty/spare depo
                          i`ll open today 3 ps3 maybe i will find 3 differant results
                          • Sparks88
                            • Sep 2011
                            • 110
                            Re: Sony PS3
                            when you do a global reset (press down and hold eject and power buttons!!) then plug in the power lead and it will switch on and fan will run at max for a few seconds, keep holding buttons down for a few more seconds, unit is now at default video out and deck is reset and if you have a stuck disc it will eject it, no hdmi output until its enabled in menu so if you dont have a composite video input or a sony ps lead with a scart plug to test it on a tv then you will never get video
                            • dj_ricoh
                              • 2073
                              Re: Sony PS3
                              i talk to my friend who gave me this told me there is a difference from no signal and black screen .
                              i froze :| aww now what :-??
                              • Mad_Professor
                                A Mech Warrior
                                • Feb 2011
                                • 1587
                                Re: Sony PS3
                                He's right, when I said hdmi stays dark, I meant it doesn't put out a signal.
                                • dj_ricoh
                                  • 2073
                                  Re: Sony PS3
                                  ty for reply .
                                  do you mean that i should connect with all the ports then reset the console? like holding the power until it beeps ty
                                  • Carlos#2003%
                                    Schematic de una Sony VAIO PCG-41217u, Sony VPCSB45FL (MBX-237), 1p-0117j01-a012 mbx-237.
                                    by Carlos#2003%
                                    Buenas mi nombre es carlos me uni al foro porque estoy buscando el schematic de una sony vaio pcg-41217u otras formas de escribirlo son 1p-0117j01-a012 mbx-237 numero de placa revision 1.2 o Sony VPCSB (MBX-237), en fin me gustaria y ayudaria un monton si alguien me puede dar dichi svhematic para hacer las mediciones de una laptop de la mencionada anteriormente(Sony VAIO PCG-41217U) con el fin de repararla dejo de funcionar solo prende el led de la bateria al pulsar el boton de power el disco empiesa a hacer ruido de actividad pero los leds del frontas no reflejan acividad y no enciende la pantalla....
                                    02-15-2024, 07:52 PM
                                  • dkneyle
                                    Sony KDL-46HX850 Can't upgrade/update firmware
                                    by dkneyle
                                    Diagnosed this TV as having a failed main board which I've replaced with one from a KDL 55HX850. They are (supposedly) the same board.
                                    Being 'Smart TV' it requires a firmware reboot when you swap out boards such as T-Con or main board. It starts with a black screen and flashing yellow and green LEDS, indicating it needs that firmware boot. The procedure described all over the web is to put the software into the root directory of a FAT32 formatted USB drive and it should load that up once plugged into USB1 port. But not for me. I can see the LED on the USB chip flash for about...
                                    09-25-2024, 10:44 PM
                                    Sony VAIO SVF11N1L2E Hybrid (2-in-1) Fit multi-flip Specification for Upgrade or Repair
                                    This specification for the Sony VAIO SVF11N1L2E Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the SVF11N1L2E boardview and SVF11N1L2E schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                                    09-06-2024, 05:27 AM
                                    Sony VAIO Duo 11 Hybrid (2-in-1) Duo 11 Specification for Upgrade or Repair
                                    This specification for the Sony VAIO Duo 11 Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Duo 11 boardview and Duo 11 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Sony VAIO...
                                    09-06-2024, 05:30 AM
                                    Sony VAIO VPCM12M1E/W Netbook Specification for Upgrade or Repair
                                    This specification for the Sony VAIO VPCM12M1E/W Netbook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the VAIO VPCM12M1E/W boardview and VAIO VPCM12M1E/W schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
