Polymoog 280a bad capacitors
  • theokretes
    • Jul 2013
    • 49
    When my polymoog arrived, there were a few problems.
    What's a "polymoog"? It's a pseudo-polyphonic analog synthesizer comprising of 71 keys. They're essentially... a glorified string synthesizer; but capable of many ambient drones, super hyperactive zinging strings, aaand, mellow due to the single filter. Some deride these as being unreliable, all I have to say is: OF COURSE something is going to have problems if it has electrolytic and tantalum capacitors from 1970 without ever being replaced
    #1 tantalum capacitors were cut out of the circuit due to shorting
    #2 the electrolytic capacitors are butt-ancient
    #3 the previous "tech" that worked on it put nasty electrolytics in place of where actual tantalums should have been.
    #4 LEDs were mismatched
    The first hurdle is opening this thing, which I always dislike doing :p
    I ended up tackling the power supply last, but I had a DOA diode which caused the 5v rail to be almost nonexistent. Thankfully the service manual (which is very very long and hard to read from ADD), brought me to the right spot.
    Nichicon VX axials, along with vishay-sprague. Finding those capacitors is noooot fun at all. The original chemicons should never be looked at again. The terminals had corrosion: at which point the chemicon is telling you that it doesn't want to live anymore.
    Upon taking a look at the reference oscillator board, you'll see a cut tantalum. Along with some Fairchild UA726HC dual-transistormahoozits. These transistormahoozits are very important. If they decide to die, sourcing genuine ones is very difficult. Most NOS ones are about $80 apiece, they will ALWAYS have gold legs if genuine.
    So here's what happened after I went through all of the tantalums:
    There were also other electroyltics I went through.
    It's doing much better now. The only problem is that the 5v rail is at 6v and REQUIRES 6v to produce any sound. I recently found out that this is due to failing opamps. I'll go through those whenever I get time and/or feel like revisiting this thing.
    Unfortunately I don't have any more board shots, I wish I took more as I went through it. Oh well. It looks very nice now, after I went through it.
  • mockingbird
    • Dec 2008
    • 5484
    Re: Polymoog 280a bad capacitors
    You might want to have a look at this Youtube Channel... Specifically the fascinating series of videos documenting the rebuild of a very rare Yamaha CS-80. The reason I'm linking it is because I remembered him replacing even old plastic caps...
    • kc8adu
      • Nov 2003
      • 8832
      • U.S.A!
      good save!
      i have been seeing lots of vintage synths for repair lately.
      folks tend to keep them after they die as they paid a bunch for them new.
      one day they dust it off and see if it can be repaired.all the local musical instrument places send them to me.in one week i got 5 access "virus" units in!
      kinda rare.unless fried by lightning they usually live with caps and deoxit in pots and switches.
      • Perry Babin
        Tantalum Capacitors and Heat Sensitivity
        by Perry Babin
        I remember reading somewhere, years back, that tantalum capacitors are sensitive to heating on their negative terminals and using more than a minimal amount of heat could result in damage. Is this/was this ever true?
        04-03-2024, 05:28 PM
      • dragon3x
        by dragon3x
        power on.
        Here are some examples :
        switching supply area).
        than 6.3 V.)
        03-21-2025, 02:46 PM
      • slybunda
        AA and AAA battery charger capacitors?
        by slybunda
        hey all, iv got my favourite battery charger here which iv had for many years probably 15 years now or maybe even more. it still works good but thought id open it up to clean the dust out of it, lots of dust inside but now its clean and noticed 4 capacitors inside it and wondered if i should replace them.
        it has inside:
        2 x 47uf 16v caps 105c branded as Su'scon (lol sounds sus to me)
        2 x 470uf 16v LZ105c branded as G.Luxon
        not heard of these brands are they any good?
        iv attached photos of the charger and the board inside for an idea on the type of...
        12-24-2023, 04:41 AM
        After all of...
        07-13-2024, 08:14 PM
      • Cama
        Solar Inverter - SMH-II - 2 missing capacitors
        by Cama
        I need help to find the value of 2 missing capacitors ( C102 and C117) on my Easun SMH-II mainboard (solar hybrid inverter). I circled it in red on the close-up picture. The 2 old capacitors are completely missing, so I have no reference. Does anyone have this board and can tell me the value or make an educated guess based on the location ?
        My model is : EASUN SMH-II 7 KW
        Mother Board : P/N 18947-002401250250
        Maybe the EASUN SMH-II 4.2 KW have the same capacitors
        Thank you...
        09-12-2025, 02:50 AM
