In-depth Xbox Questions
  • llamaboy
    • Nov 2010
    I'll be fixing a lot of Xbox 360's soon. I am in the process of doing an Atari 2600 fix/mod; and it's cake. But the 360 is, for the most part, a crippled semi-modern computer; the tolerances on part selection is a lot tighter. No Nichicon VX's here (even though some 360's have them).
    I've seen a few Xbox 360 questions on here, and they've all pretty much focused on the electrolytic capacitors and polymer capacitors. Those I'm replacing with UCC KY's/LXZ's, some Panny FMs, and some Nichicon Polys. But what of all the tiny little SMD ceramics?
    My main question concerns temperature coefficients.
    I know what it means, but does it make that much of a difference in this application? Is it location specific; can I use cheapo Y5Vs everywhere or use C0Gs closer to the processor and cheap out other places or...?
    Should I just avoid Y5V and worse altogether?
    Or does it care all that much as long as something is there (going by a comment I read earlier about a coupler capacitor falling off not mattering...)?
    Oh, bonus question: Tantalum. Any opinion on using it to replace electrolytics on motherboards, and what should be done if doing so (less capacitance, what to look for, etc)?
  • mockingbird
    • Dec 2008
    • 5484
    Re: In-depth Xbox Questions
    The 2700uF Rubycon MFZs you will have to replace with Nichicon HZ. That's the only thing available with the same spec.
    Regarding tantalum, I don't think you can get them high enough spec to use in the 360. Also which box are you fixing? Doesn't sound like Xeons.
    Also are you doing a clamp fix? I found the MKI method to be the best. If you want I can send you the PDF. Also the PDF specifies British dimensions. I can tell you the Home Depot P/Ns if you're interested. Will cost less than $5 for each box plus you're only widening the holes as opposed to MKI because the bolts are a bit thinner.
    • llamaboy
      • Nov 2010
      Glad I didn't order yet, I'll throw some HZs in there. I think I have a couple somewhere around here. Damn they're expensive.
      Is there a list of electrolytics on each board revision? I don't want a stack of expensive capacitors I won't use anytime soon. All of my friends have warranties (lol) and don't want to take the side panel off.
      One of the ones I'm fixing is a Core made in 2005. Old old old. The other is an old Pro, don't know just how old. The Core will probably go for sale when I'm done drilling into it and get it to go stable and keep cool for eight hours straight.
      No clamp fix yet; I want to see what I can do on my own first before ordering Xbox repair-specific stuff. Lapping or just replacing heatsinks with something that is actually to spec, new/better TIM, replacing the rear fan and adding CPU/GPU fans, drilling out a port for an intake fan on the side panel, might do a duct; probably not required due to the CPU/GPU getting their own fans. With all of these new fans, I'd like to get some that take less effort to run. No Vantec Tornado.
      Maybe a duct going to an empty fan port on the side panel from the new CPU/GPU fans. Hmm...
      Oh, that reminds me, know of any upgrades for the fan MOSFETs?
      • mockingbird
        • Dec 2008
        • 5484
        I have Xeon Pro from '06. By "Pro" I'm assuming you meant those units that came with the 20GB HDD... You will need to clamp them. Clamping and not reflowing is better than just reflowing. In fact, I didn't reflow at all and I've had mine working great for months now.
        Don't buy out all the HZ stock, leave some for me. Something tells me they're going to get rare very soon as manufacturers move to polymer for low esr applications. Even Panasonic is slowly moving their production to China. Someone at the xbox-scene forums suggested that the entire xenon MB caps are in a VRM circuit, and that you could use polymers everywhere, but that sounds like nonsense to me. If that were the case, MS would have used bumblebees throughout the board and not just near the GPU.
        Yea those sound like interesting mods, but you're wasting your time because if I was someone that wanted to buy a reliable box with manufacturer warranty, I'd just buy a slim for $199 rather than pay you a fortune for your efforts. The slims have the CPU/GPU (They're both in one die now, you know) vented from the top. I also think they fixed the solder cracking. I think they're still using lead-free but someone suggested here that even lead-free solder can be improved by adding copper to it, which I think they've done.
        • llamaboy
          • Nov 2010
          NOTE: I am going by a list of capacitors I found. If you have a definite list of what is needed for the Xenon board, please say I'm being dumb and need to get X instead.
          Yep, 20 gig, that would be it. I've been thinking; a Home Depot run is needed anyway, and I like the sound of it. Those parts would probably end up being used for something lame if I didn't put them into an Xbox (well, lamer than a 2005 computer. I'm a PC guy). Send that PDF, if you will, and the part numbers. Thank you much.
          My concern is stress on the board. Is there anything for the back of the board to more evenly distribute the stress put out by the clamp? If not, I could probably figure something out and fabricate it. MDF or plastic...hmm. Might be fun.
          Lol I wish I had enough money to buy out the whole HZ stock. Have you tried using polymers in place of the HZs, just to see what happens? Who knows, might not be as picky as imagined. More expensive now, but later...
          Pop goes the GPU! But hey, if there's one laying around to sacrifice, (I only paid $25 shipped for my broken Core) might as well give it a shot, stress-test, and see what happens.
          My efforts won't cost much, I'm going to turn the Core for maybe $100 opening bid ($75 profit is good for me). I'll throw some pretty LEDs in there somewhere, maybe put in a window and make it look pretty. It's sad aesthetics sell better than things that actually matter. Or I'll give it to the wife, so we can both play online, if I do any XBL. I like my pretty PC games and mouse/keyboard.
          Or I'll re-case it and use a PC power supply for it, and use it to experiment on. Endless possibilities!
          Fusion style, huh? Shows how old it is. Have you seen the performance reports of the combined CPU/GPUs coming out? It's good for an HP/Dell/Apple customer, I guess.
          • mockingbird
            • Dec 2008
            • 5484
            What do you mean? The new combined GPU/CPU are slower? I heard it runs on linux pretty good, being triple core and all. I wouldn't want to have to compile the kernel for that, it would be a nightmare figuring out the drivers.
            PM me your email and I'll send you MKI and part numbers. I'm not going to publicize the Home Depot parts because the last time I went some shmuk with the same ideas as me bought up all the stock and there weren't any refills on hand. I barely made it out there with enough for one box clamping.
            Yes, there is controversy regarding the MKI/III method that it merely reverses the problem (Makes the board flex concave instead of convex or whatever) but this is not true. There is one popular site selling the expensive "deluxe" clamp kit with that retention bracket, but they charge $20 for it. Not necessary in my opinion. MKIII I don't like, but MKI does eliminate the need for the bracket IMO.
            I had this discussion about the capacitors with PCBONEZ I think, he's the one that referred me to HZ. And no, you can't use polymers there, because they don't have those values in polymer. If they did, MS probably would have used them themselves.
            Yea, I also hate FPS with the Xbox controller. It's the most retarded thing I ever seen. My brother-in-law is wreaking out his guts with it on COD and thinks he's such an "expert". I informed him that if I went on those servers with a mouse and keyboard, I would wipe the floor with every single player there.
            To be honest, I would just give it to the wife (Unfortunate as it is that you have one) rather than sell it, because I personally wouldn't be able to tolerate the liability if I sold it. There's no telling how long these clamped boxes will last. Nothing short of a reball with leaded solder is a guarantee.
            • ratdude747
              Black Sheep
              • Nov 2008
              • 17136
              its called cutting corners... apple could have made the imac g5 mainboards bombproof... if they used poly caps. why not? poly's are expensive compared to lytics... and i imagine microshaft did the same. figured by the time the red ring hits, people would have already moved on... warranty's up, in comes the dough!
              just because they didn't doesn't mean the shouldn't have... it makes sense why HZ may go extint... other than cost, polys win every time compared to ultra low esr lytics. better specs and more durable... win-win.
              sigpic
              (Insert witty quote here)
              • mockingbird
                • Dec 2008
                • 5484
                No, I disagree in this case. MS had a very high failure rate on 360s, and even had to extend the warranties because of disastrously bolshevik RoHS policies.
                Look at the new slim:
                All polymers. (Yes I see those lytics near the ports. Don't worry, they won't have any stress placed upon them anytime soon)
                They redesigned the circuit so that they could use mostly polymer capacitors. They were able to do this because of the reduction and combination of the GPU/CPU die.
                They certainly didn't want those kind of premature failure rates with the huge losses they take in practically just giving away the consoles.
                Apple is a different story. Firstly Apple never used off-brand capacitors. They always stuck to the Japanese brands, they were just unaware of lousy series. Secondly, Apple has nonexistent control over some of its OEMs. That's why their PSUs use off brand capacitors. My guess is the systems CPUs fail prematurely because of the stress placed upon them by the PSUs.
                Thirdly, Apple knows who buys their products: Yuppies and stupid people. They don't have to have quality hardware, the same morons will kepp returning for their table scraps as a dog returns to its vomit.
                • ratdude747
                  Black Sheep
                  • Nov 2008
                  • 17136
                  i would not call the ROHS communist. no relation. the ussr were huge polluters...
                  misguided? yes. it was a failed concept... if they had made an exception on BGA connections, then there might have been hope.
                  now if they ever made a solder that was leadless but worked for BGA... and it was not extremely expensive... then ROHS all the way... lead bad!
                  sigpic
                  • shovenose
                    Send Doge Memes
                    • Aug 2010
                    • 6575
                    i think lead-free is great. they just need to make it work right. im sure if they try hard enough...but they wont, everything is made like shit these days
                      • 31199
                      if they span the fucking fans it wouldnt have been a problem, but some dumb fuck in marketing wanted it to make the same noise as a snes.
                      reality time, you cant have multiple cores & high end gpu rammed into a shoebox without heavy cooling!
                      • ratdude747
                        Black Sheep
                        • Nov 2008
                        • 17136
                        imagine if they made a system powered by the atom... no heat issues there... no power either
                        sigpic
                        • mockingbird
                          • Dec 2008
                          • 5484
                          Different material have different properties. Saying you don't want lead in your solder is like saying you don't want wheat in your diet. The concept is ridiculous (Anyone who says they are allergic to wheat is a liar). BGA soldering requires a malleable metal, and lead is cheap and effective. There's nothing else as practical.
                          • shovenose
                            Send Doge Memes
                            • Aug 2010
                            • 6575
                            Mockingbird, my mother (and supposdly me too but i eat wheat anyway), is very allergic to wheat...
                            Lead-free is a step in the right directin. They just have to make it work BEFORE selling stuff with lead-free solder.
                            • brethin
                              • Dec 2008
                              • 1907
                              Lead free as in paint is a good (because kids may eat the paint chips).
                              Leaded gas was much better for car engines than lead free but they removed the lead to reduce emissions.
                              Lead free electronics is the dumbest feking idea ever, noone is going to chew on a motherboard and the lead serves an important purpose.
                              Next thing you know they will ban lead fishing sinkers because some fish might swallow one and contaminate the lake.
                              • shovenose
                                Send Doge Memes
                                • Aug 2010
                                • 6575
                                um, but people (like me) touch motherboards and video cards, and then eat something, then be like, oops i just forgot to wash my hands lol. and a lifetime of that cant be healthy.
                                • mockingbird
                                  • Dec 2008
                                  • 5484
                                  It won't rub off on your hands from touching it on a motherboard. Don't forget most of the solder is tin, with only a little bit of lead in it.
                                  • ratdude747
                                    Black Sheep
                                    • Nov 2008
                                    • 17136
                                    i think the reason they want lead free solder is they do not want all the lead going into the landfill/incinerator... that WILL get into the air/groundwater... not good. hence why a lot of electronics have the non-trashcan sign on them... they do have lead solder and are unsafe to toss into the landfill. however, nobody ever follows it...
                                    hence why i think leaded BGA's should be legal but illegal to toss as hazardous waste...
                                    sigpic
                                    • tsxownz
                                      • Mar 2011
                                      to mockingbird
                                      since im new the board doesnt allow me to pm you. im interested on the parts list of the mk1 clamp solution. no risk there since i dont live in the mainland US so... i wont empty your resources
                                      • TheLaw
                                        • Jan 2011
                                        • 477
                                        How do you feel about Panasonic and others moving to China? I bought some FRs and they are from Malaysia. Is the era of Japanese caps over? HZs are almost impractical anyway with the price of polymer pretty low. They are good for certain things that polymers cant do. I just hope all the big manufacturers don't start screwing us.
                                        • TMTGTR
                                          An Xbox One PSU Odyssey
                                          by TMTGTR
                                          Firstly I am not a tech. You guys may see mistakes or oversights in my methods so don't be bashful and feel free to post corrections/opinions.
                                          =>Background:
                                          I bought my son a used Xbox One original model: A12-220N1A Rev: 02 with original PSU & 2 controllers 7 years ago. I “modded” the unit placing a 4.5” 12V exhaust fan with a 9v wall wart adapter on top of the vent/fan of the unit. And plugged the Xbox PSU into a Tripplite LTR-600 voltage regulator. Also connected to the Tripplite are a 275w computer tower, an Xbox 360 PSU and a Westinghouse 52” LED TV. ...
                                          06-17-2022, 05:40 PM
                                        • liquidzorch
                                          Xbox Series X mosfet controller questions
                                          by liquidzorch
                                          Hello. I got in an xbox series x that was taken apart to clean, then reassembled, after that, it powers on then off instantly.
                                          When pressing the on button, I have found that the two ic's that control voltage to the memio, memphy (MP2926) and cpu, gpu (MP2855) DO recieve an EN signal, and probing the pwm outputs (that go to the intellegent mosfets (MP86965)) of both of the ic's go high, but there is no PWMing (probed with oscilloscope).
                                          So the EN pin goes high, the PWM output (all of them) goes high for about half a second, then everything goes low again.
                                          07-20-2023, 02:31 PM
                                          HP EliteDesk 800 G3 + ProDisplay P240va + Seagate Game Drive for Xbox 2TB Green EliteDesk 800 i5-7500 Specification for Upgrade or Repair
                                          This specification for the HP EliteDesk 800 G3 + ProDisplay P240va + Seagate Game Drive for Xbox 2TB Green can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the EliteDesk 800 G3 + ProDisplay P240va + Seagate Game Drive for Xbox 2TB Green boardview and EliteDesk 800 G3 + ProDisplay P240va + Seagate Game Drive for Xbox 2TB Green schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively...
                                          09-12-2024, 02:00 PM
                                        • DrewPhillips
                                          Capacitor Diarrhea - Nichicon PL Series
                                          by DrewPhillips
                                          Hello All, I have on the bench a couple of PSU's which have some failed Nichicon PL series caps. They didn't "puke" their guts through the top, but instead "diarrhea'ed" corrosive brown electrolyte through the bottom, down the legs and onto the board. On one cap, the electrolyte rotted the cap right off the board leaving 2 little stubs, and also corroded a trace on the foil side.
                                          The PSU's are Power-One MAP series and are ringing-choke topology. The semiconductors have date codes in 1993. The PSU's were used in a commercial application, fan-cooled. They had failed...
                                          03-02-2025, 10:18 PM
                                        • Stevedb
                                          Boardview xbox 360 , xbox fat , xbox one x and xbox one s
                                          by Stevedb
                                          Hi all
                                          I will share the boardviews i found internet from the xbox 360 , xbox fat and xbox one x and xbox one s
                                          Pasw netcomchetumal.
                                          Enjoy it.
                                          Greetings Steve
                                          From Belgium...
                                          04-04-2023, 12:42 AM
