PS4 pro won't start, beeps on cd player
  • fab13
    • Dec 2021
    • 109
    • France
    Hello ,
    A friend of mine dropped off his PS4 pro console and it won't boot on the power button but we can hear the CD player beep.
    I can't find the solution
    Test with another new and functional power supply, I get out well the 5 Volts standby and the 12 Volts when I shunt the power supply and remains stable in 12 Volts.
    Test 3V battery bios ok and at the output terminal of the power cable power button I have 3 Volts and new cable and no trace of rust or anything. The console does not start.
    I've checked for short circuits everywhere, HDMI port, video chip, southbridge and usb port, all diodes, and in diode mode everything seems fine.
    However, I found it strange that the GPU measurement was 1.2 Ohm, which is perhaps normal for a ps4 pro console? because even with graphics cards, the GPU level is close to 1 Ohm for recent cards.
    Any idea where I can check?
    I've been working on it for 3 days :mdrsign:
  • fab13
    • Dec 2021
    • 109
    • France
    Re: PS4 pro won't start, beeps on cd player
    For your information, I found the problem: the 32kz crystal oscillator was no longer working, tested it with an oscilloscope and the console works.
    • u666sa
      HP Envy x360 13-bf0013dx (i7, 8gb) ipa32 la-m024p rev 1b short near PJ1802, type-c not switching to 19 volts
      by u666sa
      Laptop is HP Envy x360 13-bf0013dx, hp website link, it's an i7-1250U with 8 gig onboard ram.
      Platform: ipa32 la-m024p rev 1b
      Originally you'd plug power supply into it and it would take up to 1.2 amps and then drop to 200 milliamps and then go back up again to 1.2, staying all the while at 5 volts. Pressing power button would results in power LED blinking amber 3 times. 3.3 volt rail, 5.1 volt rail present, main power rail 8.8 volts. Power button test pads near EC chip 2.7 volts.
      I found a short on the other side:
      10-04-2025, 05:03 PM
    • Mcfeetroy
      Fishing bite alarm drains battery
      by Mcfeetroy
      Good day to all. The bite alarm drains 9-volt Krona batteries. Current consumption when switched on is about 50 mA. I wiped the board from oxides, I will attach a photo (on the board there is a j3y transistor and a 7533 stabilizer, the microcircuit is erased = (the 3.3-volt stabilizer heats up weakly. I replaced it, nothing changed. I unsoldered the microcircuit, the consumption disappeared. The resistance on the pins of the unsoldered microcircuit from the point clockwise is more than 2 megaohms, the 11th leg is presumably ground. I warmed up the microcircuit, the consumption does not change....
      08-01-2025, 03:52 AM
      MEDION AKOYA S15447 + ext. DVD Player Notebook Specification for Upgrade or Repair
      This specification for the MEDION AKOYA S15447 + ext. DVD Player Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the S15447 + ext. DVD Player boardview and S15447 + ext. DVD Player schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any...
      09-06-2024, 05:30 PM
    • retrorepair2
      HP Z820 Workstation 4 beeps (sometimes)
      by retrorepair2
      I've got an issue with my Z820 that I'm having trouble working out the root cause of.
      More often than not it'll turn onand fans will blast for a moment before stopping and I'll get 4 beeps that will repeat forever (at least the power light will keep flashing).
      What I can't understand is sometimes it'll just work and I can use it all day but other times it'll boot then reboot then reboot and 4 beeps for the rest of the day. Sometimes it'll work fine from cold for hours, sometimes it'll do the 4 beeps from cold.
      Another oddity is the fans. Before the 4 beeps...
      09-24-2025, 08:05 AM
    • supermattch
      HP 15dy-2021nr wont power on mystery volts
      by supermattch
      Hi everyone.
      I am diagnosing my personal laptop, because it wont power on and no leds light up.
      At the dc-in there are 8 pins, 1 and 2 shows healthy 19.66 volts. The next three are ground, but the 6th one shows .283 volts. This is strange to me, it should be 3.3 or 5 or aome volts not 0.283v. As I am new to this, I would like some guidance. Please someone advise me on what to check next.
      Oh the boardview and schematics I am using is for a similar model as I cannot find the proper one anywhere. Quanta DA0P5HMB8F1 rev F. Nowhere on the internet.
      09-23-2025, 12:13 PM
