Xbox Series X shuts off after ~6 seconds
  • survivalbloke
    • Aug 2021
    • 290
    This Series X came in for shutdowns. If I press the power button, I get button illumination and one beep. After ~6 seconds, another beep is heard and it powers off.
    I've tried a hard reset, but instead of the reset, I just get the 6 second shutoff. I also swapped out the PSU figuring that was most certainly it, but it was not.
    I've torn it mostly down and a visual inspection to the boards - nothing of note there.
    Thoughts?
    • 31012
    Re: Xbox Series X shuts off after ~6 seconds
    harddrive?
    most xboxes use shit rosewill drives
    • Dan81
      SNES-powered
      • Oct 2013
      • 1865
      • Romania
      AFAIK they stopped using HDDs and whatever storage is in there is likely SSD.
      Main rig:
      Gigabyte B75M-D3H
      Core i5-3470 3.60GHz
      16GB DDR3-1600
      Samsung SH-224AB DVD-RW
      Delux MG760 case
        • 31012
        if it's the shoebox shape then it's ssd
        • Mario875
          • Jun 2023
          • 15
          • Far Away
          Don’t know why people are debating this if it’s a Series X…they all came with NVME type SSDs (in a non-commercially available size).
          • survivalbloke
            • Aug 2021
            • 290
            There is no hard drive in this unit. Matter of fact, the media must be integral to the board because I don't recall ever seeing removable media on a Series X.
            • diif
              • Feb 2014
              • 6978
              • England
              It M.2, hidden under a shield. It is removable.
              https://www.ifixit.com/Guide/Xbox+Se...acement/141752
                • 31012
                it's also coded to the console - dont corrupt or erase the first partition!
                • survivalbloke
                  • Aug 2021
                  • 290
                  So, what happens if the existing SSD dies?
                  To test if it was the SSD, I removed it, then used Macrium Reflect to copy that 1024MB RAW coded partition, then flashed that partition to another SSD, leaving the rest of the SSD blank. When I powered it back up with the offline update USB connected, this time it powered on, but then off after 2 seconds. My research on this concluded that this condition is the result of the Xbox not recognizing the replacement SSD - presumably due to not having that coded partition present, but I copied it... so I'm a bit confused.
                  Also, according to Crystal Disk Info, the original SSD from the Xbox was fine. Man, I've got so much time in this with no diagnosis. I may need to just stick to HDMI port replacements.
                  • diif
                    • Feb 2014
                    • 6978
                    • England
                    It's a custom drive.
                      • 31012
                      if you do an update or it updates from online/game-disk it changes the code - so keeping backups is pointless.
                      i wont touch xbox consoles, they arent worth the trouble with shit like that going on.
                      • survivalbloke
                        • Aug 2021
                        • 290
                        Yeah, I'm going to do only HDMI ports from now on. Huge waste of my time.
                        • trepachka
                          • Oct 2022
                          • 424
                          I am troubleshooting Xbox Series X shutting off immediately after HDMI port replacement. I am trying to identify values of R18 and R19 resistors. When measuring across, they both show near 0 ohms. I do not know whether this is normal or what. Take a look at the enclosed photo for reference. Thanks.
                          • liquidzorch
                            • Oct 2016
                            • 134
                            • mexico
                            Those are 0 ohms. Try looking at u82, that seems to blow if anything is shorted at the HDMI connector. There should be 3.3v on pin 1 I believe. And when turned on, pin 6 should have 3.3v. If pin 6 doesn't get 3.3v when turned on, replace the u82, you can find them on other boards. Any chance you could take a measurement of the GPU core voltage side to ground, how much resistance do you get?
                            • trepachka
                              • Oct 2022
                              • 424
                              I currently have an Xbox One S motherboard available to steal components from. I found similarly looking components with markings "KAD" on it. Is this the one I can use as a replacement? Take a look at the enclosed photos.
                              • scorpionfadi
                                • Mar 2018
                                • 6
                                • syria
                                Try replacing the hard drive with a new one, this may solve the problem.
