PS4 not sync the controller
  • giove
    • 26
    • Italy
    hi I have a PS4 model cuh-1216A that does not sync the controllers. Better to say cold sometimes everything works correctly but when I turn it off and on again after a while it no longer synchronizes the controllers. It must be said that the Wifi has not worked for some time and so I proceeded to replace the AW-nb218 chip, unfortunately without solving either problem. Controllers plugged into the USB charge fine and always work in safe mode. can anyone help me to solve?
  • lotas
    • Jan 2016
    • 4754
    • Russia
    Re: PS4 not sync the controller
    You have a problem in the firmware in NOR Flash, BwE PS4 WiFi / BT Patcher & Extractor helped me earlier. But you have to be very careful not to spoil the firmware itself, otherwise you will get a brick!
    • giove
      • 26
      • Italy
      I thank you for the answer. Let me ask you a question, If it were a firmware problem it should never work instead sometimes, cold it works and works well!! Where can I find more info on NOR flash?
      • lotas
        • Jan 2016
        • 4754
        • Russia
        You will enter BwE PS4 WiFi / BT Patcher & Extractor into the search engine and a lot of what you will find on this malfunction.
          • 31201
          i think there is a thread here about how to patch it, complete with the files.
          i remember seeing it once.
          • lotas
            • Jan 2016
            • 4754
            • Russia
            Yes, here you also need to check the power supply of this module, there are two power supplies 1.8v and 2.5 or 3.3v, maybe some kind of dc / dc converter is buggy.
            • giove
              • 26
              • Italy
              Can you help me find these threads?
                • 31201
                https://www.badcaps.net/forum/showthread.php?t=50682
                https://www.badcaps.net/forum/showthread.php?t=55263
                • giove
                  • 26
                  • Italy
                  Update. The ps4 a year ago could not be updated, gave an error code and was taken to assistance. Upon pick up I was told everything was working except the WIFI. Since it suited me I confirmed the repair, but I don't know what they did. This is a necessary explanation.
                  Now I started the PS4 in safe mode the controller connected with the wire as indicated works and I performed an installation. To my amazement from a moment before the controllers didn't work now after the reinstallation everything works ok (except the WIFI).
                  I'm keeping it under test and since I reinstalled the controllers are working fine. Since I already had some doubts about the HW failure before replacing the BT/WIFI chip and also the firmware problem, what could it be?
                    • 31201
                    it;s possible the install updated the firmware - who knows.
                    • master3112
                      ASUS ROG Strix- G513IH-HN008, G513-6050A3249301- MB-A04 (A4) damaged Embedded Controller
                      by master3112
                      I have an ASUS ROG Strix- G513IH-HN008, motherboard G513-6050A3249301- MB-A04 (A4)
                      When I received the device, the device has no function. After an investigation, I found that the PWM CONTROLLER RT6575B (U6100) is getting warm and there is a short circuit at the 3V3 output. This normally supplies 3V3 for the embedded controller IT5571E-128 (U301). When measuring and analyzing with a thermal imaging camera, I found that some components are damaged: SLG4E42553VTR (U8500), IT5571E-128 (U301), LAN RTL8111H (U450), LOGIC 74LVC1G08GW (U1900), RT6575B (U6100) All these components are on...
                      10-29-2024, 09:32 PM
                    • foxer
                      Sony AV1010, basically works but heatsink is cold, resistors overheating
                      by foxer
                      Weird stuff.
                      I press power on this receiver, I hear the relay click, I can play music and get radio, everything apparently works but not really. The big heatsink stays cold to the touch, the small heatsinks to the two voltage regulators on the mainboard get super hot, and there are two overheated brown areas on the mainboard with an identical pattern (circled in red), centered on the components on each side of the big capacitors (removed in these pictures). Those last components, of course, also get burning hot.
                      So...I spent the week with my novice skill trying to locate...
                      06-19-2023, 07:54 PM
                    • grimacelord
                      PS4 CUH-2115B Slim All Controllers Do Not Sync By Bluetooth or USB
                      by grimacelord
                      Hello. I have a PS4 Slim model number CUH-2115B that is having a problem with syncing any controller by USB and Bluetooth. Every controller I have tried will not sync, and I know that the controllers will sync fine to another PS4, so it's not a controller problem. I have tried 5 different USB cables and 3 different controllers and none of them sync to this PS4, but will on others.
                      The USB ports on the PS4 is delivering 5V power and does charge the controllers (I checked with an USB ammeter).
                      The controllers also do not work in Safe Mode. I understand that if they...
                      08-08-2022, 09:04 AM
                    • ronnygracias
                      Help with freemotion incline trainer with controller comm error
                      by ronnygracias
                      The treadmill was working fine, one day the belt snapped and after checking the unit I also noticed that the display is now showing the Controller comm error. So I opened it up and the treadmill had two boards. One is a power supply board and the other is the motor controller. I noticed there was a mouse nest, so I took power supply board out, cleaned it up, replaced the big capacitor and that did nothing. Then I took apart the motor controller and cleaned that up, and when I plugged it in, it started right up. I thought I fixed it. But when the belt arrived, I installed it and tried to power...
                      11-04-2024, 01:32 PM
                    • CapLeaker
                      Dell ATX PSU won’t start, but forcing it works fine?
                      by CapLeaker
                      Got a case of something new weird at work. There is an old 2nd gen Intel i3 in an old “Pizza box” shell that has a small form factor power supply. Unfortunately I forgot to take pictures and model number off it.
                      Anyway, I get to work and get to look at this computer. Standby LED on the PSU is on, but the computer won't start. Hmm o.k. take the battery out of the main board try again, nothing. O.k. then… unplug the power supply from the main board and put in a full size ATX PSU (yeeeesss! Exact that blown Powerman IP that I fixed a while back), plug it in and the old...
                      10-28-2024, 06:59 PM
