PS4 not sync the controller
  • giove
    • 26
    • Italy
    hi I have a PS4 model cuh-1216A that does not sync the controllers. Better to say cold sometimes everything works correctly but when I turn it off and on again after a while it no longer synchronizes the controllers. It must be said that the Wifi has not worked for some time and so I proceeded to replace the AW-nb218 chip, unfortunately without solving either problem. Controllers plugged into the USB charge fine and always work in safe mode. can anyone help me to solve?
  • lotas
    • Jan 2016
    • 4577
    • Russia
    Re: PS4 not sync the controller
    You have a problem in the firmware in NOR Flash, BwE PS4 WiFi / BT Patcher & Extractor helped me earlier. But you have to be very careful not to spoil the firmware itself, otherwise you will get a brick!
    • giove
      • 26
      • Italy
      I thank you for the answer. Let me ask you a question, If it were a firmware problem it should never work instead sometimes, cold it works and works well!! Where can I find more info on NOR flash?
      • lotas
        • Jan 2016
        • 4577
        • Russia
        You will enter BwE PS4 WiFi / BT Patcher & Extractor into the search engine and a lot of what you will find on this malfunction.
          • 31007
          i think there is a thread here about how to patch it, complete with the files.
          i remember seeing it once.
          • lotas
            • Jan 2016
            • 4577
            • Russia
            Yes, here you also need to check the power supply of this module, there are two power supplies 1.8v and 2.5 or 3.3v, maybe some kind of dc / dc converter is buggy.
            • giove
              • 26
              • Italy
              Can you help me find these threads?
                • 31007
                https://www.badcaps.net/forum/showthread.php?t=50682
                https://www.badcaps.net/forum/showthread.php?t=55263
                • giove
                  • 26
                  • Italy
                  Update. The ps4 a year ago could not be updated, gave an error code and was taken to assistance. Upon pick up I was told everything was working except the WIFI. Since it suited me I confirmed the repair, but I don't know what they did. This is a necessary explanation.
                  Now I started the PS4 in safe mode the controller connected with the wire as indicated works and I performed an installation. To my amazement from a moment before the controllers didn't work now after the reinstallation everything works ok (except the WIFI).
                  I'm keeping it under test and since I reinstalled the controllers are working fine. Since I already had some doubts about the HW failure before replacing the BT/WIFI chip and also the firmware problem, what could it be?
                    • 31007
                    it;s possible the install updated the firmware - who knows.
                    • master3112
                      ASUS ROG Strix- G513IH-HN008, G513-6050A3249301- MB-A04 (A4) damaged Embedded Controller
                      by master3112
                      I have an ASUS ROG Strix- G513IH-HN008, motherboard G513-6050A3249301- MB-A04 (A4)
                      When I received the device, the device has no function. After an investigation, I found that the PWM CONTROLLER RT6575B (U6100) is getting warm and there is a short circuit at the 3V3 output. This normally supplies 3V3 for the embedded controller IT5571E-128 (U301). When measuring and analyzing with a thermal imaging camera, I found that some components are damaged: SLG4E42553VTR (U8500), IT5571E-128 (U301), LAN RTL8111H (U450), LOGIC 74LVC1G08GW (U1900), RT6575B (U6100) All these components are on...
                      10-29-2024, 09:32 PM
                    • grimacelord
                      PS4 CUH-2115B Slim All Controllers Do Not Sync By Bluetooth or USB
                      by grimacelord
                      Hello. I have a PS4 Slim model number CUH-2115B that is having a problem with syncing any controller by USB and Bluetooth. Every controller I have tried will not sync, and I know that the controllers will sync fine to another PS4, so it's not a controller problem. I have tried 5 different USB cables and 3 different controllers and none of them sync to this PS4, but will on others.
                      The USB ports on the PS4 is delivering 5V power and does charge the controllers (I checked with an USB ammeter).
                      The controllers also do not work in Safe Mode. I understand that if they...
                      08-08-2022, 09:04 AM
                    • ronnygracias
                      Help with freemotion incline trainer with controller comm error
                      by ronnygracias
                      The treadmill was working fine, one day the belt snapped and after checking the unit I also noticed that the display is now showing the Controller comm error. So I opened it up and the treadmill had two boards. One is a power supply board and the other is the motor controller. I noticed there was a mouse nest, so I took power supply board out, cleaned it up, replaced the big capacitor and that did nothing. Then I took apart the motor controller and cleaned that up, and when I plugged it in, it started right up. I thought I fixed it. But when the belt arrived, I installed it and tried to power...
                      11-04-2024, 01:32 PM
                      Tankless hot water heater controller board not powering up when power is applied
                      by sam_sam_sam
                      I recently bought a used tankless hot water heater and the controller board is completely dead no power up when power is applied the display board works however the main controller board does not work correctly at all the fuse is good
                      I bought a used replacement controller board that also had issues that I was able to fix and now the tankless water heater works correctly now
                      However I would like to know if I could figure what happened to this controller board if possible
                      Tomorrow I will take some better pictures of both side of both boards
                      The...
                      12-09-2022, 09:14 PM
                      Lift Master Garage Door wall switch display / motion sensor controller display disappeared no back light
                      by sam_sam_sam
                      This happened last Saturday and today I finally had time this morning before I went to work to replace two non brand capacitors
                      I will let you be the judge weather or not these are bad or not according to the blue ESR meter that I am using
                      I am comparing them to a brand new one that I installed
                      The display came back on and the programming was not lost which I was surprised by I would have thought that when the display went blank that so did the memory as well
                      I going to let it run for several days before I remount back on the wall next to the...
                      09-05-2024, 06:48 PM
