I am working on a Playstation 5. I have all the power rails present but Blue Light of Death. I have provided 12 volts and 1 amp from bench power supply. I receive a 0.01 amp draw of current. Any ideas? Just in general. Anyone ever seen this small of a short on a printed circuit board? Acts like a crack in board but none present. Any assistance would be appreciated. Thanks!
0.01 AmP Short on PS5 motherboard
Re: 0.01 AmP Short on PS5 motherboard
all i can say is watch a lot of cod3r video's - the guy is a master with ps5 and a good teacher.
https://www.youtube.com/c/TheCod3r/videos
https://www.twitch.tv/thecod3r2015/videos
while your at it, dump the syscon flash and post it here with the model number.
i want to create a collection to share
That’s not a short, 10mA draw is just what the board it taking but it’s not right, looks like it is stuck at the POST boot. It should increase to around 300mA when you apply power then settle down to around 70mA of I’m not mistaken.
The only info you have here is that the power on sequence is not happening if it just takes 10mA as soon as you apply 12V And hold there.
You need to do more fault finding, check all standby voltages, check for shorts on power rails (what is the actual resistance from the rail to GND), check the caps behind the south bridge, check around the SSD controller, etc.
Could literally be any number of things.
Originally posted by Mario875 View PostThat’s not a short, 10mA draw is just what the board it taking but it’s not right, looks like it is stuck at the POST boot. It should increase to around 300mA when you apply power then settle down to around 70mA of I’m not mistaken.
Could literally be any number of things.I bought a known good EDM-020 with a PSN ban. Just to get known good standby voltages and compare. I also ordered a Southbridge. PS5 BLOD- CFI-1115A Disc Version- Board= EDM-020
