I am working on a Playstation 5. I have all the power rails present but Blue Light of Death. I have provided 12 volts and 1 amp from bench power supply. I receive a 0.01 amp draw of current. Any ideas? Just in general. Anyone ever seen this small of a short on a printed circuit board? Acts like a crack in board but none present. Any assistance would be appreciated. Thanks!
0.01 AmP Short on PS5 motherboard
Re: 0.01 AmP Short on PS5 motherboard
all i can say is watch a lot of cod3r video's - the guy is a master with ps5 and a good teacher.
https://www.youtube.com/c/TheCod3r/videos
https://www.twitch.tv/thecod3r2015/videos
while your at it, dump the syscon flash and post it here with the model number.
i want to create a collection to share -
That’s not a short, 10mA draw is just what the board it taking but it’s not right, looks like it is stuck at the POST boot. It should increase to around 300mA when you apply power then settle down to around 70mA of I’m not mistaken.
The only info you have here is that the power on sequence is not happening if it just takes 10mA as soon as you apply 12V And hold there.
You need to do more fault finding, check all standby voltages, check for shorts on power rails (what is the actual resistance from the rail to GND), check the caps behind the south bridge, check around the SSD controller, etc.
Could literally be any number of things.Comment
Could literally be any number of things.I bought a known good EDM-020 with a PSN ban. Just to get known good standby voltages and compare. I also ordered a Southbridge. PS5 BLOD- CFI-1115A Disc Version- Board= EDM-020
by Geeker007Hi All, I have a 9th Gen Dell Optiplex micro PC motherboard which doesn't power on. When I connect the motherboard with power adapter, it goes into safe mode and turns off. So from info I have gathered online, it looks like there is a short circuit on the motherboard. So can you guys help me with figuring out the issue?
I am new to electronics repair, so my queries could be naive but I am ready to learn.
So I have a multimeter and a solder with me. But I can try to get a variable voltage power supply with a thermal camera as well. From what I seen online, best way is... -
by StephenI check PPBUS_AON and there is a short present on the line, the computer shows a short when testing for short to ground, so when I inject voltage into the line, I get 0AMPS so no short is showing up. I have replaced a blown cap on this board that exploded and tested for the short and it is now removed. Any suggestions? I tested voltage at the line when the fuses are connected and I am getting 1.2 Volts at the line.
by gaelicanHi,
I am working on an Asus ROG laptop repair. I was able to find that there is a short on the motherboard, and the 20 volts from the charger only gets to the first mosfet before disappearing.
When looking around with a thermal camera, I noticed the chip marked "14C" in the picture was getting warm. Nothing else was receiving heat.
I found a boardview diagram and schematic for a motherboard that looks nearly identical, that has the same component. This appears to be marked as "AC Short Protection" with a value of 13.7KOhms.
by Mess
Hi beginner here, so I'm not sure of I've done this right 😅 trying to diagnose my laptop's motherboard (dax31mb1aa0 rev a). I don't quite know how to read the schematic, so I'm attaching the pictures of the motherboard and the measurements.
I was attempting to measure resistance to GND on inductors. I disconnected motherboard and used "continuity testing" setting on my multimeter. I put black probe to Ground & red probe on an inductor. Did I measure this right? Am I correct to think that 0.3 ohm measurement indicates a short circuit? Thank you for your help!... -
by playitthe comon problem they say , the charger will shut off power once plugged to laptop , i dont have battery, its long gone ago , i use it for backup with adapter and vga port to external monitor(yes no screen lcd) in case my desktop needs fix . one thing for sure i could say the clr resistor - r010 beeps ,short at both sides , the checked all the coils , the 3 coils together gives all of them beeps short along with their respective capacitors . i dont have voltage ampere injection dc machine as in videos i have seen they see where its getting hot and they remove the short and replace components...
- Loading...
