NR90GC Nail Gun controller board repair
  • pintglass
    • Jul 2019
    • 79
    • United Kingdom
    I am in the process of trying to repair a controller board for a Hitachi NR90GC nail gun. The gun has no mechanical reason why it won't work. So I am assuming there's an issue with the PCB.
    I've draw a schematic of the pcb by tracing/probing around the board to help try and find out why its not working.
    Firstly can you just have a look at the schematic to check if I have made any obvious mistakes.
    Secondly can you give me a clue as to what the main IC (U1) could be, as the IC only has the marking of the model number of the nail gun on it. Could it be a custom Chip? There's a few other components that I can't find info on but I can manage without that for now.
    Thanks in advance
  • petehall347
    • Jan 2015
    • 4451
    • United Kingdom
    Re: NR90GC Nail Gun controller board repair
    c10 c11 dont look too clever
      • 31301
      the trackside looks like it got wet
      why the hell does a nailgun need a microcontroller?
      • lotas
        • Jan 2016
        • 4910
        • Russia
        Most likely a re-marked microcontroller (it has internal firmware), its power supply is 3.3v per 1 pin. for 7 pins. - reset.
          • Jul 2011
          • 6070
          Because it needs to know when the nail has left the gun’s guide so it does not jam would be my guess and maybe to know if the tool is jammed so it cuts power to the motor
          The battery operated rivet gun that I has a micro controller in it as well because it controls the amount of torque that it sends to the jaws of the tool and tracks the travel of the rod
            • 31301
            well they are dumb shits because crystals and resonators dont like shocks - like you get with a solenoid hammer mechanism.
            check the resonator is resonating.
            (and check the soldering on it)
            • pintglass
              • Jul 2019
              • 79
              • United Kingdom
              Because it needs to know when the nail has left the gun's guide so it does not jam would be my guess and maybe to know if the tool is jammed so it cuts power to the motor
              The nail gun doesn't have any means to sense a nail jam the only sense it has is that the firing mechanism is fully depressed so it knows its pressed against a piece of timber before it fires. Usually if there's a jam the firing mechanism will not depress.
              When I've been testing it just this doesn't seem to be working though as the controller seems to fire without sw2 being grounded.
              I will test this but the whole board was encapsulated in some kind of silicone/coating that's why it possible looks like its got wet, but that's impossible due to it having the coating until I scrapped it all of.
                • 31301
                i noticed the rubber
                • Sheppma
                  • Oct 2013
                  • 8
                  looks like quite a bit of corrosion as well as the damaged chip capacitor, i would give it a thorough clean and try then , you might be lucky
                  • lotas
                    • Jan 2016
                    • 4910
                    • Russia
                    This is not corrosion, the board was coated with silicone sealant.
                    • pintglass
                      • Jul 2019
                      • 79
                      • United Kingdom
                      Do you know what it is they use, I was thinking of using silicone to reseal but have read silicone can be acidic so may cause corrosion.
                      I've drawn a blank trying to find any info on this IC, no micro controllers seem to have VCC on pin 1 and GND on pin 2.
                        • 31301
                        i use this:
                        https://www.ebay.co.uk/itm/125281546908
                        the 705 one
                        • redwire
                          • 3912
                          You can see this uses high voltage capacitive discharge to the gun solenoid.
                          There is a DC-DC converter, SCR, and HV big film cap. Careful not to get zapped.
                          I would see if it's first generating HV to charge the cap.
                          • R_J
                            • 9631
                            Does it have any sighs of life? are any of the led's lit? does the exhaust fan ever run. Is the fuel cell installed properly.
                            I have worked on the paslode nail guns and only had to replace broken pistons due to nails hitting something solid and breaking the piston shaft.
                            • pintglass
                              • Jul 2019
                              • 79
                              • United Kingdom
                              To be honest after some testing I don't think there's anything wrong with the controller board. I originally pulled it all apart as the fan wouldn't run, which caused the board to error.
                              When I've been testing the board I've had it powered with my bench top power supply and it seems to work fine, the fan runs ok and I get a spark. So I think the issue is that the battery's are shot.
                              They do seem to charge up ok and do hold a charge, could it be that they can't provide enough power to start the fan.
                              I'm going to make up a new battery to test when I get chance.
                                Tankless hot water heater controller board not powering up when power is applied
                                by sam_sam_sam
                                I recently bought a used tankless hot water heater and the controller board is completely dead no power up when power is applied the display board works however the main controller board does not work correctly at all the fuse is good
                                I bought a used replacement controller board that also had issues that I was able to fix and now the tankless water heater works correctly now
                                However I would like to know if I could figure what happened to this controller board if possible
                                Tomorrow I will take some better pictures of both side of both boards
                                The...
                                12-09-2022, 09:14 PM
                              • Grouickman
                                EPILOG Laser - XS002 controller board
                                by Grouickman
                                Hello gus,
                                Just have two XS002 controller board for Epilog laser engraver for repair, looking for any schematic or doc on those board. So far I could only find the "Service training manual", but it's for the whole unit, not specific to the controller board and there is very little info on the board itself.
                                For instance I don't even have the connectors pinout
                                thx.
                                06-10-2025, 11:46 AM
                              • howardc64
                                by howardc64
                                07-24-2025, 05:17 PM
                              • WiredRacing
                                Trials and Tribulations with M.NT68676.2 LCD Controller board and LVDS Panel
                                by WiredRacing
                                Hey all, want to poke the hive mind here for a technology I must be missing something critical about I can't discern from looking at spec sheets alone.
                                I have an ATGames Legends Pinball machine, the playfield is a 32" LCD Display. I'm trying to attach an LCD controller to it for direct PC access, as others have been successful.
                                The LCD is a SPLENDID CD320B01A-350 (I think it's a custom panel for ATGames as google turns up nothing), which is mated to a HV320FHB-N02 (47-6021088) T-CON board (this is probably the important component anyhow)
                                The LCD...
                                08-31-2021, 09:42 AM
