Solar Inverter Caps
  • sedonix
    • Aug 2010
    Solar Inverter Caps
    Hello all you bad cappers!
    Just ran across this forum and would like to get your expert opinion on an issue from the solar power world. As a life long electronics type, I have been contending with my solar power forum friends that the new micro-inverters from the Enphase brand are doomed to failure because they have the audacity to think that they can go 10 to 20 years with electrolytic caps inside of a sealed box mounted on a hot roof beneath solar panels. The company swears up and down that these are "hi-rel" caps and they've done accelerated testing on them etc, and has the whole industry trusting them to the tune of 100's of thousands of units per year. Not me baby - give them a few more years in the field and watch out. Sorry, I can't give you the details, but you get the idea. Each unit runs as much as 250W converting 30Vdc to 240Vac, the caps are like 1000uf, running at 60hz.
    I don't know maybe I'm just paranoid, but my first summer job was working at Tektronix in the precision cap department and I've seen bad caps in every kind of consumer electronics. I watched VCR failures for about 10 years and maybe a 100 versions that it took some Panasonic engineer to learn that Elec. Caps aren't spec'd at high frequencies like 50kHz and don't work as good there.
    • 30985
    Re: Solar Inverter Caps
    well 60hz is nothing, depending on the ripple and cap it's poss to get 20years+ out of one.
    but not at those temperatures.
    has anybody shoved a thermocouple in the case to see what the ambient is on a summer afternoon?
    • erictech
      • Oct 2010
      My mother in-law was just looking into solar powered today. I just so happened to come across this thread. I'd really like to see how they would hold up against a roof in Central-Valley California (summer temperatures this year peaked at 113 F).
      I'm in no way an electronics expert, a computer nerd, yes! But I seriously doubt at those temperatures, those panels will even remotely last that long...
      P.S. I didn't mean to revive an older thread.
      • PCBONEZ
        Grumpy Old Fart
        • Aug 2005
        • 10661
        OH COOL!
        LOTS of new cap work coming!!
        Mann-Made Global Warming.
        - Dr Seuss
        • PCBONEZ
          Grumpy Old Fart
          • Aug 2005
          • 10661
          For lytics each 10C rise in temp reduces the life by 50%.
          - Dr Seuss
          • kc8adu
            • Nov 2003
            • 8832
            • U.S.A!
            post a pic of one opened up.
            • japlytic
              • Oct 2005
              • 2086
              At a home show, I've seen a solar inverter with clear plastic showing quality Hitachi electrolytics, along with other Japanese electrolytics too.
              • shovenose
                Send Doge Memes
                • Aug 2010
                • 6575
                that was a showcase. do we know what they actually use in the units the sell?
                  by momaka
                  03-12-2025, 03:42 PM
                  by momaka
                  03-15-2023, 10:17 PM
                • JFA
                  Honda generator inverter 230v 1900uf caps
                  by JFA
                  I have a Honda generator with a faulty inverter. The inverter is encased in black resin with just the tops of a dozen small electrolytic caps and four 230v 1900uf electrolytic caps poking out of the top of the resin. The plastic cover of one of the 230v caps was burned off but there was no sign of bulging and the capacitor can was in good condition. The heat source looks likely to be from the outside rather than from the component itself but since the inverter is basically unrepairable, I chiseled away and removed the capacitor. I had to destroy the capacitor so had no chance to test it but it...
                  11-28-2021, 03:30 AM
                • eryjus
                  by eryjus
                  05-10-2023, 11:21 AM
                • mitsu2k
                  Power-One solar Inverter driving me NUTS!!!
                  by mitsu2k
                  Hello folks, this is a last ditch effort. I thought I would seek your expertise before giving up.. I have been working on this thing for over 2 months and have gotten nowhere. Here is the issue:
                  Inverter powers on and immediately red GFI light comes on and inverter will not complete the initialization process.
                  There is no error code on the screen. I have removed most of the Y capacitors and tested to no avail.
                  All relays are good.
                  I replaced the current transducer- same problem. Checked most of the transistors and diodes and all appear good. I wish I could get my hands...
                  11-13-2023, 07:19 PM
