value on resistor ps4 pro
  • Ken123
    • Oct 2021
    • 58
    • Sverige
    hello, need help with identifying resistor value by the mn864729 hdmi encoderchip on a nvb-003 board.
    i lost resistor when replacing encoder.
    console have wlod. hope its this resistor
  • Ken123
    • Oct 2021
    • 58
    • Sverige
    Re: value on resistor ps4 pro
    Mixid boards up a bit. Its a nvg-002 but i had a nvb-003 donor. Its slightly different but had a 1k resistor there.
    No difference through.
    Still wlod and its wierd because console had a bad powersupply and network port/burned components.
    Fixed this and I had picture and all good.
    Installed a hdd and it overheated. Forgotten clamp 🥴
    After this wlod.
    Guess apu is a goner
    • Ken123
      • Oct 2021
      • 58
      • Sverige
      Fixed, rookie mistake by using wrong hdmi port 🥴
      • Clanner
        • Dec 2022
        • 3
        Hey, guess I'll just abuse your thread.
        Does anybody have a clue about the value of this resistor, PS4 slim. I'm going to replace it, but I lack a donor board:
        https://ibb.co/TcVGGLr
        • Ken123
          • Oct 2021
          • 58
          • Sverige
          Seems to be 22ohm on my donor bord
          • Clanner
            • Dec 2022
            • 3
            Thanks a lot. I'm going to keep you updated, whether it worked. ;-P
            • jinu_j
              by jinu_j
              Hi
              05-03-2025, 10:51 PM
            • mikey5791
              Need help to replace burned resistor in 350w atx psu
              by mikey5791
              Hi to all forum members,
              Got this faulty 350 watt atx psu dirt cheap from a local online seller as i am keen to use it as a learning tool to repair faulty power supply.
              The faulty part is quite obvious from the burn area near the 16pin KA7500 BD pwm. The fuse is still intact with good continuity.
              Upon power on ac, there is 5vdc standby power on cathode of diode D14 and about 10vdc on cathode of diode D13.(This should be the aux power to generate the 12v and 5v rail.)
              Initially i replace the two burned resistors near my marked red arrow to 200 ohm resistor...
              12-26-2024, 04:55 AM
            • MidnightRoller
              Can a resistor lose resistance after hot air?
              by MidnightRoller
              I am curious if a 0402 resistor could go from 43 ohm to 0. In electronics class and my experience a resistor can degrade and gain resistance all the way up to not being able to conduct at all. I have never heard of a resistor decreasing in resistance and becoming 0 ohm or a dead short… that's not the direction they fail… or so I thought.
              I was attempting to remove a wson8 chip on an iMac motherboard and it required a lot of heat, on one side of the chip were 3 0402 resistors that were very close. I popped the chip out unintentionally out of the tweezers and sent those resistors...
              02-02-2022, 11:46 PM
            • artvandalai
              What resistor ohm will work better to repair this waterpik?
              by artvandalai
              The resistor on this waterpik blew. I changed it with the a similar spec 47ohm 2 watt yageo resistor but it still keeps blowing the resistor. Checking with the multimeter the motor, capacitor, diodes, and thermal fuse all checked normal. Will a higher ohm resistor work better? What ohm resistor will work better to repair this waterpik? This video is showing the repair with a 56 ohm resistor https://www.youtube.com/watch?v=_J7_rV7ui1Y
              01-05-2025, 04:10 PM
            • chth96
              Is it okay to replace 1/2 watt resistor with 1 watt resistor in AC/DC adapter?
              by chth96
              I have purchased an 100-240v AC/5v 2a DC adaptor from aliexpress,and a month ago It smelled burning when I plugin it powerstrip.
              Since then, This AC/DC adaptor have been out of order.
              But A few days ago,I replace 0.5 watt resistor with 1 watt resistor(1ohm) in this adapter.
              After replacing resistor,It succeed to recharge all of android phone.And When I measure voltage on the two pins of USB port,It shows 5.5v
              And Is there any possibility that it will suddenly explode as well as to be out...
              12-03-2023, 04:40 AM
