Asus prime z390-a rev1.02 bios need
  • WhyINeedAccount123
    • Feb 2021
    • 19
    • Poland
    Hi everyone, i tryied to update bios on my motherboard from 1802 to 2002 and that did not well, this bricked my mobo. Can someone send me a working bios.bin?
    • Feb 2021
    • 19
    • Poland
    Re: Asus prime z390-a rev1.02 bios need
    i downloaded bios from asus official page, then i use uefi tool to extract bios .bin from .cat but still. Computer turning on, led cpu light, then dram light but then nothing. Everytghing was after update bios, i make a pictrue old version old bios, then downloaded new... bios flashed 100% then pc says it will make a restart. But then nothing, now idk what to do, new bios programed from official page asus, and zero changes. Can someone help me pls?
      • Feb 2021
      • 19
      • Poland
      here is this broken bios, But can this flashing bios damage something else?
      • hoaca388
        Badcaps
        • Jan 2022
        • 12326
        ASUS Prime Z390-A bios 2004
          • Feb 2021
          • 19
          • Poland
          still not working,and now on the original bios it doesn't start at all. So there have been some changes, but still no display
            • 21861
            What model is your programmer,are you using a clip or have you desoldered the chip.Did you remove the CMOS battery
              • Feb 2021
              • 19
              • Poland
              I use ezp2010 programmer, i solder chip to special board for this programmer. Yes, i always remowe cmos battery
                • 21861
                I don`t see version 2002 at asus support. Try the 1802 version
                  • Feb 2021
                  • 19
                  • Poland
                  Sorry, I made a mistake when writing the post. The bios version to which I updated my motherboard is 2004. I tried to flash the 1802 version from asus. But still no change. In the 2004 bios change notes you can see "Update Intel ME firmware." I think something went wrong here. Returning to the original bios chip, after soldering it, the computer works, I just soldered it wrong before. No bios works, all the time the computer turns on without a picture, I've tried probably 10 bios, but nothing.
                    • Feb 2021
                    • 19
                    • Poland
                    Maybe ec after this update has problem?
                      • 21861
                      Have you checked your soldering and for broken traces, or missing resistors
                        • Feb 2021
                        • 19
                        • Poland
                        Yes, i checked. But when i update bios it may have been broke traces?
                        I dont understand what happened, bios may be faulty, but something else can be damaged? WHY the startup doesn't go further than this ram?
                          • 21861
                          The traces could have been damaged when you desoldered and resoldered the chip.Did the programmer verify after writing.Try another chip
                            • Feb 2021
                            • 19
                            • Poland
                            Test programmer verify chip "ok".
                            At start i used new chip...
                              • 21861
                              Maybe the TPU/iRog firmware needs flashing.The chip size should be 64KB,512KB or 2MB. Post backups or compare with the attached FW extracted from bios version 2004
                              More info about TPU FW https://winraid.level1techs.com/t/so...e-guid/32418/3
                              • edworthy
                                • May 2020
                                Just recovered my newly 'acquired' ASUS PRIME Z390-A ! Thank you so much.
                                • razor_amd
                                  by razor_amd
                                  12-15-2020, 07:07 PM
                                • pirati
                                  by pirati
                                  Yesterday, 04:20 PM
                                • grimacelord
                                  by grimacelord
                                  07-10-2025, 02:52 PM
                                • DynaxSC
                                  by DynaxSC
                                  06-14-2024, 03:49 PM
                                • jbonavita
                                  by jbonavita
                                  Some issues
                                  Things I tried
                                  04-29-2025, 09:38 PM
