dell optiplex 3090 bios issue please help!!
  • elmotastic
    • Jun 2023
    • 3
    Re: dell optiplex 3090 bios issue please help!!
    Originally posted by volinakis
    1st boot, press F2, write service tag, disable Absolute, save (Apply changes), restart. 2nd boot press Alt+F to exit manufacturing mode.
    Thank you, works like a charm. I really appreciate your help.
    Just out of curiosity, I had a look on a few bios files with password and unlocked for the 8FC8. There are actually two bytes changed, what looks for me like random locations. Maybe I did not tried hard enough the see the pattern.
    Is the secret somewhere hidden in this forum, how the bios is unlocked?
    • volinakis
      • Jan 2021
      • 2610
      • N/A
      #42
      it's a "secret" at sight, please donate for forum to keep servers alive and I'll tell you where to look.
      • interpc
        • Feb 2015
        • 73
        • Mexico
        #43
        help to unlock a dell 3090
        3090loc.zip
        thanks
        • volinakis
          • Jan 2021
          • 2610
          • N/A
          #44
          [ATTACH]305476[/ATTACH]
          thanks
          • interpc
            • Feb 2015
            • 73
            • Mexico
            #45
            thanks works perfect
            • alfie73
              • Oct 2020
              • 31
              • Philippines
              #46
              sir please help dell optiflex 3090 computer trace my service tag 1V8DXM3 and my motherboard Foxconn IPCML-RN/ZB
              • volinakis
                • Jan 2021
                • 2610
                • N/A
                #47
                your bios has no DMI, bios was modified previously. anyway, try this bios and write your DMI.
                • alfie73
                  • Oct 2020
                  • 31
                  • Philippines
                  #48
                  thank you sir for the file ill try it tommorow...I dont know what is DMI sir?i backup this bios using ch341 ...after i back up i erase then i flash other bios in page 1 i download it and try to flash but my pc is not turning on i flash my back up file but still not turning on il try this firmware tommorow that you give to me..hopefully this fimware will bring my pc back...can i flash it using ch341?and you said write your DMI where i can find DMI ?and how to write DMI in bios?
                  • volinakis
                    • Jan 2021
                    • 2610
                    • N/A
                    #49
                    it means you failed to read properly your bios with CH341, that's why you better READ THE GUIDES before.
                    "When flashing a BIOS always make a backup first. Take 2 or 3 different dumps and make sure they are identical. Make sure that the dumps looks good, i.e. not filled with 0x00 or 0xFF. After compression, if the file has a size of only a few kilobytes, the EEPROM was most likely not read properly."
                    https://www.badcaps.net/forum/showpo...49&postcount=2
                    • alfie73
                      • Oct 2020
                      • 31
                      • Philippines
                      #50
                      is there away i can recover my pc?or download the right bios for my motherboard?
                      • alfie73
                        • Oct 2020
                        • 31
                        • Philippines
                        #51
                        thank you so much sir my pc just woke up in this file i just nned to flash using another flasher thank you so much
                        • osman68i
                          • May 2015
                          • 334
                          • The Netherlands
                          #52
                          Hi
                          i want to unlock optiplex 3090 micro
                          SVCTAG 244K2L3 - 8FC8
                          • hoaca388
                            • Jan 2022
                            • 11135
                            • Viet Nam
                            #53
                            Originally posted by osman68i
                            Hi
                            Unlock bit not found on this bios.
                            Become a Badcaps supporter
                            Thanks to all supporters.
                            • osman68i
                              • May 2015
                              • 334
                              • The Netherlands
                              #54
                              thats very strange.
                              I will reprogram the oiginal bios and check again. I will take a photo. thanks in advance.
                              • Techminator
                                • May 2023
                                Can you please help me unlock BIOS of my Dell Optiplex 3090 micro
                                Service Tag: FM0L6L3
                                Also, please guide me how to use the files as I am completel new to this. I tried to see if there is a jumper on the motherboard but there isn't.
                                • hoaca388
                                  • Jan 2022
                                  • 11135
                                  • Viet Nam
                                  #56
                                  thats very strange.
                                  Try and feedback
                                    • 20279
                                    You will need an SPI programmer to make a backup of the bios chip contents (bios dump) .
                                    Please read the BIOS guides, methods, resources and tools thread and the rules for future reference.
                                    https://www.badcaps.net/forum/showthread.php?t=103528
                                    https://www.badcaps.net/forum/showthread.php?t=103569
                                    • ademkotiloglu
                                      • Sep 2021
                                      • 11
                                      • tr
                                      #58
                                      help please?
                                      S.T = 330VPM3
                                      • hoaca388
                                        • Jan 2022
                                        • 11135
                                        • Viet Nam
                                        #59
                                        Originally posted by ademkotiloglu
                                        help please?
                                        S.T = 330VPM3
                                        What ? What help ?
                                        • ademkotiloglu
                                          • Sep 2021
                                          • 11
                                          • tr
                                          #60
                                          What ? What help ?
                                          I forgot my bios password. I added my original bios file. I request the unencrypted version.
                                            DELL OptiPlex 3090 OptiPlex 3000 i5-1145G7 Specification for Upgrade or Repair
                                            This specification for the DELL OptiPlex 3090 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the OptiPlex 3090 boardview and OptiPlex 3090 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL...
                                            09-12-2024, 03:44 PM
                                            09-12-2024, 03:36 PM
                                            DELL OptiPlex 3090 OptiPlex 3000 i3-1115G4 Specification for Upgrade or Repair
