dell optiplex 3090 bios issue please help!!
  • aegeanxtr
    • May 2012
    • 6
    • turkey
    #141
    Originally posted by hoaca388
    It works with the suffix 8FC8
    I tried it and it works! Thank you very much my friend.
    • CuteWildCat
      FF
      • Jan 2025
      • 15
      • FR
      #142
      Can someone help me please to unlock admin password please ?
      Service Tag : 1THQMS3
      Many Thanks
      • peste
        • 12643
        • ROMANIA
        #143
        Many Thanks
        post full name and model, motherboard model, etc.
        post bios here not on another site..
        • CuteWildCat
          FF
          • Jan 2025
          • 15
          • FR
          #144
          Bios Dell Optiplex 3090 SFF
          Motherboard RZ0624
          • hoaca388
            Badcaps
            • Jan 2022
            • 11640
            #145
            Motherboard RZ0624
            Backup not good , read chip again.
            • misiozol
              • Feb 2017
              • 8
              • :D
              #146
              Guys quick question, what programmer to use for 25Q256JVFQ , trying to read bios have few programmers but seems neither support this chip :/
              • peste
                • 12643
                • ROMANIA
                #147
                see which programmer has this chip in the database...
                • misiozol
                  • Feb 2017
                  • 8
                  • :D
                  #148
                  Programmer is on it's way. Will seek help once have it.
                  • misiozol
                    • Feb 2017
                    • 8
                    • :D
                    #149
                    If any one be so kind and remove the computer trace (absolute) dell optiplex 3090 micro
                    ST: B03RMM3
                    MOBO: IPCML-RN/ZB
                      • 20678
                      ST: B03RMM3
                      MOBO: IPCML-RN/ZB
                      try
                      • misiozol
                        • Feb 2017
                        • 8
                        • :D
                        #151
                        Worked perfect, was able to disable it in bios settings thank you.
                          • 20678
                          You`re welcome
                          • misiozol
                            • Feb 2017
                            • 8
                            • :D
                            #153
                            For future reference, green board CH341A and 16pin clip works perfect with this MOBO board, just needs pins rerouted on programmer as they are not 1:1, use attached data sheet page 9, package include driver, software for programming, plus data sheet.
                            If you are unsure of voltage that is given to flash memory look on voltage regulator usually SOT-223 package part number or similar AMS1117 left bottom corner indicates output voltage it should state 3.3
                            • jrlmerchandise
                              • Jun 2025
                              • philippines
                              #154
                              Hi Help with Bios password locked on my dell optiplex 3090 micro
                              Service tag: 5MPNPM3
                              and forgive me I'm new here, could you direct me on how to use the file? Thanks very much!
                              • peste
                                • 12643
                                • ROMANIA
                                #155
                                The bios chip must be unsoldered from the board before writing or reading..
                                do not use the clip, you may have errors..if you do not have anything to unsolder it with,
                                solder wires between the programmer and the bios chip..
                                you need an SPI programmer...here is a video for example..https://www.youtube.com/watch?v=DWWi...nnel=ThisIsHow
                                • misiozol
                                  • Feb 2017
                                  • 8
                                  • :D
                                  #156
                                  Actually it doesn't have to be de-soldered, clip is sufficient for this one. All in my post up.
                                  https://www.badcaps.net/forum/troubl...97#post3650297
                                  • jrlmerchandise
                                    • Jun 2025
                                    • philippines
                                    #157
                                    Ok, Thanks ill review the videos.
                                    • jrlmerchandise
                                      • Jun 2025
                                      • philippines
                                      #158
                                      Hi mate, do you have a reference video on this , on how to do it? Thanks a bunch!
                                      • misiozol
                                        • Feb 2017
                                        • 8
                                        • :D
                                        #159
                                        No video, don't have time for playing. It's VERY simple procedure. You can buy programmer+16pin clip from ali for less then 10e.
                                        • niru
                                          • Apr 2018
                                          • 11
                                          • pokhara
                                          #160
                                          DELL OPTIPLEX3090 BOARD ID 212037-1 service tag 974XFL3
                                          no display bios problem please help me
                                            DELL OptiPlex 3090 OptiPlex 3000 i5-1145G7 Specification for Upgrade or Repair
                                            This specification for the DELL OptiPlex 3090 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the OptiPlex 3090 boardview and OptiPlex 3090 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL...
                                            09-12-2024, 03:44 PM
                                            09-12-2024, 03:36 PM
                                            DELL OptiPlex 3090 OptiPlex 3000 i3-1115G4 Specification for Upgrade or Repair
