Lenovo 11E8 M70Q DIFFERENT FROM 11DT. REQUEST BIOS PLEASE
  • tahnri2k17
    • Jun 2022
    • 6
    • philippines
    Please help me clean my bios. This is the bin file. Anyhelp will be appreciated
  • ddtechrepairs
    • Apr 2012
    • 15
    Re: Lenovo 11E8 M70Q DIFFERENT FROM 11DT. REQUEST BIOS PLEASE
    Hi
    Give this one a try.
    • tahnri2k17
      • Jun 2022
      • 6
      • philippines
      Originally posted by ddtechrepairs
      Hi
      Hi! Thanks for the help. I've tried using this bin file but is says the chip and the contents are in disagreement whenever I tried verifying using ch341a tool.
      • ddtechrepairs
        • Apr 2012
        • 15
        Hi
        If you trying to verify the contents of this file against your chip then it will be in disagreement.
        Need to make sure chip is making proper contact with the programmer.
        Empty chip, Blank check it.
        then burn and verify.
        regards
        • tahnri2k17
          • Jun 2022
          • 6
          • philippines
          Thank you I've already completed the process that you've mentioned but after that, my m70q doesn't boot anymore I've tried removing and placing back the battery and changing the position of the jumper wires but it's still not turning on. It's still receiving power since my flash drive led indicator was lighting up whenever i plug it in the usb slot. Is there anything that I can do to fix this?
            • 22021
            Use different software,there`s NeoProgrammer,Colibri and ASProgrammer ,you`ll find them all posted on the forum .Choose the chip manually,don`t use Auto-Detect .The chip part number is etched on top of it,select it from the support list.
            https://www.badcaps.net/forum/showpo...40&postcount=2
            • tahnri2k17
              • Jun 2022
              • 6
              • philippines
              Thank you! I've actually followed all the step on that thread but it gave me this error. I really don't know why :'(
              • hoaca388
                Badcaps
                • Jan 2022
                • 12354
                With CH341A , do not use clip.
                ​https://www.badcaps.net/donate
                • dquesada202
                  • Jan 2021
                  • 8
                  • Costa Rica
                  It doesn't turn on for me anymore, after trying with a CH341a, they know what I'm doing wrong in the m70q model.
                  Already with m710q I have achieved it successfully.
                  Do you know what it could be?
                  • dquesada202
                    • Jan 2021
                    • 8
                    • Costa Rica
                    why not use the soc8 clip?
                    • hoaca388
                      Badcaps
                      • Jan 2022
                      • 12354
                      Maybe it will give you junk file after reading.
                      • o2809013
                        • Mar 2022
                        • 11
                        • Turkey
                        hi
                        this is not programmer problem. 11E8 oem product for amazon costumer services. It uses Coreboot bios. All other models works with AMI bios. 11E8 only works with special chrome os for amazon. You can't replace bios beacuse there is very important security partition inside bios chip. you need check this pages.
                        https://edk2-docs.gitbook.io/underst...tel_boot_guard
                        https://cdn.badcaps-static.com/pdfs/...de23cefb86.pdf
                        • o2809013
                          • Mar 2022
                          • 11
                          • Turkey
                          There is two bios chip on this machine. All chips OTP function activated and some partitions erase protected. You need change 16mb chip and flash your original dump. There is no other solution for now.
                          • dquesada202
                            • Jan 2021
                            • 8
                            • Costa Rica
                            I already replaced the Chip, but I don't know which bios to configure since I used the ones above and it only turns on and then turns off.
                            Does anyone have one that works?
                            Thank you
                            • ravenmx
                              • May 2018
                              • 180
                              • puebla
                              i have same problem this bios only works from chrome os amazon, i need bin files for ec, ec bios and main bios for install windows, only whit the original file (amazon works) whit others files only power on and shutdown inmediatly(no works)
                              • pinay38794
                                • Feb 2023
                                • Brasil
                                Hi
                                Thank You, this BIOS solves my problem
                                • ShadowDeath
                                  • May 2023
                                  • Costa Rica
                                  Hi! May i know if there is proof of this method working without issues? i have one of these machines and really like to give an usage as for right now its idle getting dust sadly... or where i can find more info about it as per google and bing this is the only place with some info and really like to gather the info so i can give it to a technician to help me with the machine.
                                  • Akhenaton
                                    • May 2023
                                    • New World
                                    My brother! You and I are in the same boat. I have this exact model and am searching from answers on the internet on how to wipe the operating system and install anything else (either linux or windows).
                                    I am a layman on this area, so this is all very new to me. However, I already ordered a CH341A and as soon as it gets to me I'll start tinkering with the machine.
                                    Apparently this is a special model where they put a lot of protections, even at a hardware level. Switching the jumper to delete/restore CMOS/BIOS didn't do anything, neither taking ou the cell-battery. And, apparently, just flashing these custom BIOS available to other models doesn't seem to work.
                                    However, I have a couple of ideas I want to try (before attempting to downright replace the chips). If I have success doing so, I'll post on the forum.
                                    Please, stay tuned - and also, if you get something good going, share as well!
                                    • ShadowDeath
                                      • May 2023
                                      • Costa Rica
                                      Thanks for taking your time to reply to my message, never receive an email with the reply lol but yeah its kinda hard and sad not to find any info related to this, i think next week i will try to change any physical bios chip with a friend and see how it goes, wish me luck and ill let you know if this method work.
                                      • izaak94
                                        • Mar 2019
                                        • 140
                                        • mexico
                                        hello, do you know if it is possible to install windows on this computer linked to amazon?
                                        • fefocaceres
                                          Lenovo M70Q G2 11DT bios password
                                          by fefocaceres
                                          I need some help unlocking the BIOS on a Lenovo ThinkCentre M70q Gen 2.
                                          The admin password is set and I can’t access BIOS settings.
                                          Here are the system details:
                                          • Model: Lenovo M70q Gen 2
                                          • Product type: 11DT
                                          • Serial number: MJ0GSLST
                                          Thanks in advance for any help....
                                          10-02-2025, 09:48 PM
                                        • lucaszmn
                                          by lucaszmn
                                          Problem:
                                          Initial Findings:
                                          • I concluded that the
                                          08-12-2025, 03:01 PM
                                        • Wahaz
                                          by Wahaz
                                          10-30-2023, 08:42 PM
                                        • grimacelord
                                          Lenovo Legion T5-26AMR5 Desktop - Corrupt BIOS
                                          by grimacelord
                                          Hello there.
                                          I am working on a Lenovo Legion T5-26AMR5 desktop that currently has a corrupt BIOS and I have been unsuccessful thus far in trying to fix it myself.
                                          History:
                                          1. This computer came to me initially with an error message that said "BiInitializeLibrary failed 0xc0000001" or "0135 fan error". It would always be one of the two errors. It should be noted that when it produced the fan error, there was no physical problem with the fans. They were all spinning just fine.
                                          I searched for this error online and discovered...
                                          03-15-2023, 03:29 PM
                                        • to5it0
                                          Need Clean BIOS/EC Bin File for Lenovo ThinkPad Yoga 11e 2H1703-27220F Rev. A Marked as U2501 on the motherboard.
                                          by to5it0
                                          Need Clean BIOS/EC Bin File for Lenovo ThinkPad Yoga 11e - Stuck with 0275 Error CMS
                                          I am attempting a repair on a Lenovo ThinkPad Yoga 11e that is currently stuck at boot with the error: "0275 error CMS" even after setup new bios battery and will not allow me to enter the BIOS/Setup.
                                          This is a critical issue that I believe requires flashing the BIOS chip directly using a programmer (e.g., CH341A/RT809H), as standard software updates or resets are not possible.
                                          I have opened the laptop and identified the main BIOS chip...
                                          10-24-2025, 01:35 AM
