Please help me clean my bios. This is the bin file. Anyhelp will be appreciated
Lenovo 11E8 M70Q DIFFERENT FROM 11DT. REQUEST BIOS PLEASE
Tags: None
Re: Lenovo 11E8 M70Q DIFFERENT FROM 11DT. REQUEST BIOS PLEASE
Hi
Give this one a try.Attached FilesPremium supporters get full download access and other benefits.
Hi
If you trying to verify the contents of this file against your chip then it will be in disagreement.
Need to make sure chip is making proper contact with the programmer.
Empty chip, Blank check it.
then burn and verify.
regardsComment
Thank you
I've already completed the process that you've mentioned but after that, my m70q doesn't boot anymore
I've tried removing and placing back the battery and changing the position of the jumper wires but it's still not turning on. It's still receiving power since my flash drive led indicator was lighting up whenever i plug it in the usb slot. Is there anything that I can do to fix this?
Use different software,there`s NeoProgrammer,Colibri and ASProgrammer ,you`ll find them all posted on the forum .Choose the chip manually,don`t use Auto-Detect .The chip part number is etched on top of it,select it from the support list.Thank you
https://www.badcaps.net/forum/showpo...40&postcount=2Comment
Thank you! I've actually followed all the step on that thread but it gave me this error. I really don't know why :'(Use different software,there`s NeoProgrammer,Colibri and ASProgrammer ,you`ll find them all posted on the forum .Choose the chip manually,don`t use Auto-Detect .The chip part number is etched on top of it,select it from the support list.
If you have found our forum useful please consider supporting us. Subscribe for a small monthly fee and receive extra benefits including our bios, boardview & schematic archive.
Subscribe to support us. It only takes 1 minute:
https://www.badcaps.net/settings/subscriptionsComment
It doesn't turn on for me anymore, after trying with a CH341a, they know what I'm doing wrong in the m70q model.
Already with m710q I have achieved it successfully.
Do you know what it could be?Comment
hi
this is not programmer problem. 11E8 oem product for amazon costumer services. It uses Coreboot bios. All other models works with AMI bios. 11E8 only works with special chrome os for amazon. You can't replace bios beacuse there is very important security partition inside bios chip. you need check this pages.
https://edk2-docs.gitbook.io/underst...tel_boot_guard
https://www.badcaps.net/download/?id=44f1286fComment
There is two bios chip on this machine. All chips OTP function activated and some partitions erase protected. You need change 16mb chip and flash your original dump. There is no other solution for now.Comment
I already replaced the Chip, but I don't know which bios to configure since I used the ones above and it only turns on and then turns off.
Does anyone have one that works?
Thank youComment
i have same problem this bios only works from chrome os amazon, i need bin files for ec, ec bios and main bios for install windows, only whit the original file (amazon works) whit others files only power on and shutdown inmediatly(no works)Comment
Hi! May i know if there is proof of this method working without issues? i have one of these machines and really like to give an usage as for right now its idle getting dust sadly... or where i can find more info about it as per google and bing this is the only place with some info and really like to gather the info so i can give it to a technician to help me with the machine.Comment
My brother! You and I are in the same boat. I have this exact model and am searching from answers on the internet on how to wipe the operating system and install anything else (either linux or windows).
I am a layman on this area, so this is all very new to me. However, I already ordered a CH341A and as soon as it gets to me I'll start tinkering with the machine.
Apparently this is a special model where they put a lot of protections, even at a hardware level. Switching the jumper to delete/restore CMOS/BIOS didn't do anything, neither taking ou the cell-battery. And, apparently, just flashing these custom BIOS available to other models doesn't seem to work.
However, I have a couple of ideas I want to try (before attempting to downright replace the chips). If I have success doing so, I'll post on the forum.
Please, stay tuned - and also, if you get something good going, share as well!Comment
Thanks for taking your time to reply to my message, never receive an email with the reply lol but yeah its kinda hard and sad not to find any info related to this, i think next week i will try to change any physical bios chip with a friend and see how it goes, wish me luck and ill let you know if this method work.My brother! You and I are in the same boat. I have this exact model and am searching from answers on the internet on how to wipe the operating system and install anything else (either linux or windows).
by fefocaceresHi everyone,
I need some help unlocking the BIOS on a Lenovo ThinkCentre M70q Gen 2.
The admin password is set and I can’t access BIOS settings.
Here are the system details:- Model: Lenovo M70q Gen 2
- Product type: 11DT
- Serial number: MJ0GSLST
by lucaszmn
Summary of BIOS Whitelist Removal Problem
Problem:
Initial Findings:- My current BIOS version is N1KET58W (1.45).
- I have a CH341A programmer and have successfully created two full backups of my BIOS.
- I have the ability to use command-line tools on a Linux machine.
- I attempted to use several automated and manual patching methods on my N1KET58W (1.45) BIOS, including using hex strings. These attempts all failed.
- I concluded that the
Channel: BIOS Requests ONLY!
08-12-2025, 03:01 PM -
by WahazHello,
I found 3 bios chips on the board, which I read with a bios programmer: two XMC model bios chips and a Winbond model bios chip. Each XMC model bios chip has two partitions named XM25QH128A [3.3V] and XT25F128A [3.3V]. And the Winbond model bios chip has three partitions named W25Q80BL 3.3V, W25Q80xV 3.3V and W25Q80DV 3.3V....-
by gestalt.exeHi everyone,
My Lenovo Legion Y540 (i7-9750H, RTX 2060) bricked after I downgraded from BHCN44WW to BHCN21WW.
Laptop stopped booting entirely.
I used a CH341A programmer to dump the corrupted 16MB BIOS.
i then attempted the following:- Downloaded stock BIOS BHCN39WW from Lenovo
- Trimmed it to 16MB
- Extracted the BIOS region from the corrupted dump
- Extracted the BIOS region from the stock 39WW
- Replaced the corrupted BIOS region with the stock one (within hxd , opened the corrupted dump and replaced its region by the stock)
- Injected back my LDGB / DMI
by grimacelordHello there.
History:
I searched for this error online and discovered...-
- Loading...
