lenovo pih80f/b5030 13101-1 bios request
  • lordrussell
    • May 2015
    • 31
    I'm in need of the full clean bios for this model, lenovo pih80f/b5030 13101-1.
    All I've been running into is the 4mb upgrade not the 8mb. Otherwise, I've included the original dump if someone is brave enough to remove (or know how to) the pass lock.
    Thanks in advance for your help.
  • hoaca388
    Badcaps
    • Jan 2022
    • 12318
    Re: lenovo pih80f/b5030 13101-1 bios request
    B50-30 (Touch) All-in-One (Lenovo) - Type F0AU - Model F0AU008FUS
    • lordrussell
      • May 2015
      • 31
      Thank you hoacca, I will give this a try & post the results.
      You are indeed a scholar & a gentleman.
      • Wahaz
        by Wahaz
        10-30-2023, 08:42 PM
      • lucaszmn
        by lucaszmn
        Problem:
        Initial Findings:
        • I concluded that the
        08-12-2025, 03:01 PM
      • personanongrata
        Help Lenovo Workstation P910 BIOS Request
        by personanongrata
        Dear all, I found this forum and this is my last hope. I had a problem with BIOS update though Windows Update - it was stuck for an hour and I decided to restart. Then it bricked. The reason to update was, I had no video on my panorama display. I tried to find a BIOS on my own, but it seems that Lenovo doesn't provide a complete file, only the BIOS section. Is there any chance someone could repair it? I did a backup from the chip, attached. I also tried using another BIOS, slightly different revision. It worked and even I had a display working, but then Windows tried to update once again and it...
        10-24-2025, 11:19 AM
      • HammyCheesy
        Lenovo ThinkStation P720 BIOS Request
        by HammyCheesy
        Hello all,
        I'm trying desperately to revive a ThinkStation P720 that I purchased from a seller who claims it suffered a "failed firmware update."
        When given power, the machine turns on, spins up fans, beeps a single time, fans slow down, then a beep code is sounded repeatedly (3 high/short tones, 1 low/long tone).
        Type: 30BB
        Model Number: S03600
        S/N: MJ07N68C
        Things I have tried:
        1. Reseated all components, pulled everything except for 2 RAM modules (1 per CPU)
        2. Attempted to boot with just a single CPU...
        04-11-2025, 01:02 AM
      • grimacelord
        by grimacelord
        Hello there.
        History:
        03-15-2023, 03:29 PM
