[Request] Asus A320M-k updated BIOS Dump
  • abel2b
    • Mar 2009
    • 34
    Hello, anyone have BIOS Dump (ROM/BIN) for Asus A320M-K, dump has to be version 5862 or higher, so I can use with Ryzen 5 4600G CPU.
    I do not have a spare older generation compatible CPU to boot and update via Bios EZFlash Utiliy...
    Also I will be flashing via CH341A programmer with either (AsProgrammer, NeoProgrammer, Flashrom)
    I´ve tried the usual extraction of file with UEFITool --->
    Open the *.CAP file, do a right-click onto the listed "AMI Aptio capsule", choose the option "Extract body..." and save it as *.ROM file. from latest BIOS *.CAP file and later flashed with no luck... board will not POST anything
  • hoaca388
    Badcaps
    • Jan 2022
    • 11691
    Re: [Request] Asus A320M-k updated BIOS Dump
    Post your original corrupt bios here.
    • abel2b
      • Mar 2009
      • 34
      Originally posted by hoaca388
      post your original corrupt bios here.
      • abel2b
        • Mar 2009
        • 34
        According to Asus CPU support for this board, a Ryzen 5 4600G is supported or validated since BIOS Ver. 5862 so I downloaded latest version 6402…
        I connected my CH341A (Green) programmer with 1.8V adapter to the board.
        I identified pins as follows…
        Then I fired up NeoProgrammer V2.2.0.10, identified chip as Gigadevice GD25LQ128C [1.8V] and read data successfully and saved backup…
        OK so then I opened the updated BIOS CAP with UEFITool NE Alpha 59 , then - right-click onto the listed “AMI Aptio capsule”, choose the option “Extract body…” and save it as *.ROM file. (File size 16,384 KB)
        I then erased and verified blank chip with NeoProgrammer successfuly, then opened new *.ROM file and flashed, Successfully… I removed programmer cables, installed CPU and powered up… :frowning_face:
        It didn´t POST, boot or display anything (Fans running)
        I also have tried with no luck, manually editing *.CAP file with HxD and removing first 2048 bytes and saving as *.ROM, I also tried Asus CAP to Bin Tool to create *.ROM file, I tried flashing with CH341 programmer original soft, with AsProgrammer I even flashed with Flashrom for windows, in all cases no errors where displayed… yet Mother Board refuses to POST…
        SOOO! What am I doing wrong!
        what is the proper way to do it…
        Any help would be greatly appreciated…
        P.S please excuse my English, it is not my native tongue…
          • 20781
          Take the CMOS battery out before programming ,and use the clear cmos jumper afterwards. UEFITool has removed the CAP header ok 0 - 7FF (LENGTH 800)
          • abel2b
            • Mar 2009
            • 34
            Not Quite sure what you mean by (LENGTH 800) but I believe so....
            Just in case I will attach Asus website latest CAP file and extracted Bin by Uefitool please verify ... THX
              • 20781
              There is a difference between the 6402 i extracted and your file, theres a serial number in yours,i don`t know why,but it should be ok,take the cmos battery out and flash it .
              • abel2b
                • Mar 2009
                • 34
                OOH yeah the 6402 *.bin file, well I added DMI data from backup with FD44Editor_0.9.2 that is why serial number, UUID is there
                I´ll try in just a minute
                • abel2b
                  • Mar 2009
                  • 34
                  Take the CMOS battery out before programming ,and use the clear cmos jumper afterwards. (LENGTH 800)
                  Well I reflashed everything as instructed and no luck!
                  No video, post, beeep nothing just amber LED and CPU come on...
                  • abel2b
                    • Mar 2009
                    • 34
                    • abel2b
                      • Mar 2009
                      • 34
                      ??? nothing
                      • Bad_repair
                        • Jul 2022
                        I am also struggling with this board, using a CH341a the newer type with the built in voltage selector switch.
                        My board has a Winbond 25Q128FWSQ which is 1.8v, but the chip does not auto detect, I can manually select the closest chip which is the W25Q128FW [1.8] however if I try to erase the chip I get a "Probable erasure failure, check protection bits in status registers"
                        I am using the NeoProgrammer 2.2.0.8 with a clip over type device, I don't have to tools or skills to desolder due to very severe shaking, so can't avoid this option sadly.
                        I also get "verification error on address: "random hex address" " when I try to do any kind of "off-protect->erase->blank check->write->verify sequence.
                        Any help would be appreciated, maybe we can solve the problem for both of us. TIA for any help
                        • hoaca388
                          Badcaps
                          • Jan 2022
                          • 11691
                          Ch431A is a programmer with poor reliability. Flash the bios file for your chip, then read the chip again and compare with the original file to see if they are the same.
                          • Reda123456
                            hi
                            • Jan 2022
                            • 88
                            • iraq
                            need bios for Asus prime a320m-k
                            Hello i need the dump bios for this Motherboard becouse i have r5 4500 and i can't update the mb to make the cpu work in this mb
                            i need ver 5862 or higher than 5862
                            E307069 GE-1
                            • abel2b
                              • Mar 2009
                              • 34
                              I have no problem detecting chip or errors during write.. I did a comparison by programming chip, then read content with ASPprogrammer, NeoProgrammer and CH431 software, saved file and compared to original file with HexFlex and HXD and content is the same....
                              • abel2b
                                • Mar 2009
                                • 34
                                Re: need bios for Asus prime a320m-k
                                E307069 GE-1
                                Same here, still haven´t been able to get a dump from an updated "working" board...
                                • hoaca388
                                  Badcaps
                                  • Jan 2022
                                  • 11691
                                  Try again with 5862 version.
                                  • abel2b
                                    • Mar 2009
                                    • 34
                                    Is this actual 5862 BIOS dump or extracted from download ...?
                                    • hoaca388
                                      Badcaps
                                      • Jan 2022
                                      • 11691
                                      That file extracted from download. It's clean file.
                                      • xstage
                                        • Jul 2022
                                        • indonesia
                                        Has this problem been solved, I'm also facing the same thing, I want to upgrade the cpu to r5 4650g, the bios position is 5606 and can't update to version 5862 because I'm using a cpu a6 9500 which is not supported in bios 5862
