[Request] Asus A320M-k updated BIOS Dump
    • 21945
    Re: [Request] Asus A320M-k updated BIOS Dump
    Originally posted by xstage
    Has this problem been solved, I'm also facing the same thing, I want to upgrade the cpu to r5 4650g, the bios position is 5606 and can't update to version 5862 because I'm using a cpu a6 9500 which is not supported in bios 5862
    Can you post your bios backup
    • abel2b
      • Mar 2009
      • 34
      Well here´s an update, I managed to borrow an AMD Ryzen 3 2200G and with the updated 6402 that I downloaded, extracted and flashed chip, but that the Ryzen 5 4600G did not boot, I installed the the R3 and booted fine, checked the bios it said Ver. 6402, power down, I then swapped the R3 for the R5 and BOOOM! it booted...... WTF!
      • BELK
        • Oct 2022
        • Philippines
        can you post your ver.6402 bios dump?
        • regiman
          • Nov 2021
          • Argentina
          Hi Guys. Here I copy the Original Bios file of a working Prime A320M-K.
          • wengot
            • Jul 2023
            • Philippines
            I downloaded a bios file from asus and its 16mb and I need only 8mb..
            help please
            • hardware1
              • Sep 2021
              • 2948
              • N/A
              #26
              help please
              You should write your device model number, upload your BIOS Backup, take an image for the chip to see what is written on it and add the link of the official BIOS.
              all donations are welcome,
              • neeworam
                • Jun 2021
                • Philippines
                #27
                Hello there! I was wondering if you could help me figure out how to transfer my serial number and MAC address to a BIN file. Any assistance would be greatly appreciated. Thank you!
                • lucas357
                  • Jun 2021
                  • argentina
                  #28
                  alguien tiene la versión PRIME A320M-K BIOS 5220 directo de la placa?
                  Does anyone have the PRIME A320M-K BIOS 5220 version directly from the motherboard?
                  in English please..
                  • peste
                    • 13635
                    • ROMANIA
                    #29
                    in English please..
                    post the S/N, post the original content of the bios chip, the motherboard model, etc.
                    • SoporteNetFe
                      • Aug 2021
                      • 121
                      • Argentina
                      #30
                      in English please..
                      Try this...
                      • BrocKastillo
                        • Jul 2023
                        • Puebla
                        #31
                        Hello everyone! I have similar problems, I have an athlon 220G and I have 3 boards, all a320mk, 1 is a rev. 1.02 and the other 2 are rev. 1.04.
                        The plate rev. 1.02 has a macronix MX25U12873F eeprom, and it worked with the rom, 4011, while the rev. 1.04 have winbond 25q128fwsq eeprom, it doesn't work, I use CH341 with 1.8v, and AsProgramer, the rev. 1.04 turns on the led, and turns on the fan but gives no signal.
                        Does the eeprom have anything to do with it?​
                        Sorry, im using translate, im speak spanish...
                        • Vmalpica01
                          • Oct 2020
                          • 32
                          • Colombia
                          #32
                          Originally posted by SoporteNetFe
                          Try this...
                          Thanks, tested and working
                          • Citymin
                            by Citymin
                            S/N : 5RNK9FFT70...
                            08-05-2025, 05:12 AM
                          • Sebastian Codrean
                            BIOS file for ASUS F542UN laptop
                            by Sebastian Codrean
                            Hello to all of you! I need help with a BIOS file.
                            The BIOS chip is fried on my Asus F542UN laptop, and I bought a new chip that needs programming. I have a CH341a programmer but I need a .bin BIOS file. On Asus support page the firmware has another extension, .310 and from reading on this forum I understand that that file is not complete BIOS.
                            So, in short I need the "complete" BIOS .bin file to flash on the new chip. Another issue is that on back of the case the label says F542UN but on the sticker on the motherboard it's X542UN.
                            02-20-2025, 10:25 AM
                          • DynaxSC
                            by DynaxSC
                            06-14-2024, 03:49 PM
                          • jbonavita
                            by jbonavita
                            Some issues
                            Things I tried
                            04-29-2025, 09:38 PM
                          • kodox
                            Asus ExpertBook B1400CB Bios Dump Needed
                            by kodox
                            need original bios dump, original bios has flashed by other technician before me.
                            attached bios was read from the chip but no display and amperage fluctuating from 0.6A to 0.34 and back to 0.6A.
                            unit info:
                            Model: Asus ExpertBook B1400CBA-0711A1235U
                            S/N: R6NXNZ006657238
                            CN: 7F6F
                            Mainboard Code: B1500CBA R2.1...
                            08-16-2025, 12:20 PM
