Lenovo ideacentre 310S-08ASR BIOS
  • DiamondTech61
    • Aug 2021
    • 63
    • united kingdom
    Can I have a BIOS.BIN for lenovo FT4STMS VER 1.0 please
    I have a none POSTing PC, I have managed to get an original dump if that helps
    PC is ideacentre 310S-08ASR
  • hoaca388
    Badcaps
    • Jan 2022
    • 12394
    Re: Lenovo 90G0 BIOS
    Attach your original corrupt bios file.
    • DiamondTech61
      • Aug 2021
      • 63
      • united kingdom
      sorry forgot the important part
      • hoaca388
        Badcaps
        • Jan 2022
        • 12394
        Lenovo 90G0
        • maddex
          • Mar 2022
          • gorizia
          Re: Lenovo ideacentre 310S-08ASR BIOS
          Good morning.
          I have a corrupted bios of the same model in the discussion.
          I tried the repaired bios and now it works, but I knew it couldn't be good a lot of data is missing.
          Is it possible to repair this dump that I am attaching to you?
          thank you right now for the immense support.
          Marco
          • maddex
            • Mar 2022
            • gorizia
            Originally posted by maddex
            Good morning.
            Marco
            thanks i solved it by myself.
            I managed to merge between corrupt bios and empty bios.
            it works perfectly.
            • themosttogain
              • Jun 2022
              • 46
              Another No POST here...BIOS dump attached - is anyone able to repair please?
              Board model FT4STMS, Lenovo 310S-08ASR, serial PC17EMSN
              Thanks in advance!
              • hoaca388
                Badcaps
                • Jan 2022
                • 12394
                Thanks in advance!
                310S-08ASR Desktop (ideacentre) - Type 90G9
                • themosttogain
                  • Jun 2022
                  • 46
                  Thanks very much! Unfortunately this turned out not to be a BIOS issue. In their infinite wisdom, Lenovo added a foam surround on the bottom of the CPU cooler which seems to absorb any airborne moisture and corrode the capacitors on top of the CPU. There are several videos about it on YouTube like the one I've linked in case anyone else comes across this issue.
                  • lucaszmn
                    by lucaszmn
                    Problem:
                    Initial Findings:
                    • I concluded that the
                    08-12-2025, 03:01 PM
                  • max_sneka2
                    Lenovo Ideacentre AIO 24IHR9 Bios needed
                    by max_sneka2
                    Good Evening
                    Lenovo AIO Ideacentre 24IHR9
                    Working but no display
                    Bios Issue
                    Board Number JOC10 LA-N241P IRPLSC1 REV 1.0
                    S.N MP2G2K47
                    Machine Type F0HN
                    MTM F0HN00AJAK
                    MO MPNXS481301Y...
                    10-16-2025, 11:45 AM
                  • Wahaz
                    by Wahaz
                    10-30-2023, 08:42 PM
                  • grimacelord
                    by grimacelord
                    Hello there.
                    History:
                    03-15-2023, 03:29 PM
                  • to5it0
                    by to5it0
                    10-24-2025, 01:35 AM
