Asus ProArt Z690-CREATOR WIFI
  • uvaiz
    • Jan 2014
    • 113
    • saudi arabia
    hai,
    anyone have backup bios for Asus ProArt Z690-CREATOR WIFI
    bcz after updating bios my system is restarting,
  • peste
    • 12887
    • ROMANIA
    Re: Asus ProArt Z690-CREATOR WIFI
    Originally posted by uvaiz
    hai,
    post the bios here, just as damaged as it is ..
      • 21080
      hai,
      Download the bios from the support site https://www.asus.com/Motherboards-Co...HelpDesk_BIOS/
      Extract the zip folder and open the bios with UEFITool and select "Action" -> "Capsule" -> "Extract body" .That will remove the CAP header leaving you with the full bios.You can rename the file from rom to bin.If the newest one isn`t working try an older version.
      Most Asus retail motherboard bios can be extracted the same way.
      https://github.com/LongSoft/UEFITool..._A59_win32.zip
      • grimacelord
        by grimacelord
        07-10-2025, 02:52 PM
      • razor_amd
        by razor_amd
        12-15-2020, 07:07 PM
      • jbonavita
        by jbonavita
        Some issues
        Things I tried
        04-29-2025, 09:38 PM
      • throwaway327
        by throwaway327
        Model No: RC72LA
        Serial No: SBNVKD001014459
        06-18-2025, 05:52 PM
      • helpmepleasethanks
        Thinkpad T440P bios repair after WIFI whitelist mod
        by helpmepleasethanks
        As per the the rules, here are the specifications of my laptop :
        • Make and model number : Thinkpad T440P
        • Serial number (S/N) : PB-03A7V7
        • Model type - Model (MTM) : 20AW-S2N800
        • Bios version : 2.50 (not 100% sure, that's what I remember)
        Here is the problem, and the events leading to it :
        1. Upgrade screen, keyboard, trackpad, RAM and CPU
        2. Reboot and use the laptop for a bit : everything is working fine
        3. Shutdown (no power) and upgrade WIFI with unsupported chip (AX210)
        4. Boot up the device : bios warning, as expected
        5. Shutdown the device again (no power)
        6. Connect the 8-pin clip of a CH341a
        01-09-2025, 12:09 PM
