Bios for ASUS M5A78L-M/USB3
  • computeka
    • Apr 2021
    • 31
    • colombia
    ASUS M5A78L-M/USB3
    need bios pls
    • 21874
    Re: Bios for ASUS M5A78L-M/USB3
    Originally posted by computeka
    ASUS M5A78L-M/USB3
    need bios pls
    Did you look for it at Asus support https://www.asus.com/SupportOnly/M5A...HelpDesk_BIOS/
    • aboumohamed
      • Dec 2018
      • 258
      • algeria
      try this dump
      • mkdj
        by mkdj
        Dear all,
        10-19-2025, 04:41 AM
      • razor_amd
        by razor_amd
        12-15-2020, 07:07 PM
      • pirati
        by pirati
        Yesterday, 04:20 PM
      • DynaxSC
        by DynaxSC
        06-14-2024, 03:49 PM
      • Ahari
        by Ahari
        I...
        08-13-2025, 06:12 AM
