Lenovo 510s-08ikl desktop PC
  • wwbielsko
    • Aug 2008
    • 59
    Does anyone can make dump of BIOS from Lenovo Desktop PC:
    Lenovo 510s-08ikl
    or how to extract bios from IMAGEO2T.rom lenovo bios file to update ?
    regards
  • peste
    • 13562
    • ROMANIA
    Re: Lenovo 510s-08ikl desktop PC
    Lenovo 510s-08ikl
    regards
    What problem do you have??
    make a copy of the original bios and post it here.
    • wwbielsko
      • Aug 2008
      • 59
      PC is starting after turning on and restarting in loop.
      I had replace CPU with no results, so I would like to flash BIOS.
        • 21841
        Lenovo 510s-08ikl
        regards
        IMAGEO2T.rom is a 6MB update.Post your backup,and serial number .
        • wwbielsko
          • Aug 2008
          • 59
          Here is dump and SN as follows: DSCA011261
          • aboumohamed
            • Dec 2018
            • 258
            • algeria
            Try this dump
            • wwbielsko
              • Aug 2008
              • 59
              Thanks man, big up but unfortunately result is the same, fan is starting and stopping in loop
              So I think the problem is somewhere else.
                • 21841
                here,try this one .
                  • 21841
                  Maybe not. The bios you tried was from a IdeaPad 510S-14ISK laptop.The bios has been deleted.
                  • wwbielsko
                    • Aug 2008
                    • 59
                    Unfortunately, no results. Still the same. Ac adapter fan restarts every 2 seconds. 3V 5V ok, north bridge is little bit warm so it is starting, cpu is cold. I try to reflow northbridge with no effects. Some of dc converters is starting but turning off in loop.
                    • grimacelord
                      by grimacelord
                      Hello there.
                      History:
                      03-15-2023, 03:29 PM
                    • lucaszmn
                      by lucaszmn
                      Problem:
                      Initial Findings:
                      • I concluded that the
                      08-12-2025, 03:01 PM
                    • survivalbloke
                      Unable to extract bios file from Lenovo bios exectuable
                      by survivalbloke
                      I'm trying to extract a flashable bios file(ch341a) from the lenovo bios executable download. I have tried the instructions from this site https://starkeblog.com/lenovo/uefi/2...pdate-exe.html, which are not working. According to those instructions, after issuing the command
                      Code:
                      "innoextract 7wcn38ww.exe"
                      it should create an \app folder, inside which, I should find a newly created "7wcn38ww.exe" file. I should then be able to extract that using 7zip and find my .FD file.
                      The trouble I'm having is that I'm not getting the newly...
                      06-12-2024, 07:55 AM
                    • Wahaz
                      by Wahaz
                      10-30-2023, 08:42 PM
                    • survivalbloke
                      Unable to extract Lenovo BIOS file from installer
                      by survivalbloke
                      I'm working on a Lenovo LOQ 15APH8, Serial# MP2L9MAV. I want to flash a new BIOS onto it, but I'm also trying to learn this process for my own enrichment and professional development.
                      I was watching some tutorials, copying the serial info blocks from the old bios to a new bios. Before that though, they use innoextract on the Lenovo .exe. I downloaded Innoextract v1.9 but it tells me my .exe is not a supported inno setup installer(see screenshot). So if I unpack this using 7zip, I do get a .ROM file, but according to my tutorials, I'm looking for a .FD file.
                      How can...
                      07-16-2025, 03:21 PM
