ASUS dual rx580 8gb
  • nixi22
    • May 2016
    • 44
    • Croatia
    ASUS dual rx580 8gb
    Hi, im looking for schematics for ASUS dual rx580 8gb. Board model is D009PI2
    tnx
  • Borges
    • Dec 2021
    • 8
    • EspaƱa
    Re: ASUS dual rx580 8gb
    did u find it??
    • drewpcfix
      • Feb 2021
      • 13
      • philippines
      boardview for this?\
      • cbrcbr21
        • Nov 2020
        • 8
        • van
        pls
        • Tynan Dill
          by Tynan Dill
          Assuming...
          11-22-2024, 01:46 PM
        • m1ch43lzm
          by m1ch43lzm
          05-12-2025, 08:37 PM
        • Zakyn
          ASUS Radeon DUAL-RX580-O8G, randomly not working
          by Zakyn
          I am having issues to diagnose whats wrongs with ASUS Radeon DUAL-RX580-O8G, sometimes its not recognized/ no output, sometimes works fine for hours under 100% load (benchmarks/games). All voltages OK, BIOS chip replaced to be sure, what should I check next? I am guessing some solder balls cracked (maybe sometimes not connected), so should I do a reball?
          One thing that is suspicious, I run dmggy.py to check memories, the script output is all memory banks are fine, but during the test the screen sometimes go black and some artifacts blinked very shortly (not always the same collumns,...
          03-13-2024, 02:04 AM
        • DynaxSC
          ASUS STRIX Z490-F GAMING - No POST, stubborn board
          by DynaxSC
          I have this very stubborn ASUS mobo on the bench, and I already face the wall with it. It just refuses to POST, although everything seems to be OK.
          The situation looks like this:
          After connecting the board to the power supply on Nuvoton (SLP_S3#, pin 64), the Low signal (50 ohm resistance) appears immediately. PWRNTN# signal goes through Nuvoton to the chipset (confirmed after removing the chipset). The following conditions are then met for the chipset to generate the SLP_S3# signal:
          1. RTC oscillates normally (32.768KHz).
          07-08-2022, 05:45 AM
        • howardc64
          by howardc64
          07-24-2025, 05:17 PM
