ASUS Radeon DUAL-RX580-O8G, randomly not working
  • Zakyn
    • Aug 2023
    • 12
    • Česko
    I am having issues to diagnose whats wrongs with ASUS Radeon DUAL-RX580-O8G, sometimes its not recognized/ no output, sometimes works fine for hours under 100% load (benchmarks/games). All voltages OK, BIOS chip replaced to be sure, what should I check next? I am guessing some solder balls cracked (maybe sometimes not connected), so should I do a reball?
    One thing that is suspicious, I run dmggy.py to check memories, the script output is all memory banks are fine, but during the test the screen sometimes go black and some artifacts blinked very shortly (not always the same collumns, so hard to say which lines may have the problem).
    Thanks for any help
  • Zakyn
    • Aug 2023
    • 12
    • Česko
    I maybe have solved it, I noticed that circuit for DP bypass have tear away IC with two MOSFETS, according to schematic it detects dongle in DP and then bypasses HDMI 1 or 2. When i replaced it, GPU gives output, after few days of testing (multiple resets and stress tests). But I am not sure if it is just luck or it was realy it.
      AMD Radeon R9 290 / R9 380 / R9 390 Schematic & Board View
      The Radeon R9 290 was a high-end graphics card by AMD, launched on November 5th, 2013. Built on the 28 nm process, and based on the Hawaii graphics processor, in its Hawaii PRO variant, the card supports DirectX 12. This ensures that all modern games will run on Radeon R9 290. The Hawaii graphics processor is a large chip with a die area of 438 mm² and 6,200 million transistors. Unlike the fully unlocked Radeon R9 290X, which uses the same GPU but has all 2816 shaders enabled, AMD has disabled some shading units on the Radeon R9 290 to reach the...
      10-01-2024, 12:46 PM
      AMD Radeon RX Vega 56 / RX Vega 64 Schematic & Board View
      The Radeon RX Vega 56 is a high-end graphics card by AMD, launched on August 14th, 2017. Built on the 14 nm process, and based on the Vega 10 graphics processor, in its Vega 10 XL variant, the card supports DirectX 12. This ensures that all modern games will run on Radeon RX Vega 56. The Vega 10 graphics processor is a large chip with a die area of 495 mm² and 12,500 million transistors. Unlike the fully unlocked Radeon RX Vega 64, which uses the same GPU but has all 4096 shaders enabled, AMD has disabled some shading...
      10-01-2024, 01:07 PM
      AMD Radeon RX 470 / RX 580 Schematic & Board View
      The Radeon RX 470 is a mid-range graphics card by AMD, launched on August 4th, 2016. Built on the 14 nm process, and based on the Ellesmere graphics processor, in its Polaris 10 PRO variant, the card supports DirectX 12. This ensures that all modern games will run on Radeon RX 470. The Ellesmere graphics processor is an average sized chip with a die area of 232 mm² and 5,700 million transistors. Unlike the fully unlocked Radeon RX 480, which uses the same GPU but has all 2304 shaders enabled, AMD has disabled some shading units...
      10-01-2024, 12:52 PM
      Thermal pad thickness for various laptop GPU / Graphics Cards
      ASUS Dual RTX 2070 OC 8GB
      ASUS ROG STRIX RTX 3080 OC
      ASUS ROG STRIX RTX 3090
      ASUS TUF Gaming RTX 3080 OC Edition
      ASUS TUF GTX 1660 S-O6G GAMING
      EVGA RTX 3060 Ti XC GAMING 8GB
      EVGA RTX 3060 XC GAMING 12GB GDDR6
      EVGA RTX 3080 FTW3 ULTRA GAMING
      EVGA RTX 3080 TI FTW3 ULTRA GAMING
      EVGA RTX 3090 XC3 ULTRA GAMING 24GB
      Gainward RTX 2080 Phoenix GS Specs
      Gainward RTX 3070 Phoenix 8GB
      Gainward RTX 3080 Ti Phoenix
      GIGABYTE AORUS RTX 3080 MASTER 10G
      02-09-2024, 08:08 AM
      ASUS VivoBook ASUS VivoBook 15 S513 FHD i5 16GB/512GB G3 SSD Notebook 15 Specification for Upgrade or Repair
      This specification for the ASUS VivoBook ASUS VivoBook 15 S513 FHD i5 16GB/512GB G3 SSD Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the ASUS VivoBook 15 S513 FHD i5 16GB/512GB G3 SSD boardview and ASUS VivoBook 15 S513 FHD i5 16GB/512GB G3 SSD schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant...
      09-07-2024, 02:50 AM
