hi there..elitedesk 800 g1 sff working bios needed...i also checked hp site and extracted main rom from the file but it doesnt work...it seems its a general for this model but mine doesnt have any ati or nvidia gpu on board only intel...i also checked the 2 forums here that users shared bios files none of them worked too...mainboard had bad caps problems as usual and i replaced them all...same the psu...every thing is normal but i got no beeps..nothing at all only after few seconds fan spin higher...i think its corrupted bios may be the problem not super io...sadly dont have any cpu to replace and check this part too...i will post the extracted bios from mainboard and the recomended bios from hp here...if any one has the working dump bios file for this model and share it ,it would be great...thank you.
Tags: None
Re: elitedesk 800 g1 sff
The extracted hp file is the right one for this model,its a virgin bios ,if it hasn`t worked then the problem is somewhere else. -
finally i got a cpu to check if its the problem or not...cpu with this model was i5-4590.....i replaced it with pentium g3240 and it worked fine....it booted and no other problem were detected.Comment
NEED BIOS HP ELITEDESK 800 G1 SFF (Merlin Rev A)
SN CZC5140JF4
PRODUCT C8N26AV
OLD BIOS ATTACHEDAttached Filesif you find these attachements useful please consider making a small donation to the site
HP EliteDesk 800 G1 Base Model Small Form Factor PCAttached Filesif you find these attachements useful please consider making a small donation to the site
https://www.badcaps.net/donateComment
Thanks for urgent reply
Need bios for HP ELITDESK 800 G1 TWR (Merlin rev A)
SN CZC607B11P
Product no C8N27AV
Sir plz helpComment
Hi
Anyone can help me to clean ME region of my original bios file?
When I try to open it using Intel Flash Image Tool, got error
upload again yours backup
or try itAttached Filesif you find these attachements useful please consider making a small donation to the site
Actually i am from pak and there was problem in net and i failed to download yours backup file.
But which bios i uploaded up. its clean and 100% working. i tried it on so many sff pc. and everytime it works.
write bios on mx25l12805d
check batery cell and cmous jumper
if not get success then try to change the processor or ramComment
After a bios update the PC no longer starts, I wrote the bios above but the network card has lost the MAC address, could you help me thanksAttached Filesif you find these attachements useful please consider making a small donation to the site
Every donation made will go towards server fees and maintenance costs.Comment
by intelgHello everyone, I am looking for help as I am struggling to remove lost BIOS Admin password on an HP EliteDesk G6 800 series desktop. I wanted to reset the vPro remote control IP kvm for homelab use.
Here is the hardware identification specs:
HP EliteDesk 800 G6 Desktop Mini PC
Intel(R) Core(TM) i5-10500 CPU @ 3.10GHZ 16384 MB RAM
BIOS ver S21 Ver. 02.05.01 01/05/2021
Born on date: 07/26/2021
SN MXL11841GN
SKU 3X8V9UCHABA
UUID 8116E79EF6FFE94DB0B98A3188270C5C
SYSTEM BOARD ID 8710
SYSTEM BOARD CT NUKBER PJLHQ0A8JF236L...-
by macabookHello everyone,
🧩 Initial Issue- Board powers on (fans spin, keyboard lights up and can be adjusted, caps lock led lights), but no display or backlight
- External display (HDMI) shows
Channel: BIOS Requests ONLY!
07-24-2025, 02:17 PM -
by BrentH561Hello everyone, I am looking for help to make sure I am on the right track to remove lost BIOS Admin password on an HP EliteDesk G6 800 SFF. I recently purchased this on ebay and the seller is willing to accept a return but I have already installed my new HDs, NVME, and setup proxmox so I would like to keep it.
HP EliteDesk 800 G6 SFF
Serial No: MXL1223499
Product No: 26S74UT#ABA
BIOS/IC chip seems to be the 4 pin XMC XM25QH128A (3.3v). However most...-
by zlr8rlooking for a fully extracted (by programmer) Bios for a Dell Inspiron 17 (7786) v.1.09 or newer, so I can compare it with my own bios to check for corruption.
cheers
Dell Inspiron 17 (7786) Laptop
Service Tag: 5J0NHT2
Bios: 1.9.0
MOBO: RO 15 17 WHL 2GB MB / 18706-2
Attached;
1. My saved bios using a programmer
2. Dells Bios updater .exe (v1.16)
3. Dells Bios recovery file
4. What I got when i tried to extract the main bios .bin file from Dells Bios v1.16 exe/rcv using some .py script i found online.
5. Image of ME...-
by limannHello,
I need Bios for HP EliteDesk 800 G3 Mini 65W, please support
*Serial No : 8CG7427T48
*MB Info : Scorpius MB Rev A
16515-1
348.06N35.0011
*Proplem : No power on - 3 flashing red & 5 white, speaker : beep bep beep
Thank you...-
- Loading...
