have somebody start diagram for motherboards? MS-7817 water spill
  • ktmmotocross
    Boardkiller
    • Feb 2014
    • 3622
    • slovakia
    i have MSI H81M-E33 MS-7817 that not work after water spill.
    i need to check what is wrong.
  • dicky96
    Sun Seeker
    • Mar 2017
    • 1825
    • Spain
    Re: have somebody start diagram for motherboards? MS-7817 water spill
    Here is the boardview or schematic, maybe that will help
    Follow me on YouTube
    Learn Electronics Repair
    • dicky96
      Sun Seeker
      • Mar 2017
      • 1825
      • Spain
      Sorry forgot to attach the file lol
      • ktmmotocross
        Boardkiller
        • Feb 2014
        • 3622
        • slovakia
        thanks i allready have it. im more familiar with laptops.
        i dont know starting sequence of pc motherboards.
        board is poorly marked so BV will be aprisiated
        • dicky96
          Sun Seeker
          • Mar 2017
          • 1825
          • Spain
          Taxxan posted the Power On Sequence for H81 chipset here. His is a gigabyte board but same chipset would suggest the sequence is the same as your board
          https://www.badcaps.net/forum/showthread.php?t=96386
            20 year old Kenmore refrigerator ice maker bad water valve coil took a crap
            I got lucky that when I got home and was about to get some ice out of the ice dispenser I hear and see water running down the outside of the ice dispenser what the heck is going on here
            At first I thought that the ice dispenser mold was cracked so I brought a new ice maker because this one has been in there for about 10 years now
            Well I put the new one in and wait and I wait for the water valve to open and let water in no such luck well there is a way to check the function of the motor and the water valve on this ice maker just need a jumper wire “L” to...
            04-09-2023, 08:04 PM
          • betmen
            water pump Scala2 - electrical diagram
            by betmen
            Does anyone have a wiring diagram for the pump mentioned?
            The markings on the board are 98800964 r07, two or three capacitors are burnt.
            I don't have the board with me yet, but I don't know if the printed lines on the board are visible due to the short circuit that occurred and how the capacitors were connected.​
            05-22-2025, 02:56 AM
          • hs5424
            Dynacord powermate 1600 block diagram.
            by hs5424
            Hi All,
            I obtained a schematic diagram for the above mixer but I am wondering if a block diagram exists as I am trying to fix a problem in the protection circuit which I find a little confusing using a circuit diagram only. In the good old days the workshop manuals always had a block diagram with a circuit discription. Very useful for fault finding.
            The protection light is perminently on. The right sode has a -80DC on the feed to the speaker, hence the protection led on. I have removed all the O/P transistors which checked out OK. I tested all other transistors in circuit which seem...
            07-31-2025, 01:35 PM
          • Ugur87
            MacBook Air M4 A3240 Brand New Water Damage no Image
            by Ugur87
            I have a brand new 13.6-inch MacBook Air M4 that was only used for three days and now has water damage. A glass of water was spilled over it. I examined the motherboard and there was only water next to the display connector. I cleaned it with isopropanol and the components look clean. The MacBook obviously turns on and draws 20 volts from the power supply. The keyboard backlight comes on, but the display remains black. Where should I best start? Even when I shine a light on the display, I don't see any image. I have all the tools I need, including an infrared camera. Where should I best start?...
            08-28-2025, 01:09 PM
          • edugimeno
            Stagg sms12p audio amp has water damage
            by edugimeno
            Hi! My friend just brought this audio amplifier/speaker fro his music band saying they realized its got no sound. Led powers up but there no sound at all
            I opened it and found 3 board. 2 of them are for input plugs and potentiometers, and the other larger board has the amplifiers for 2 large speakers that it drives
            There's also a large toroid transformer that feeds a lower voltage to the first 2 boards and a larger voltaje (36x2 rectified close to 100v) to the power board. The power board has the plugs for both speakers
            There is only one signal wire connecting the first boards...
            05-24-2025, 06:00 AM
