Asus B250 Mining Expert motherboard schematic
  • doctorman
    • Mar 2021
    • 10
    • usa
    would really appreciate if I can get this boards schematics please
  • hady994
    • Oct 2021
    • Lebanon
    Re: Asus B250 Mining Expert motherboard schematic
    I also need one urgently.
    • doctorman
      • Mar 2021
      • 10
      • usa
      it is a deadend search, Asus will never release it.
      Ended up sending mine to Asus for repair
      • Remie9
        • Nov 2021
        • Mauritius
        I need the schematic too. Sending mine to ASUS will be the same cost as buying a new one.
        • glovecaps
          by glovecaps
          11-25-2024, 04:23 PM
        • dhenion
          Asus VivoBook F510UA-AH51 won't run on battery after motherboard replacement
          by dhenion
          I'm working on my sister's laptop: Asus VivoBook F510UA-AH51 - The motherboard died so I replaced it.
          The original board was:
          ASUS X510UNR REV 3.0 A
          The replacement board is:
          ASUS X510UNR REV 3.0 B (identical except B vs A - I couldn't find an A board anywhere. Visually they are identical.)
          It boots right up on the replaced motherboard and everything works fine on the new motherboard - but it won't run off battery. When I disconnect the charger it immediately dies. When I plug it back in and reboot the system - it still shows the battery at...
          01-30-2024, 01:45 PM
        • oragano
          ASUS ex-b250-V7 motherboard bios corrupted - by me
          by oragano
          hey all, i did a silly thing and flashed bios to perfectly working board. None of the asus official download bios would work with ez flash. They all gave error saying not supported bios file. I tried using uefi tool to extract it to a bin file but then ez flash wouldnt even recognise it.
          So, i used freedos and afudos with the aforementioned bin file i extracted and forced the issue. After bios reprogram, reboot and it was dead. Fans spinning but no post.
          i have a bios writer and none of the .cap files from the official site work either. I just get one spin, then off, then all fans...
          10-17-2024, 02:53 AM
          ASUS P5GC-MX motherboard recap
          by momaka
          Here’s another motherboard that needed a full recap: an ASUS P5GC-MX.
          This one was gifted to me some years ago by user Pentium 4, along with a few other goodies. It actually came in working order with no bulging or leaking caps. However, I noted there were United Chemicon KZG caps everywhere on the motherboard. The CPU VRM output (CPU V_core) was the only exception: it had only 2x KZG. The rest was 6x UCC TMV 4V 680 uF caps… which aren’t any good news either.
          So here is what the motherboard looked like with its original caps:
          CPU VRM area up close…...
          01-27-2021, 11:59 PM
        • EvazX
          ASUS ROG G513QY – RX 6800M powered but not detected intermittently + random crashes (Motherboard: 6050A3254002-MB-Axx)
          by EvazX
          I am working on an ASUS ROG G513QY laptop with RX 6800M dGPU.
          Originally, this laptop was completely non-functional. I replaced the motherboard (part number 6050A3254002-MB-Axx), and with the replacement board it started working fine.
          For a long time, the dGPU worked perfectly stable. I played several hundred hours on very demanding games such as Cyberpunk 2077 without any crashes, instability, or detection issues. Performance was excellent and there were no warning signs of failure.
          However, after some time, the replacement motherboard...
          08-25-2025, 06:09 PM
