Lenovo M900 iq1x0ms bios
  • hoaca388
    Badcaps
    • Jan 2022
    • 12314
    Originally posted by Nebukadnerzar_V
    Hi!
    I have a ThinkCentre M900 (Tiny), which won't POST. It turn's on, when AC is connected. Fan spins down after a while, so EC is working, but no picture and no beep.
    Hopefully, it can be fixed by cleaning the BIOS.
    Machine Type: 10FL
    Model Number: S1QS00
    S/N: S4BB8418
    Attached is the Dump.
    Thanks in Advance!
    M900 Desktop (ThinkCentre) - Type 10FL
    • Nebukadnerzar_V
      • Oct 2017
      • 24
      • Deutschland
      Thank you! That fixed the machine!
      Is there a tool or another way to transfer the DMI Data (S/N, UUID, Windows License) from the broken dump to the new BIOS?
      I found a "Lenovo DMI Decryptor" Tool on GitHub, but it was unable to find the DMI block in my dump.
      • hoaca388
        Badcaps
        • Jan 2022
        • 12314
        DMI is not in bios, it is in EC.
        • Nebukadnerzar_V
          • Oct 2017
          • 24
          • Deutschland
          Thank you for sharing this information!
          I am wondering, why my DMI is empty now after just flashing the Main-BIOS.
          I did not change the EC firmware. How can I get back the DMI data?
            • 21841
            Try the attached bios, your windows key has been added.
            To enter the DMI run the bios update executable. Read steps 6 and 7 in the README ,and input y instead on n to enter the serial number etc.
            Bios update - https://download.lenovo.com/pccbbs/t.../fwjybfusa.exe
            README - https://download.lenovo.com/pccbbs/t.../fwjybfusa.txt
            6. You will see the prompt "Would you like to update the Serial
            Number?". Input "n" and press Enter.
            7. Then you will see the prompt "Would you like to update the
            Machine Type and Model?". Input "n" and press Enter again.
            Then the BIOS update process will start.
            • Nebukadnerzar_V
              • Oct 2017
              • 24
              • Deutschland
              #26
              Thanks for the effort! However, with that file, the machine does not POST, like with the original dump.
              I don't know, whether the issue is actually in the "windows-key-section" or there is something else wrong.
              I reflashed the clean BIOS and reprogrammed the S/N and Type/Model, so the machine is working again.
              Also, Windows is still able to be activated, even though the Key is no longer present on the machine.
              I will like the machine as it is now and say Thank you for all the help!
              • woocashewski
                • Nov 2020
                • Polska
                #27
                hi. I have (two ) lenovo m800 sff, with iq1x0ms mainboards. I've dumped original bios and enable xeon compatibility by ME editor (it was long ago, so I dont remember exactly how I'm wondering... is there a way to enable RAID support on that motherboard? if so, please help me how. thanks in an advance. I'm using ch341 clip adapter, i can also desolder rom chip if necessary.
                • lucaszmn
                  by lucaszmn
                  Problem:
                  Initial Findings:
                  • I concluded that the
                  08-12-2025, 03:01 PM
                • Wahaz
                  by Wahaz
                  10-30-2023, 08:42 PM
                • grimacelord
                  Lenovo Legion T5-26AMR5 Desktop - Corrupt BIOS
                  by grimacelord
                  Hello there.
                  I am working on a Lenovo Legion T5-26AMR5 desktop that currently has a corrupt BIOS and I have been unsuccessful thus far in trying to fix it myself.
                  History:
                  1. This computer came to me initially with an error message that said "BiInitializeLibrary failed 0xc0000001" or "0135 fan error". It would always be one of the two errors. It should be noted that when it produced the fan error, there was no physical problem with the fans. They were all spinning just fine.
                  I searched for this error online and discovered...
                  03-15-2023, 03:29 PM
                • to5it0
                  Need Clean BIOS/EC Bin File for Lenovo ThinkPad Yoga 11e 2H1703-27220F Rev. A Marked as U2501 on the motherboard.
                  by to5it0
                  Need Clean BIOS/EC Bin File for Lenovo ThinkPad Yoga 11e - Stuck with 0275 Error CMS
                  I am attempting a repair on a Lenovo ThinkPad Yoga 11e that is currently stuck at boot with the error: "0275 error CMS" even after setup new bios battery and will not allow me to enter the BIOS/Setup.
                  This is a critical issue that I believe requires flashing the BIOS chip directly using a programmer (e.g., CH341A/RT809H), as standard software updates or resets are not possible.
                  I have opened the laptop and identified the main BIOS chip...
                  Yesterday, 01:35 AM
                • mkdj
                  Lenovo IdeaPad 3 - Hard Disk not recognized in BIOS
                  by mkdj
                  Dear all,
                  I have recently fixed a Lenovo IdeaPad 3 15 ALC6 that was not booting due to a BIOS issue. After flashing the BIOS, the laptop boots up, but hard disk is not recognized in BIOS. Is says "Hard Disk : Not Installed". I have tried with 2 different drives (one that I know is working on another laptop) but I get the same result. I do not know if disks were recognized before I got the laptop and fix it, but I don't see any reason why not. I can boot on USB though.
                  Here the steps I have taken to fix the laptop:
                  - downloaded latest BIOS from Lenovo Website...
                  10-18-2025, 03:43 AM
