Lite-On LCT-256M3S / Plextor PX-256M3S SSD firmware
  • pfrcom
    Oldbie
    • Jun 2006
    • 1230
    I have a Lite-On LCT-256M3S-41 which isn't detected
    Inside at U12 is a Winbond 25Q80BVNIG, a 1MB chip
    But inside Dell's LCT-256M3S-VRDD_ZPE.exe firmware update is file 1.BIN of 256KB
    I presume the 256KB is actual firmware code and remaining 768KB of the 1MB is parameters & control storage for that firmware
    Can anyone provide some insight and/or advise where the 256KB is located within the 1MB ?
    Or supply an update for the equivalent Plextor SSD in title
    Plextor support site just gives me 403 Forbidden for everything
    better to keep quiet and be thought a fool, than to open your mouth and remove all doubt
  • diif
    • Feb 2014
    • 6978
    • England
    Re: Lite-On LCT-256M3S / Plextor PX-256M3S SSD firmware
    Updates tend to be just that, an update, replacing just the outdated code but leaving the rest intact.
    it's an old drive, perhaps it's worn out.
    • zklgfs
      Anker SoundCore 2 Bluetooth Speaker Turns Off After a Few Seconds (Possibly Firmware Issue?)
      by zklgfs
      I have an Anker SoundCore 2 (A3105) that I saved from the trash (well, I guess there's a reason why it was supposed to go into the trash...). The problem is that it always turns off after a few seconds (sometimes it stays on a bit longer, between 30 and 60 seconds, but it still turns off). The power light turns on and the bluetooth light starts blinking, but both abruptly turn off again. The "turn off sound" is still played after the lights turn off. Sometimes, it also loops the on-off cycle several times without me pressing any buttons. If I connect an AUX cable, music...
      08-11-2025, 02:14 PM
    • TheUser
      Thinkpad Docker G2 Type-C 40AS - Firmware Unknown
      by TheUser
      Hello to everyone ,
      This is my first post here, and i would like to share with you a small story in case you can help me.
      Docker Type-C Gen 2 - Model 40AS. Was given to me by a friend for free ,but with the problem that you cannot use the video output ports.
      All ports work , USB , Ethernet, Type C ... but HDMI + Display Port don't work
      I searched on reddit and google for problem similar to that, and a LOT of people had fixed this problem by updating the firmware. So i tried , i searched and found 1.1.13 utility and 1.1.20 utility that can help...
      02-10-2024, 02:07 PM
    • gurj1979
      Ubiquiti firmware help. US-8-150W POE
      by gurj1979
      Hi guys.
      I've got a Ubiquiti US-8-150W POE switch which has issues with updating the firmware.
      Turned out to be a bad EEPROM chip. It would read the firmware and work as normal, but failed to write new firmware to it.
      So I took off the chip and read on EEPROM and saved it. Wrote to old chip and failed to write
      Got New chip and writes good.
      THE PROBLEM...
      It fails to fully load the firmware, POE lights fail to work during g firmware test during load. I'm suspecting bad EEPROM Read.
      Does anyone have a Good Firmware I can have?...
      07-22-2024, 05:13 PM
    • Slapito
      Request for EC firmware for MSI Vector GP66 12UHSO (MS-15441 ver 1.0)
      by Slapito
      I'm currently repairing an MSI Vector GP66 12UHSO laptop with a motherboard reference MS-15441 ver 1.0. The EC chip (ENE KB9548QF2) on the board appears to be damaged and needs to be reprogrammed.
      Can someone please send me the firmware (EC/Embedded Controller) or indicate where I can download the correct EC firmware version corresponding to this motherboard model?
      I already have access to the BIOS downloads on the MSI support page, but need specifically the EC binary or its equivalent firmware image.
      I already downloaded the BIOS update file from msi official...
      10-09-2025, 02:00 AM
    • wattage
      by wattage
      Hello Badcaps Community,
      07-13-2025, 04:41 PM
