H55+i5 520M OEM Mainboard BIOS Request
  • murat0606
    • Oct 2020
    • 18
    • Earth
    Hi guys, I need a help. The mainboard I showed in the photo has a problem with the BIOS. But this mb is OEM. (Label: 3-H55+i5) ?
    How can I find? Thanks.
    Regards.
    • 20888
    Re: H55+i5 520M OEM Mainboard BIOS Request
    Post your bios backup .
    • murat0606
      • Oct 2020
      • 18
      • Earth
      Sure, Thank you for your interest.
        • 20888
        Your backup dumps are both 1KB too long,also they are both badly corrupted. Are you using a CH341A programmer ?
        • murat0606
          • Oct 2020
          • 18
          • Earth
          Yes sir,CH341A programmer.
          I'm uploading again
          • murat0606
            • Oct 2020
            • 18
            • Earth
            Detail:
            American Megatrends Inc.
            Version: 080015 // INP55001
            12/21/15
              • 20888
              I'm uploading again
              The bios backup is better than the last ones but still corrupt.Are you using a clip or have you desoldered the chip ? .Try NeoProgrammer software and make another backup - https://www.badcaps.net/forum/showpo...04&postcount=7
              • murat0606
                • Oct 2020
                • 18
                • Earth
                Nope, Same again.
                  • 20888
                  have you desoldered it ? or are you using a clip
                  • murat0606
                    • Oct 2020
                    • 18
                    • Earth
                    Nope, using Clip.
                      • 20888
                      It would be better to desolder it.If you don`t have a hot air station you can still desolder using a soldering iron.Run the soldering iron with flux and solder accross 4 pins on one side while lifting slighty with tweezers until its just clear of the pads,then do the same at the other side. Then put the chip into a sop8 adapter, if you have one.
                      • murat0606
                        • Oct 2020
                        • 18
                        • Earth
                        Thanks for interesting. I probably won't find
                        • jbonavita
                          by jbonavita
                          Some issues
                          Things I tried
                          04-29-2025, 09:38 PM
                        • zenius
                          by zenius
                          12-08-2024, 06:13 AM
                        • Wahaz
                          by Wahaz
                          10-30-2023, 08:42 PM
                        • hotcrossedbuns999
                          M715q Desktop (ThinkCentre) - Type 10M3 - Request bios chip location and useable bios for use with CH341A Programmer.
                          by hotcrossedbuns999
                          My pc updated bios through Windows Update and I was greeted with BLACK SCREEN WITH CPU FAN MAX SPEED. I don't think there is even a screen signal, because it triggers my monitor for a couple seconds and then the monitor turns off. I tried the other outputs as well.
                          1. I tried clearing bios, resetting bios, removed the CMOS battery, removed m.2 ssd, wifi, and ram. Still black screen with CPU fan blasting.
                          2. I tried using the Lenovo BIOS CD and BIOS USB, but neither worked. At least I couldn't get anything to work.
                          3. I could only locate two chips that look like bios chips. Could someone verify this
                          01-03-2025, 12:32 PM
                        • macabook
                          by macabook
                          🧩 Initial Issue
                          07-24-2025, 02:17 PM
