HP AIO Pegatron IPISB-NK bios
  • Francisco.s
    • 686
    • Spain
    this AIO boot with blue screen asking for "Press the ESC key for Startup Menu".
    The problem is that doesn't work any of its usb ports, so keyboard is not detected.
    I've tested another bios pch-dump but doesn't solve. (the same blue screen)
    I think it is a problem with pch, but I would like to check the ec-bios before going any further.
    I have read this chip and attached its contents just in case someone can test it or share a good one.
    Thanks in advance.
    • 20844
    Re: HP AIO Pegatron IPISB-NK
    Post the full PC model number
    • Francisco.s
      • 686
      • Spain
      Hi SMDFlea,
      it is a HP TouchSmart 520-1002es.
        • 20844
        virgin bios ,no DMI . no ec.
        • Francisco.s
          • 686
          • Spain
          Thanks SMDFlea,
          this is one of the dumps I've already tested.
          Same problem with usb ports, tha's way I asked for a dump for ec- bios.
          Kbc chip is an IT8519e.
            • 20844
            I don't have the ec. It won't help anyway the problem is somewhere else, a USB controller chip,if there is one,or the PCH.
            • Francisco.s
              • 686
              • Spain
              Thanks for being interested in this post, you are are always helpful.
              I think there is not a usb controller chip, so most probably is a pch related issue.
              I will let you know how it is solved finally. ( if owner wants to repair it)
              • Francisco.s
                • 686
                • Spain
                Hi SMDFlea, you were wright, there are a damaged usb3 controller chip.
                It is a Texas Instruments TUSB7320, and as I said it is damaged and blocks the other usb2, that I think that sre controlled by the pch.
                I removed the TUSB7320 chip, and except usb3, all is working properly.
                I hope this post can help someone else to solve other similar issues.
                Thanks for your help.
                • antskull
                  • Aug 2017
                  • 17
                  • jakarta
                  thank you, same problem. waiting for TUSB7320 new ic.
                  • antskull
                    • Aug 2017
                    • 17
                    • jakarta
                    https://www.aliexpress.com/item/1005...d=sgt1zfnFk1Z1
                    • Errol Reyes
                      • Mar 2020
                      • 5
                      • Philipines
                      Thanks you working
                      • nasirahmad52
                        Banned
                        • Sep 2014
                        • 8
                        • Bangladesh
                        Originally posted by Errol Reyes
                        Thanks you working
                        Alhamdulillah, TUSB7320 IC bad, Remove and All ok
                        • YOUN
                          • Feb 2015
                          • 79
                          • Burkina faso
                          i want ec for hp 4300 IPISB IK
                          THANK !
                            SMDFlea commented
                            Editing a comment
                            Off topic, start your own thread.
                        • labcleyton
                          • Aug 2021
                          • brazil
                          Retirei o TUSB7320RKM e tambem resolveu o problema. Obrigado
                          English translation - I removed the TUSB7320RKM and it also solved the problem. Thanks​
                          • otgava
                            • May 2021
                            • 9
                            Hi All
                            Jun 2025 still the same, removed this chip and system booted up! Thank you.
                            • kamkooltech
                              kamkooltech
                              • Jun 2019
                              • 107
                              • nigeria
                              worked for me
                              • macabook
                                by macabook
                                🧩 Initial Issue
                                07-24-2025, 02:17 PM
                                by Vesko356
                                08-11-2023, 03:27 AM
                              • jbonavita
                                by jbonavita
                                Some issues
                                Things I tried
                                04-29-2025, 09:38 PM
                              • zenius
                                by zenius
                                12-08-2024, 06:13 AM
                              • Wahaz
                                by Wahaz
                                10-30-2023, 08:42 PM
