Acer XC100 bios
  • lezsimply
    The Wanderer
    • 657
    • Philippines
    Acer XC100 bios
    Good Day, need bios dump for this system. All voltage are ok but no display after pressing power button. Motherboard code is D1F-AD ver.1.0A. Thanks
  • peste
    • 13562
    • ROMANIA
    Re: Acer XC100 bios
    make a copy of the original bios of the laptop and try this.
    • lezsimply
      The Wanderer
      • 657
      • Philippines
      Re: Acer XC100 bios
      Ok I'll try your bios. Don't know what's wrong with stock bios but I uploaded it. Thanks!
      • German Velasco
        • Nov 2024
        • Colombia
        HOLA SE TE SOLUCIONO?
        HELLO, WAS IT SOLVED FOR YOU?
        in English please..
        • James194zt
          Acer Nitro 50-640E Corrupted BIOS Dump
          by James194zt
          My daughter has accidentally managed to kill her Acer gaming desktop it has a blank screen after updating and when you press the power button the fans spin, light comes on and it makes 1 long and 1 short beep and no attempt to boot.
          All basic troubleshooting has been done we replaced CPU, GPU and RAM from a working machine and no joy, I also noticed a post on here with the same issue and it was the BIOS. I am pretty sure also because it was doing a BIOS update that stopped it working, she knocked the keyboard out by accident during the update and the screen just went...
          04-28-2025, 03:29 PM
        • Ahari
          by Ahari
          I...
          08-13-2025, 06:12 AM
        • mkdj
          by mkdj
          Dear all,
          10-19-2025, 04:41 AM
        • Habble7
          by Habble7
          Suspected Cause:
          Troubleshooting Attempts:
          05-22-2025, 07:28 AM
        • x14nl34l
          Acer TravelMate p614 (tmp614-51-g2-5442) bios dump
          by x14nl34l
          Hi, I need a bios dump for my Acer TMP614 (tmp614-51-g2-5442 bios dump). Thanks.
          09-01-2025, 09:54 PM
