H81m-e/m52ad/dp_mb
  • kesmeseker
    • Jan 2015
    • 117
    • turkey
    H81m-e/m52ad/dp_mb
    Hi . I need H81M-E/M52AD/DP_MB bios dump. please help
    thanks.
  • kesmeseker
    • Jan 2015
    • 117
    • turkey
    Re: H81m-e/m52ad/dp_mb
    case asus K31ad
    • peste
      • Dec 2016
      • 12729
      • ROMANIA
      Originally posted by kesmeseker
      case asus K31ad
      post the original bios
        • 20781
        case asus K31ad
        Download the bios from the support page,open the bios with UEFITool , select "Action - Capsule - Extract Body" that will remove the 2KB header from the 8,194KB bios leaving you with the 8,192KB bios .
        https://dlcdnets.asus.com/pub/ASUS/D...K31AD-0604.zip
        https://www.asus.com/Tower-PCs/K31AD/HelpDesk_BIOS/
        https://github.com/LongSoft/UEFITool..._A57_win32.zip
        • kesmeseker
          • Jan 2015
          • 117
          • turkey
          thanks. its tray
          • kesmeseker
            • Jan 2015
            • 117
            • turkey
            thanks working.SMDFlea
            • DannyHo
              • Apr 2018
              • Taiwan
              Thanks for sharing. The bios file is working to let my PC alive.
              • Habble7
                by Habble7
                Suspected Cause:
                Troubleshooting Attempts:
                05-22-2025, 07:28 AM
              • DynaxSC
                by DynaxSC
                11-17-2023, 10:56 AM
              • MDSI
                HP OMEN 17-an012nf BIOS dump with EC (DAG3BAMBAF0 REV : F)
                by MDSI
                I'm requesting a full BIOS dump (including EC firmware) for an HP OMEN 17-an012nf laptop.
                Details:
                Model : HP OMEN 17-an012nf
                Motherboard Part Number : DAG3BAMBAF0 REV : F
                Serial Number (S/N) : 5CD7280D51
                BIOS chip : Winbond W25Q64VSIQ
                Programmer : EZP2023+
                Issue : The motherboard is not powering on. Only the 5V rail is present. The 3.3V rail is missing because EN1 on the SY8286B remains stuck at 0V. This signal is driven directly by the EC/SIO. I replaced the 3.3V regulator and confirmed it's working.
                I already...
                Today, 07:11 AM
              • grimacelord
                Trying To Find UUID In BIOS Dump - HP 14-dq0055dx
                by grimacelord
                This laptop is the same laptop I was working on in this thread and I wasn't sure if I should post a new topic or post in that thread because I already solved the issue that thread was discussing and this is a completely different issue although it is dealing with the same laptop. I decided to make a new thread since it's a new issue, but please move if I made a mistake.
                Motherboard model number: DA0PAMB46A1 REV: A
                Secondary motherboard model number: 0PAB
                SKU: 685K4UA
                Serial number is: 5CD3223BJP
                Recently reflashed this laptop with latest BIOS and once...
                05-07-2024, 08:06 AM
              • DynaxSC
                Who has a MSI Z590 PRO WIFI - Need BIOS dump ?
                by DynaxSC
                I need a BIOS dump for MSI Z590 PRO WIFI from a real physical board, along with MAC address and serial no.
                It must be a dump from a physical board, as it contains personalized data eg. MAC Address, UUID, Serial no.
                I have a board which has lost the BIOS contents, I have the MAC and serial to this board, and need to insert it into the another BIOS image. To do it, I need to have a real image from a real board, as the images from the MSI site are without this data. The only way to find where MAC/UUID/Serial is located in the BIOS is to have a bios...
                11-06-2022, 05:22 PM
