H81m-e/m52ad/dp_mb
  • kesmeseker
    • Jan 2015
    • 121
    • turkey
    H81m-e/m52ad/dp_mb
    Hi . I need H81M-E/M52AD/DP_MB bios dump. please help
    thanks.
  • kesmeseker
    • Jan 2015
    • 121
    • turkey
    Re: H81m-e/m52ad/dp_mb
    case asus K31ad
    • peste
      • Dec 2016
      • 13562
      • ROMANIA
      Originally posted by kesmeseker
      case asus K31ad
      post the original bios
        • 21841
        case asus K31ad
        Download the bios from the support page,open the bios with UEFITool , select "Action - Capsule - Extract Body" that will remove the 2KB header from the 8,194KB bios leaving you with the 8,192KB bios .
        https://dlcdnets.asus.com/pub/ASUS/D...K31AD-0604.zip
        https://www.asus.com/Tower-PCs/K31AD/HelpDesk_BIOS/
        https://github.com/LongSoft/UEFITool..._A57_win32.zip
        • kesmeseker
          • Jan 2015
          • 121
          • turkey
          thanks. its tray
          • kesmeseker
            • Jan 2015
            • 121
            • turkey
            thanks working.SMDFlea
            • DannyHo
              • Apr 2018
              • Taiwan
              Thanks for sharing. The bios file is working to let my PC alive.
              • Ahari
                by Ahari
                I...
                08-13-2025, 06:12 AM
              • mkdj
                by mkdj
                Dear all,
                10-19-2025, 04:41 AM
              • Habble7
                by Habble7
                Suspected Cause:
                Troubleshooting Attempts:
                05-22-2025, 07:28 AM
              • haitham sharabati
                [Request] Clean BIOS dump for HP 15-da2007ne (8XF55EA#ABV) - N4000 - BIOS Lock
                by haitham sharabati
                Hello engineers 😀,
                I’m kindly requesting a clean and unlocked BIOS dump for the following HP laptop, as it’s bricked after flashing SP152727. The system now keeps rebooting, and the original issue was an Administrator / Power-On Password that I can no longer access.😏
                🔧 Device Info:
                - Model: HP 15-da2007ne
                - Product Number: 8XF55EA#ABV
                - Serial Number: CND0338P0D
                - CPU: Intel Celeron N4000
                - EC/BIOS Chip: [Add chip number from the motherboard or BIOS chip]
                💀 Problem:😅
                - Device shows “Administrator Password”...
                08-07-2025, 04:54 AM
              • Citymin
                by Citymin
                S/N : 5RNK9FFT70...
                08-05-2025, 05:12 AM
