Sup guys, i recently purchased an imac from ebay that was supposed to work but the seller scammed me and sold me a mac that was firmware locked. 2 months of headaches and learning, i was able to get the bios chip out without damaging the computer . Is this firmware impossible to bypass, and if not, how can i clean it so that the firmware password gets removed?
2019 iMac 21.5''
Re: 2019 iMac 21.5''
Open the bios with a hex editor and search for $SVS ,then fill the region you select with FF`s . There are lots of videos on youtube showing how its done https://www.youtube.com/watch?v=KCl6Iu8fSSI
.Last edited by SMDFlea; 08-02-2020, 06:57 AM. -
Please see attached clean. Re-program the bin file to the EFI chip and PRAM at the first start.Comment
Hi friends.
Please help to clean me for this bios file of iMac 27" 5K 2019 (A2115 EMC 3194)
Board number 820-01236.
Pulled the bin file that i attached in this post from a normal same model iMac
But with that file in my current iMac always restarting after several minutes of operation.
And also i already tried several method to clean the me region of this file, but always end up with file system state "error" at ME Analyzer.
Any help would be appreciated.
Thanks in advance...-
by chkintl93Hi,
Is there any one who can help unlock the efi firmware file attached?
It is for Apple iMac 27" A2115 2019.
Appreciate the help....-
by jprezaHey guys,
Looking for schematics for an iMac 4k 2019 model. For the life of me, I can't figure out why the display will not work.Everything is connected correctly, I don't see any caps or resistors that are damaged. I even swapped the display from another iMac 4k 2019 model to test it, and that display won't work either.
There are 5 diagnostic LEDs and only 4 light up. The last one does not.
Any help with schematics would be awesome!
JP-
by learnmoreHello Badcaps Community,
If anyone has it or can point me in the right direction, I'm after the following:
BIOS & FIRMWARE FOR Samsung QE55Q60TAUXXU DFVC2038 BN41-02756B-000 DATE: 2019.12.17
The mainboard and Tcon are combined into one board which has three memory ICs: 1 eMMC and 2 Winbonds
eMMC: THGBMJG6C1LBAIL
Bios (Flash memory): Winbond 25Q80DVSIG AND Winbond 25Q40CL (next to GPU)
Thanks in advance,
LL​03-04-2024, 08:51 AM -
by TheUserHello to everyone ,
This is my first post here, and i would like to share with you a small story in case you can help me.
Docker Type-C Gen 2 - Model 40AS. Was given to me by a friend for free ,but with the problem that you cannot use the video output ports.
All ports work , USB , Ethernet, Type C ... but HDMI + Display Port don't work
I searched on reddit and google for problem similar to that, and a LOT of people had fixed this problem by updating the firmware. So i tried , i searched and found 1.1.13 utility and 1.1.20 utility that can help... - Loading...
