Apple iMac 27" A2115 2019 efi firmware UNLOCKED
  • chkintl93
    • Jun 2019
    • 47
    • usa
    Is there any one who can help unlock the efi firmware file attached?
    It is for Apple iMac 27" A2115 2019.
    Appreciate the help.
  • peste
    • 13317
    • ROMANIA
    Re: Apple iMac 27" A2115 2019 efi firmware UNLOCKED
    try..
    • chkintl93
      • Jun 2019
      • 47
      • usa
      Thank you for the prompt response. I'll try and give you feedback in 2 days.
      Thanks again for the great help.
      • chkintl93
        • Jun 2019
        • 47
        • usa
        Originally posted by peste
        try..
        I tried the file, but it did not work. Any idea?
        Thanks again
        • imranromi
          • Jan 2015
          • 1290
          • Pakistan
          You sure this is not T2 model?
          • piernov
            • Jan 2016
            • 4437
            • France
            No, T2 is only found on the 2020 model.
            • MobileXT
              • Oct 2012
              • 214
              Try this one. Make sure you do PRAM reset.
              • Chozo69
                Senior Tech
                • Oct 2019
                • 6
                Hi, I've tried this one and the iMac will not boot into an OS. It loads for a while then reboots.
                • reeza_plus
                  • Aug 2015
                  • 57
                  • canada
                  hi can someone help unlock the efi firmware file attached?
                  Apple iMac 27" A2115 2019 emc 3194.
                  • peste
                    • 13317
                    • ROMANIA
                    try..
                    • anapospastos
                      • May 2023
                      • Greece
                      Hi all! I have an iMac 2019 27" A2115 EFI locked. Pressing the option button during boot doesn't give me any options to boot from a usb stick. Just the apple logo.
                      I have attached the original bios file. Can someone unlock it? I've already tried 2 different bios files I found here and there but no luck so far. Thanks in advance guys!
                      • peste
                        • 13317
                        • ROMANIA
                        try...
                        • anapospastos
                          • May 2023
                          • Greece
                          try...
                          Thank you for the response! Unfortunately it doesn't work. The apple logo is not showing up at all after flashing this file. Do you have any suggestions or a different version to try out?
                          • peste
                            • 13317
                            • ROMANIA
                            try the blocked bios again.. see what happens..
                            • ExoHe
                              • Sep 2023
                              • usa
                              Hello, I've A2115 with winbond EFI chip. ( W25Q128JVSQ ) . Can I use the attached file starting with mx in this topic ? Or how to find original EFI firmware file for A2115 ?
                                • 21577
                                Originally posted by webhost
                                its was a mistake , before i attach another bios dump
                                found here the original dump
                                thank You
                                Please read the updated rules,serial numbers are now required.
                                https://www.badcaps.net/forum/showthread.php?t=103569
                                • mccorklelife
                                  • Jan 2025
                                  I have a 27" imac 2019 model that is stuck on the apple logo. I'm not sure if this is the right approach but I accidentally had a usb containing a firmware.bin for my 3d printer, i'm wondering if it reset something? Otherwise I've been booting off my new 2tb external ssd and after installing a driver for it the restart brought me back to apple logo. I can't get back to recovery or anything to ensure I have the "allow boot from USB" but it's done it ok before. Any suggestions? I have another mac I could connect if needed.
