I need bios on this biostar A58MD Ver. 6.8 please. Ill try downloading on the site but it is exe file can someone help
					need bios on biostar A58MD desktop motherboard
	Tags: None
 Re: need bios on biostar desktop motherboard
 try...
 https://drivers.softpedia.com/get/BI...BIOS-B05.shtmlDue to a lack of donations, server free space at a critical level, and possible closure of Bios Requests all donations are welcome, click:
 thanks i already done flash the bios at first it turns on and display comes after i shut it down , it cannot turn on again unless i removed the cmos battery but if i plugged the cmos battery it cannot turn on please help on thisComment
 Re: need bios on biostar A58MD desktop motherboard
 Assuming the CMOS battery is indeed 'good' - a couple possibilities come to mind:
 - Corrupted BIOS - Clear CMOS via 'JUMPER' method; failure = Re-Flash BIOS
 - Above fails - Possible bad PSU; try different PSU.Comment
			by glovecapsHello,
			by to5it0Need Clean BIOS/EC Bin File for Lenovo ThinkPad Yoga 11e - Stuck with 0275 Error CMS
 I have opened the laptop and identified the main BIOS chip...2 Photos-
							Channel: BIOS Requests ONLY!
			My pc updated bios through Windows Update and I was greeted with BLACK SCREEN WITH CPU FAN MAX SPEED. I don't think there is even a screen signal, because it triggers my monitor for a couple seconds and then the monitor turns off. I tried the other outputs as well.- I tried clearing bios, resetting bios, removed the CMOS battery, removed m.2 ssd, wifi, and ram. Still black screen with CPU fan blasting.
- I tried using the Lenovo BIOS CD and BIOS USB, but neither worked. At least I couldn't get anything to work.
- I could only locate two chips that look like bios chips. Could someone verify this
			Can anyone post a complete bios dump for a Gigabyte GA-MA74GM-S2 Rev 1.0 desktop motherboard please?
 I have a dead motherboard - with no obvious signs of damage which I would like to save from scrap
 Many thanks for any help-
			by dnytwaryorsHello Everyone, Can you help me clean this bios backup I have? It won't display. I'll try everything related to display and my last option is bios, Thank you.
 This is my backup bios...-
- Loading...
