Hp pro one 400 G2 PCB: 6050a2716601 A01
  • bilen
    • Aug 2014
    • 637
    • istanbul
    Bios update and restart. No video screnn help me.
    old bios :
  • mcplslg123
    • Jun 2015
    • 7262
    • india
    Re: Hp pro one 400 G2 PCB: 6050a2716601 A01
    Try this bios.
    • bilen
      • Aug 2014
      • 637
      • istanbul
      Try this bios.
      power on and video screen : manufacture programming mode is in unlock mode (34) .....
      0 and no power
        • 21869
        0 and no power
        Try this one .
        • bilen
          • Aug 2014
          • 637
          • istanbul
          Originally posted by SMDFlea
          Try this one .
          problem persist
            • 21869
            Did you remove the cmos battery before flashing the bios ? .Try these other dumps
            https://www.badcaps.net/forum/showthread.php?t=69041
            https://www.badcaps.net/forum/showthread.php?t=75452
            • bilen
              • Aug 2014
              • 637
              • istanbul
              i shared pictures
              When it is 0 it does not open again
                • 21869
                You are flashing the bios with a programmer ?
                • bilen
                  • Aug 2014
                  • 637
                  • istanbul
                  yeah
                  • imranromi
                    • Jan 2015
                    • 1290
                    • Pakistan
                    Red error gone about restart more 31 time you can add manually serial number or dmi info..
                    And show Serial number error?
                    • mcplslg123
                      • Jun 2015
                      • 7262
                      • india
                      Yes, @imranromi is correct. Has faced this on a couple of HP's. You dont need to do anything. Just flash bios and let the pc restart a total of 31 times and after that . the red line will go away and it will boot normally. You need to add dmi info only after that.
                      • iZakre
                        HP Pavilion 15 bc400ns - Complete Black Screen - Only video on live usb
                        by iZakre
                        Hello everybody!
                        To put you in context I recently replaced the battery from my HP Pavilion 15 bc400ns with a used one, everything was going good. The same day, I decided to update the BIOS, everything went good. The thing occurred after I let the battery drain iddling on Windows 11 for the second time to calibrate it that the screen did not turn on again, the computer was on but the screen did not turn, like it would not wake from hibernation. I decided to restart the computer but got no video.
                        The thing is that I had installed TeamViewer and could log into the computer...
                        02-19-2023, 02:27 PM
                      • mikeybass
                        by mikeybass
                        04-23-2025, 04:30 PM
                      • akwky
                        by akwky
                        Hi!
                        04-14-2025, 01:56 PM
                      • al3m0di
                        Update bios EFCN58WW to EFCN59WW
                        by al3m0di
                        Update bios EFCN58WW to EFCN59WW for solving The Connected AC adapter has a lower wattage than the recommended AC adapter
                        I have a Lenovo Legion 5 15imh05a device that I bought used online. It came with a 20V 8.5A 170W charger.
                        The BIOS version is EFCN58WW.
                        When I turn on the device, it displays the message:
                        "The Connected AC adapter has a lower wattage than the recommended AC adapter..."
                        The device rarely charges the battery, and even when it does, it doesn't show that it's charging.
                        I've tried
                        07-29-2024, 10:32 AM
                      • capoplays
                        Help with BIOS update on Dell G15 5515 after chip replacement
                        by capoplays
                        Hey everyone,
                        I recently bought a Dell G15 5515 with an AMD Ryzen 7 5800H and 3060 RTX. The BIOS chip on it was dead, and my hardware guy replaced the chip. After that, everything was working fine.
                        The BIOS is currently at version 1.22.1, and I wanted to update it. I downloaded the latest BIOS version from Dell Support using my ST: FQZMYJ3, but when I tried to run it, it says "unsupported system." I asked my tech guy what he did, and he said he took the chip from another board and flashed it onto mine.
                        When I check the BIOS using the F12 menu Flash...
                        10-24-2025, 06:53 AM
