Lenovo C50-30 bios dump needed, please!
  • Dstecno
    • Jun 2019
    • 30
    • México
    hello everyone in the forum, I have a C50-30 lenovo with symptoms of failure in bios, in the page of lenovo is the bios, but in binary format and even I have tried with different options I have not managed to extract the FD or the ROM in format to write it with the programmer, someone can support me with a functioning dump, greetings.
    Board
    IHSWSW
    13138-1
    PIBoardwellF/C5030
  • peste
    • 13550
    • ROMANIA
    Re: Lenovo C50-30 bios dump needed, please!
    try..
    • Dstecno
      • Jun 2019
      • 30
      • México
      thanks i will try, then tell you...
      • shutt1e
        • Nov 2015
        • 15
        • italy
        ec bios dump please?
        tia
        • shutt1e
          • Nov 2015
          • 15
          • italy
          found it myself, posting here becase this seem very hard to find
          • zigana
            • Aug 2013
            • 41
            • turkiye
            thanks
            • playmedia
              Playmedia
              • Jul 2018
              • 20
              There are 2 x bios chips by the looks of it, is it the same bios file for both???
              • peste
                • 13550
                • ROMANIA
                no ..there are different bios ...
                • Elextroemsland
                  • Jan 2021
                  • 13
                  • Deutschland
                  Originally posted by peste
                  try..
                  It's not working! Can't extract file. Does someone has the bios maybe both?
                  • peste
                    • 13550
                    • ROMANIA
                    post the backup of the bios
                    • Elextroemsland
                      • Jan 2021
                      • 13
                      • Deutschland
                      Don't have any bios for it, the thing is I bought one with no screen but start up,
                      Than I forgot to save the old one and clear the chips both, and now I try both bios, (the ec bios for the 25l8006e, and the normal bios for the 25l6473e)
                      But now nothing happen no light on the powerbotten nothing)
                      What did I done wrong.?
                      And when I write the ec bios (1MB) it's say complete writing, but I I want try to read it (so I make sure, the writing was successful) nothing is on the chip.
                        • 21841
                        Is your programmer a CH341A ?
                        • Elextroemsland
                          • Jan 2021
                          • 13
                          • Deutschland
                          Yes
                          • Elextroemsland
                            • Jan 2021
                            • 13
                            • Deutschland
                            hey guys, now i thought maybe i will give it with a nother try to repair it....and now the 25L8006E is light up on the flasher on run always ...cant read cant write or delete....is it broken or do i need to desolder it from the MB to write/delete it
                            other question is : is there only one Bios hier uploaded and is it working?
                              • 21841
                              Try these alternative CH341A software
                              https://www.badcaps.net/forum/showpo...04&postcount=7 NeoProgrammer
                              https://www.badcaps.net/forum/showpo...6&postcount=10 AsProgrammer
                              • djharold
                                • Aug 2015
                                • 246
                                • COLOMBIA
                                thanks
                                • RxTx
                                  • Nov 2013
                                  • 12
                                  • Turkey
                                  Originally posted by RxTx
                                  test ok
                                  test ok
                                  • Elextroemsland
                                    • Jan 2021
                                    • 13
                                    • Deutschland
                                    can i ask you guys again , so my bios chips arrived and whats the 25l8006e and whats the 25l6473e so which one is EC and which is the Bios
                                    • FARIDIQBAL
                                      • Oct 2017
                                      • pakistan
                                      I have a strange problem with this AIO. The hard disk is not recognised in the BIOS, but the HDD itself if removed and connected to another PC is recognised. I tried the same thing with another HDD, still the same. I thought there was a problem with a SATA cable or even the power connection so i changed the sata cable and gave power to the HDD from an external source. Still nothing. Then I tried upgrading the BIOS (with a windows live cd, because the procedure was to be done from within windows), and still nothing. Has anyone else ever had this problem. I'm considering buying the motherboard, but it should be an expensive solution
                                      • Dstecno
                                        • Jun 2019
                                        • 30
                                        • México
                                        I've seen several AIO lenovo with problems in the sata power cable, you can try with another sata power cable, in my case the easy way to fix it is: cut the sata power cable by the middle and paste a working connector from another power supply, i hope this work for you.
                                        • Joluvillas
                                          Lenovo ThinkPad L15 Gen 1 i7 (20U4) Bios and EC dump needed
                                          by Joluvillas
                                          Hi all! I was reading on tutorials how to flash a bios to remove password from a bios, and I ended up reading the EC chip instead of the main bios chip, it only gave me a .bin file of 1,024kb, I learned later that that is the EC chip not the main bios chip (I should have read the tutorials here instead before attempting anything, my bad), I went to flash the original backup, the 1,024kb size file into the same chip and laptop is not powering up anymore. I may have screwed the chip or even the motherboard (Hopefully not), I am trying to see if there is a fix before I discard it. I had a couple...
                                          06-18-2024, 10:35 PM
                                        • AHmad_Salal
                                          Need BIOS Dump/ROM for Lenovo Thinkstation p500
                                          by AHmad_Salal
                                          Hello all,
                                          I have a Lenovo Thinkstation P500 that is stuck at post with no display, it happened after I changed the memory timings in bios. I can not clear CMOS using the jumper on the motherboard, also tried re-flashing bios suing a USB stick but it also doesn't work. The only solution that I can think of right now is re-flashing the bios chip using an external programmer but the problem is that I don't have the bios dump of p500 for flashing externally and I don't know the location of bios chip. If someone can provide the bios dump and bios chip location it would be really helpful....
                                          11-28-2023, 05:28 AM
                                        • DynaxSC
                                          by DynaxSC
                                          11-17-2023, 10:56 AM
                                        • TacticalFahrrad
                                          [REQUEST] Fujitsu Lifebook E5513 – Full BIOS Dump Needed (.bin)
                                          by TacticalFahrrad
                                          I extracted the official BIOS update package from Fujitsu (contains FJNB2FD.CAP, ~18.7 MB) and tried tools like UEFIExtract, but it seems to only contain...
                                          06-30-2025, 04:09 AM
                                        • hirens
                                          Lenovo ideapad 3 14IGL05 bios dump needed
                                          by hirens
                                          model: 81wh
                                          sn: pf36ta6h
                                          board no: nm-c961 gs453/gs553
                                          hey guys above is my laptop info
                                          it only blinks the power button kindly help me with a working dump
                                          old dump attached...
                                          07-21-2023, 04:48 AM
