Lenovo C50-30 bios dump needed, please!
  • lau2rentiu
    • Jan 2020
    Re: Lenovo C50-30 bios dump needed, please!
    Hi guys. is anyone having a bin file for a lenovo c50-30 f0b1 . I', stuck. I can't find a working bin file. Please help
    • peste
      • 13551
      • ROMANIA
      post the original bios ..
      • MiguelRico981228
        • May 2020
        • 38
        • Colombia
        Originally posted by RxTx
        test ok
        working for me
        thanks u
        • Fadda88
          • May 2017
          • 12
          • Italy
          thanks a lot
          • islamfouda
            • Apr 2023
            • kuwait
            thanks a lot
            • TIRCEN90
              • Feb 2022
              • 23
              • México
              #26
              Hello, could you help me? With the original BIOS it won't turn on. I tried my original EC with the plague BIOS, it turns on but without video.
              Lenovo C50-30 TYPE: f0b1 S/N S100D189
              • Joluvillas
                Lenovo ThinkPad L15 Gen 1 i7 (20U4) Bios and EC dump needed
                by Joluvillas
                Hi all! I was reading on tutorials how to flash a bios to remove password from a bios, and I ended up reading the EC chip instead of the main bios chip, it only gave me a .bin file of 1,024kb, I learned later that that is the EC chip not the main bios chip (I should have read the tutorials here instead before attempting anything, my bad), I went to flash the original backup, the 1,024kb size file into the same chip and laptop is not powering up anymore. I may have screwed the chip or even the motherboard (Hopefully not), I am trying to see if there is a fix before I discard it. I had a couple...
                06-18-2024, 10:35 PM
              • AHmad_Salal
                Need BIOS Dump/ROM for Lenovo Thinkstation p500
                by AHmad_Salal
                Hello all,
                I have a Lenovo Thinkstation P500 that is stuck at post with no display, it happened after I changed the memory timings in bios. I can not clear CMOS using the jumper on the motherboard, also tried re-flashing bios suing a USB stick but it also doesn't work. The only solution that I can think of right now is re-flashing the bios chip using an external programmer but the problem is that I don't have the bios dump of p500 for flashing externally and I don't know the location of bios chip. If someone can provide the bios dump and bios chip location it would be really helpful....
                11-28-2023, 05:28 AM
              • DynaxSC
                by DynaxSC
                11-17-2023, 10:56 AM
              • TacticalFahrrad
                [REQUEST] Fujitsu Lifebook E5513 – Full BIOS Dump Needed (.bin)
                by TacticalFahrrad
                I extracted the official BIOS update package from Fujitsu (contains FJNB2FD.CAP, ~18.7 MB) and tried tools like UEFIExtract, but it seems to only contain...
                06-30-2025, 04:09 AM
              • hirens
                Lenovo ideapad 3 14IGL05 bios dump needed
                by hirens
                model: 81wh
                sn: pf36ta6h
                board no: nm-c961 gs453/gs553
                hey guys above is my laptop info
                it only blinks the power button kindly help me with a working dump
                old dump attached...
                07-21-2023, 04:48 AM
