Inspiron 530 bios dump needed
    • 31247
    as the title says.
    • 21852
    Re: Inspiron 530 bios dump needed
    Here you go,one of these is the right bios. Please read this post about the different motherboard versions: https://www.dell.com/community/Deskt...e/td-p/4732156
      • 31247
      thanks.
      is that ICH9 rom original?
      there is a hacked one floating around that is fucked because the MAC address is missing.
      • lti
        • May 2011
        • 2557
        I think you're supposed to enter the MAC address from the original BIOS (or a label on the board if the original BIOS is completely unreadable).
          • 31247
          enter it where??
          if these arent dumped from working boards then they are useless because that data must be in them for the o.s. to start.
          btw, i dont know where you got those 4M files - the boards only have a 2M chip on them!!
          i think i'll scap this dell shit - dell are nothing but a pain in the ass.
          i have been through this bullshit with dell products before with missmatched bios sizes, critical data in the flash to save a few cents on an eeprom etc.
          fucking company should fold and save us all a lot of problems.
            • 21852
            EDIT: My apologies to you stj, i fucked up.I was using some dell bios extractor software and it pulled the bios from a random folder in my temp files,i never noted what size the bios should be,just assumed it was ok.Ive attatched the right ones this time...hopefully.
            I found some more info, according to this dell article there are 10 different 530 variants: https://www.dell.com/support/article...347263?lang=en
            From a post over at bios-mods the different bios versions for each one:
            530: BIOS chip (NVRAM) 16 Mb(G33/ICH9 chipset, uses BIOS v.1.0.18)
            530a/530c: BIOS chip (NVRAM) 8 Mb(G33/ICH9 chipset, uses BIOS v.1.0.18)
            530b/530d: BIOS chip (NVRAM) 8 Mb(G31/ICH7 chipset, uses BIOS v.1.0.2)
            530s: BIOS chip (NVRAM) 16 Mb(G33/ICH9 chipset, uses BIOS v.1.0.18)
            530sa/530sc: BIOS chip (NVRAM) 8 Mb(G33/ICH9 chipset, uses BIOS v.1.0.18)
            530sb/530sd: BIOS chip (NVRAM) 8 Mb(G31/ICH7 chipset, uses BIOS v.1.0.2 )
            Vostro 200: BIOS chip (NVRAM) 16 Mb(G33/ICH9 chipset, uses BIOS v.1.0.16)
            https://www.bios-mods.com/forum/Thre...Project?page=7
            • DynaxSC
              by DynaxSC
              11-17-2023, 10:56 AM
            • TacticalFahrrad
              [REQUEST] Fujitsu Lifebook E5513 – Full BIOS Dump Needed (.bin)
              by TacticalFahrrad
              I extracted the official BIOS update package from Fujitsu (contains FJNB2FD.CAP, ~18.7 MB) and tried tools like UEFIExtract, but it seems to only contain...
              06-30-2025, 04:09 AM
            • vinaypundith
              Razer RZ09-01682 Blade Stealth 13 2016 BIOS dump needed
              by vinaypundith
              I have this laptop that does boot but it's on an older BIOS that has issues with Secure Boot, and I cannot use the normal Razer BIOS updater because for some reason the serial number is missing / got deleted somehow (Common issue on this model, from what I've read). I got a dump of the BIOS chip (or at least what I think is the BIOS chip), and its 16MB in size - the files from the Razer BIOS update are 8MB. (There's two 8MB files, am I supposed to combine these somehow? Or combine with an Intel ME firmware? I have no idea).
              So, I'm looking for a BIOS dump for this machine - a 16MB one....
              08-03-2024, 12:32 PM
            • James Maxwell
              HP DM1-4000er Bios Dump needed
              by James Maxwell
              I badly need bios dump for HP DM1-4000er,
              Model: HP DM1-4000er
              Motherboard: DA0NM9MB6D0 REV.D
              Product: QJ490EA#ACB
              Please help. My bios chip burned so I don't have the old bios anymore. I need bios dump before I can install the replacement.
              10-28-2024, 05:38 PM
            • mkdj
              by mkdj
              Dear all,
              10-19-2025, 04:41 AM
